Over charging - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Go Back   1130cc.com: The #1 Harley Davidson V-Rod Forum > V-ROD Discussions > V-ROD Technical
Reply
Thread Tools Display Modes
Old 01-09-2013, 01:48 PM   #1
DaEvil
Lifetime Premium
DaEvil's Avatar
Images: 10
Feedback Score: 3 reviews
Over charging
I have an 06 and its over charging i checked the stator and its all good replaced the regulator twice and I still am over charging . I'm kinda stumped here any help would be great.
Thanks
2006 V-Glide
2003 custom built 113 TC
1989 Heritage turned Street Tail
1972 Shovel
1989 Yamaha XT 600
1985 Honda CR 250
1972 240 Z -LS1/6 Speed
DaEvil is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-09-2013, 03:59 PM   #2
pgilliam1
Registered Full
pgilliam1's Avatar
Feedback Score: 1 reviews
What are your symptoms? I guess you put an ohm meter on the battery when it's running to confirm this?
pgilliam1 is offline   Reply With Quote
Old 01-09-2013, 04:03 PM   #3
DUTCHROD
SpeedoDocter
DUTCHROD's Avatar
Images: 66
Garage
Feedback Score: 16 reviews
What exact voltage are you reading when the engine is idling and howmuch does add to that when you rev it? should be 14.3 and not to much schould add.
There is not much more than the stator and the regulator. in the electical diagnostic manual are a few measurements you can do on the stator but the regulator should keep the voltage stable.. the more the bat is charged the less current will flow..
you can measure the charge when you remove the main fuse and connect a amp meter over the open contacts. hard to say what should read but amps instead of milliamps are a indicator.
Is the battery holding charge in rest? i mean a half dead battery draws a bigger current and gets warm
battery in rest engine off is about 12.6 (full) and when you start it takes a few seconds to rise to 14.3v after a day maybe 5-10 seconds and in winter maybe a minute
CUSTOM BUILD AND DESIGNED SPEEDO COLOR KIT'S !
-Crazy Colors gauge kits for all VR speedo's - BRIGHT!! A cruel cool easy DIY project.
website's 'News' page :
- 'DCL-BLF1' Plug 'n Play Brakelight modulator with over 115 patterns and settings
- 'DCL-HLS1' Headlight Switch for HID's
- Electronic software conversion service of MPH to KPH speedo's ! have yours done combined with a light kit now!
- soon: load equalizer
DUTCHROD is offline   Reply With Quote
Old 01-09-2013, 04:17 PM   #4
Philthy
Registered Full
Philthy's Avatar
Images: 1
Quote:
Thanks
What are you calling "over charging"? What voltage are you reading?
The pilot is always the first person at the scene of the crash.
Philthy is offline   Reply With Quote
Old 01-10-2013, 01:07 AM   #5
DaEvil
Lifetime Premium
DaEvil's Avatar
Images: 10
idle is like 14.23 rev it up and I have hit 18 !!
2006 V-Glide
1972 Shovel
1989 Yamaha XT 600
1985 Honda CR 250
Old 01-10-2013, 04:15 AM   #6
DUTCHROD
SpeedoDocter
DUTCHROD's Avatar
Images: 66
Garage
Thats not good! is the regulator grounded ok? the voltages from the stator are (have no diagnostic manual at work) say from low rev 15 volts to maybe 40 -50 volts at 7-8-9K linear climbing...
I can imagine a bad ground distroys the regulator.. also check the other ground straps on the bottom and top of engine
Old 01-10-2013, 07:48 AM   #7
rbabos
Registered Full
Feedback Score: 0 reviews
Bad grounds as suggested. It could also be the battery at fault since resistance is required to tell the regulator what to do. They can do a lot of weird things and still start the bike.
rbabos is offline   Reply With Quote
Old 01-10-2013, 09:32 AM   #8
pgilliam1
Registered Full
pgilliam1's Avatar
Be sure to post your resolution to this problem. It's a weird one.
Old 01-10-2013, 07:13 PM   #9
RustyG
Lifetime Premium
RustyG's Avatar
Images: 99
Feedback Score: 11 reviews
It's the regulators job to limit the output of the stator as well as convert it from AC to DC volts. with 18 volts coming out of it I suggest it is the regulator at fault here. Battery condition does not play a part here.
Batterys routinely go bad. Mine last about 4 years. If battery condition was a factor you would see many posts here regarding this condition.
Regards,
John
Quote:
2007 VRSCX 0461 / 1400
2002 Road King Classic
Old 01-10-2013, 07:20 PM   #10
pgilliam1
Registered Full
pgilliam1's Avatar
But he said he replaced the regulator twice and I assume with similiar outcomes??? My bet is a bad ground.
Old 01-10-2013, 07:32 PM   #11
RustyG
Lifetime Premium
RustyG's Avatar
Images: 99
I missed that part. Bad ground would cause a problem.
Regards,
John
Old 01-14-2013, 12:20 PM   #12
DaEvil
Lifetime Premium
DaEvil's Avatar
Images: 10
I checked the grounds again and all is good thats why this makes no sense to me
2006 V-Glide
1972 Shovel
1989 Yamaha XT 600
1985 Honda CR 250
Old 01-14-2013, 12:23 PM   #13
DaEvil
Lifetime Premium
DaEvil's Avatar
Images: 10
I could try to use a different battery maybe ill try and use one with out taking mine out and see what it puts out
2006 V-Glide
1972 Shovel
1989 Yamaha XT 600
1985 Honda CR 250
Old 01-14-2013, 12:48 PM   #14
pgilliam1
Registered Full
pgilliam1's Avatar
I really can't see the battery causing this condition but it's an easy swap just to see. I'm sure you've checked and rechecked the connectors and wiring to and from the regulator - um right?
Old 01-14-2013, 03:21 PM   #15
matt2007
Registered Full
It can happen on newer systems but is rare.A shorted cell can cause an overcharge condition on some newer electronically controlled systems but I don't know it the Vrod is one of them.Even the wrong replacement battery can cause issues with these systems.Try a google search
matt2007 is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
