» Insurance
» Sponsors
SportbikeTrackGearRiders DiscountCustom DynamicsBikeBanditOutback LeatherMotorcycle.com Classifieds!
» Sponsors
Outback Leather
Reply
Thread Tools Display Modes
Old 10-06-2007, 08:25 PM   #1
Daniii
Geezer
Daniii's Avatar
Images: 681
Feedback Score: 0 reviews
The great 60k Mechanical upgrade
Well, after replacing the shift shaft (broken the last night of the KC rally), the bike would randomly jump into the next lower or upper gear! (See thread http://www.1130cc.com/forums/showthr...26#post1090526 for an explanation of what happened) Yikes. So, after consultation with Max, he gratefully agreed to assist (which means doing the heavy lifting - actually most of the lifting) in replacing the tranny with '08 parts. I rode the bike over to Max's this morning.
The bike has 56K miles on it, and has had regular service, all performed by the dealer, over its life. I was concerned, however about severa items;
1.) V-Gauge indicated voltage has been dropping, at times.
2.) Front motor mount is probably shot (everyone else's with this many miles is).
3.) The horizontal stabilizer engine mount at the front of the engine was cracked 40k miles ago. I patched it with JB weld at the time. I'm betting that it didn't hold.
4.) The clutch is probably worn.
5.) There are newer transmission upgrades that would be nice to have installed.
6.) The bike jumps outa gear!
So we loadad the bike on the bike stand in Max's garage, and went to work.
Batzilla / Dan "the Elder"
This is as amusing as watching chimps in a zoo, only without having to dodge flung poo. (Coonass)
Daniii is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-06-2007, 08:28 PM   #2
Daniii
Geezer
Daniii's Avatar
Images: 681
First, Max looked at battery voltage, and we noticed quite a difference between V-Gauge indicated voltage and battery voltage. Decided this potential problem wasn't worthy of our attention.
Bike was loaded onto Max's stand, and we started disassembly. We took off the engine guards, then the right side frame, then the left. We (Max) took off the exhaust as a single piece, The parts are piling up.
Old 10-06-2007, 08:31 PM   #3
Daniii
Geezer
Daniii's Avatar
Images: 681
The radiator was an adventure. Yes, I have extra wiring. Mostly, it wasn't a problem.
Old 10-06-2007, 08:35 PM   #4
Daniii
Geezer
Daniii's Avatar
Images: 681
Yup, motor mount was shot. Finally cleared all stuff from front of engine. Batwing was waiting patiently in front of Max's compressor tank. We wrestled a bit, but finally freed the engine from the frame.
Old 10-06-2007, 08:37 PM   #5
Daniii
Geezer
Daniii's Avatar
Images: 681
Here is the heavy lifting I was discussing earlier. Bike looks lonely without the motor....
Old 10-06-2007, 08:39 PM   #6
Daniii
Geezer
Daniii's Avatar
Images: 681
She is coming apart.....
Old 10-06-2007, 08:41 PM   #7
Daniii
Geezer
Daniii's Avatar
Images: 681
Wow. Some of the case screws were really rusty. Split the cases. Digging down to the tranny....
Old 10-06-2007, 08:46 PM   #8
Daniii
Geezer
Daniii's Avatar
Images: 681
The main bearings look pretty good. No obvious problems with the transmission. Then Max discovered the spring on the shift mechanism has apparently slipped out of place, likely when we were replacing the shift shaft. So there is some roulette with the shaft replacements. Subsquently Max noticed the new part has springs that are longer, and probably can't slip out of place.
Old 10-06-2007, 08:50 PM   #9
Daniii
Geezer
Daniii's Avatar
Images: 681
The offending part. Hard to see, but the spring that resets the shift mechanism has slipped into a lower position. In theory, I suppose one could reset it from outside the case, but I doubt it. The new part probably can't do this. We (ie: Max) replaced all the transmissions shift parts with the new part number ones, Stronger, more beefy, longer springs, etc.
Old 10-06-2007, 08:53 PM   #10
Daniii
Geezer
Daniii's Avatar
Images: 681
After cleaning all surfaces, and aligning all required parts (counterweight has to be lined up with crank), gooping seam with HD assy glue cases are put back together.
Old 10-06-2007, 08:54 PM   #11
balius
Comfortably numb!
balius's Avatar
Images: 1
You must be exhausted after watching Max do all that work
Great thread, I liked how you stepped through the whole process. You are very lucky to have Max there to help you out! Nice to know these bikes can rack up the miles too. I am hoping to get 100k out of mine at least.
Vivid Black 07 DX
balius is offline   Reply With Quote
Old 10-06-2007, 08:57 PM   #12
Daniii
Geezer
Daniii's Avatar
Images: 681
All bolts are torqued per the book. Now the clutch. Seems I had several heat stressed (ie:blue) plates. Max, who apparently has the free world supply of used clutch parts, assembled a clutch set from the best of his and my plates. We used a clutch basket he had, as it wasn't as worn as mine. I thought about trying to get him to donate the new slipper clutch he had in his bike, but decided that was going too far. This new/rebuilt clutch will be good for another 50k miles.
Old 10-06-2007, 09:00 PM   #13
Daniii
Geezer
Daniii's Avatar
Images: 681
We had another, new, oil pump, and decided to use it. The old one was in pretty good shape, showing a little wear, but while we were in here.....
Old 10-06-2007, 09:04 PM   #14
Daniii
Geezer
Daniii's Avatar
Images: 681
The oil filter is a snap to remove when the engine is out of the frame...
Decided to perform the horizontal stabilizer upgrade. This involves drilling and tapping a hole below the existing stabilizer mount. Specs call for a 10M bolt. Lowes laughed when I asked if they had one. So we used 3/8" tap set instead. Its close enough, right? (I'll use a 3/8 bolt as well).
Old 10-06-2007, 09:07 PM   #15
Daniii
Geezer
Daniii's Avatar
Images: 681
Here are the parts we replaced. Max also put on a used, but in better shape than mine, 30 tooth sprocket.
Note; when we were replacing the water lines above the engine, we discovered that the clamp that holds the water lines to the front cylinder had almost vibrated through the aluminum tubing! We reinforced the clamp area with sheet rubber.
Thats it for tonite. Total time spent in actual work, about 8 hours. I estimate another 4 easy hours to finish. That will be tomorrow morning.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Kawasaki ForumDucati ForumHarley DavidsonYamaha R1BMW S1000RR Forum
Vulcan Forums Ducati MonsterV-Rod Forum Yamaha R6 Kawasaki Z1000
Kawasaki ZX Forum Honda 600RR Harley ForumYZF-R6 ForumSportbike Forum
Kawasaki ZX-10RHonda 1000RRSuzuki SVYamaha FZ8Can Am Spyder
Kawasaki KLR 650Honda RC51Suzuki V-StromStar Motorcycles Aprilia Forum
Kawasaki VersysHonda FurySuzuki GSXR Triumph ForumKTM Forum
Kawasaki EX-500Honda GoldwingGSX-R ForumTriumph 675Victory Forums
