Rev limiter - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Go Back   1130cc.com: The #1 Harley Davidson V-Rod Forum > V-ROD Discussions > V-ROD Hi-Performance
Reply
Thread Tools Display Modes
Old 01-04-2013, 06:31 PM   #1
dshuman
Registered User
dshuman's Avatar
Feedback Score: 0 reviews
Rev limiter
This is the first motorcycle I have had that will hit the rev limiter in top gear. Is it safe to move it up to 10k?
dshuman is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-04-2013, 06:52 PM   #2
pScyko
Jarhead
pScyko's Avatar
Images: 3
Its definately been done. Unless you plan on replacing internals (i.e cams, piston heads, piston valves, valve springs) before you do it, it is not reccomended. You would just be asking for trouble IMO. Having an engine detonate at 140mph would not be cool.
Why not change pulley sizes?
/Respectfully Submitted,
Vintage 2002 Harley Davidson V-Twin_Racing_Street_Custom_A_Model_V-ROD
De-badged vivid black & chrome
Weld Racing Charger5 wheels w/ matching pulley
Stage II Cams
Slipper Clutch
Semi-topless SE Modded
16Ga Screamin EagleŽ headers
Screamin EagleŽ Race Tuner (.MT6)
Shorai Li-Fe LFX21
Unlimited Engineering 5.3 Gal gas tank
pScyko is offline   Reply With Quote
Old 01-04-2013, 07:05 PM   #3
vrunner79
Registered Full
vrunner79's Avatar
I wouldn't do it. I hear the oil pumps like to cavitate above 9,000 rpm . and if you have the stock cams then there's no need to raise the limiter. Hp starts to fall off about 8,000 rpm ..IMHO
2009 VRSCF
vrunner79 is offline   Reply With Quote
Old 01-04-2013, 07:17 PM   #4
pScyko
Jarhead
pScyko's Avatar
Images: 3
It's been mentioned here before that the rev limiter is set to 200rpm less than what the stock valve springs can handle.
Stage II Cams
Slipper Clutch
Shorai Li-Fe LFX21
Old 01-04-2013, 08:58 PM   #5
dshuman
Registered User
dshuman's Avatar
Thanks for the advice, what kind of difference will this make in the lower gears/lower rpms; and what will I gain for top speed?
Old 02-02-2013, 01:57 PM   #6
tor2502
Registered Full
tor2502's Avatar
Images: 19
Garage
Feedback Score: 1 reviews
Quote:
Anyone know how mutch rev bee-hive springs can handle ?
06 V-rod VRSCSE2 CVO
tor2502 is offline   Reply With Quote
Old 02-02-2013, 08:12 PM   #7
vrunner79
Registered Full
vrunner79's Avatar
Quote:
there's a lot more then valve springs that go into a high rpm engine. Oil pump, rods, piston pins, even the valves themselves. parts start to flex when you push them beyond what there designed to handle.
2009 VRSCF
Old 02-05-2013, 08:42 AM   #8
FABSTER
GFYS
Images: 23
Feedback Score: 33 reviews
Interesting, any more details about this?
Old 02-05-2013, 11:07 AM   #9
pScyko
Jarhead
pScyko's Avatar
Images: 3
re subbed. I am only vaguely familiar with the concept of cavitation. I know in aircraft it is detected by measuring vibrations.
Stage II Cams
Slipper Clutch
Shorai Li-Fe LFX21
Old 02-05-2013, 12:42 PM   #10
stever975
Super Moderator
Images: 22
...I am only vaguely familiar with the concept of cavitation. I know in aircraft it is detected by measuring vibrations.
Cavitation in a fluid pump refers to a condition when bubbles form and then collapse in the fluid on the inlet side of the pump due to a low enough pressure to cause the fluid to vaporize. When this occurs the pump can no longer pump fluid efficiently and, for some types of pumps, the shock waves (vibration) produced as the fluid bubbles collapse can damage the pump.
stever975 is offline   Reply With Quote
Old 02-05-2013, 01:31 PM   #11
Ed-Rod
Registered Full
Ed-Rod's Avatar
I don't think the oil pump is ever an issue 10k RPM. Plenty of guys on the forum run a 10k rev limit - valve springs are another story.
2004 B 1350 Stroker
Done gone big bore
VRFID
Supertrapp V5
Jones 480/455
SE CNC Heads
2010 Dragon Rally Alumni
Ed-Rod is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
