Motohooligan air box - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Go Back   1130cc.com: The #1 Harley Davidson V-Rod Forum > V-ROD Discussions > V-ROD Hi-Performance
Reply
Thread Tools Display Modes
Old 01-04-2013, 03:37 PM   #1
losNRS
Registered Full
losNRS's Avatar
Feedback Score: 2 reviews
Happy New Year to all. Santa was generous this year and dropped some Benjamins to me so that I could play.
I'm thinking of going with the Motohooligan air filter set-up (yes I know, gain of only 2-5 hp), but the thing is a work of art. Anyway, on my 08 DX, I"m currently running topless with drilled holes along the bottom tray, S.E. Stage II cams, stock T-bodies, Rinehart 2-1, and dyno tuned with SEPST.
My question for those in the know: Do you think, and/or recommend that I would need to re-tune after installing the Motohooligan setup?
Thanks
losNRS is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-04-2013, 04:39 PM   #2
VrodPete
Elephant Motors Rock
VrodPete's Avatar
Images: 23
Feedback Score: 3 reviews
I would say probably not, the changes would not be very large - but if you did re-tune you will probably see the rear cylinder fueling change a little more than the front due to the stacks being equal length in the MHAB.
'08 VRSCAW
1402 Oilman Elephant Motor - Fitzgerald Motorsports Style
(Fourteen-Oh-Twous Copicaticus)
HD SE II Cams, 3/8" Falicon Crank, Carillo Rods, CP Pistons, DA Fitz Engine Brace, Destroyer Injectors, Doherty oil pan, DA Fitz Head Port/Polish/+1mm Valves+springs, DA Fitz 58mm TBs, ARP studs, V&H 2nd Gear+Shift Shaft, Motohouligan Airbox, Wegner 2->1 Exhaust with Supertrapp V5
152.77 HP, 101.06 TQ
Other Toys: '01 BMW K1200LT, '76 Honda CB550F, '81 Mooney M20J
VrodPete is offline   Reply With Quote
Old 01-04-2013, 04:58 PM   #3
losNRS
Registered Full
losNRS's Avatar
Quote:
That's what I thought, just trying to err on the side of caution by asking you guys in the know. Thanks Pete. Not to get off topic, but, hows the beast running....gone against any big cubes air cool engines? Anyway, since this thing (Motobox) came out, I've been wanting one...if anything, just to admire it for the craftsmanship whenever the clam shell comes off. I believe I'm going to pull the trigger on it.
Old 01-04-2013, 05:13 PM   #4
santeg
Fah q 2
santeg's Avatar
Images: 31
I would do a couple data logs just to confirm. the sepst has that option, no?
Motor oils are like women. There are all different types, but most do a good job of lubing your crank.
santeg is offline   Reply With Quote
Old 01-04-2013, 05:58 PM   #5
losNRS
Registered Full
losNRS's Avatar
Quote:
Not sure....I'm fuc...up when it comes to stuff like this...i'll check, and knowing me being a chicken shite (for stuff like this), I'll probably take the V back to the dyno and get it re-tuned. I know it's a lot of money for this apparatus, but damn, it sure looks nice. Certainly, it's not going to gain much; however, it seems to add small power across the rpm scale. It seems not to retract power either. I appreciate you "guys" jumping on this when it came out and took a calculated and educated chance on it. It certainly makes people like me easier to make a decision. Thanks
Old 01-04-2013, 08:20 PM   #6
Consig64
FATASSDX
Consig64's Avatar
Images: 33
Feedback Score: 11 reviews
On my 1402, when I went from topless to Motohooligan I needed to add fuel to my map.
08 DX - 1402 Stroker (3/8" Falicon Full Circle Crank, K1 Rods, CP Pistons, 10mm ARP Studs, HD SE II Cams, Destroyer Injectors, V&H 2nd Gear+Shift Shaft, Motohooligan Airbox, Trask Output Shaft Support, Fitzgerald: Head Port/Polish/+1mm Valves+Springs, 58mm TBs, Engine Brace, Billet Chrome Oil Pan, 26t Pulley)
Consig64 is offline   Reply With Quote
Old 01-05-2013, 10:24 AM   #7
losNRS
Registered Full
losNRS's Avatar
Yeah Consig, seems the Moto box flows a little bit more air. Cool. Thanks for the replies, brothers.
Old 01-07-2013, 10:43 AM   #8
VrodPete
VrodPete's Avatar
Images: 23
Quote:
No real on-street run (yet), but a guy I know with a 144" Road King that makes about 140TQ and 140HP rode it after the 1402 was in, broken in and tuned and said "WOW, that thing is REALLY fast". He didn't let me ride the RK, it "needed some more tweaks"
'08 VRSCAW
Old 01-07-2013, 04:49 PM   #9
losNRS
Registered Full
losNRS's Avatar
Nice, I think because power to weight ratio, gearing, and lack of rpms, the Road King wouldn"t stand a chance. BTW, I ordered the Motobox, and waiting for it like a kid waiting for Santa to bring toys.
Old 01-07-2013, 05:05 PM   #10
Demthios
To boost or not??
Demthios's Avatar
Images: 19
Feedback Score: 4 reviews
I know that feeling losNRS, when I got the box in it was like Christmas. I have a buddy that wanted to see if so I was taking teaser shots with my phone as I unboxed the Motohooligan Airbox. It is quite the piece of work.
Demthios is offline   Reply With Quote
Old 01-07-2013, 05:08 PM   #11
pwrman
Registered Idiot
pwrman's Avatar
Feedback Score: 6 reviews
From what I read the gains are small and it tends to transfer some engine heat up towards... um well lets say private parts. Would be great to keep the boys toasty in cooler weather riding. I bought one any damn way but have not had time to fool with it, the winter mods start this weekend. It is a well made piece, looks cool and it seems a shame to cover it up. So I bought a dented up tin and started cutting it out so the air cleaner sticks out, like an old muscle car with blower or tunnel ram. I plan on a retune once I get all my mods done. JMO but unless you are using auto tune or can DIY then I would get it tuned. If you find a friendly tuner that will let you do some base line before the retune, post up the results for the rest of the class to see.
pwrman is offline   Reply With Quote
Old 01-09-2013, 08:33 AM   #12
losNRS
Registered Full
losNRS's Avatar
Quote:
Yeah, it's amazing how old wrinkled gray hair men, act like kids when it comes to things like this.
Old 01-09-2013, 08:45 AM   #13
losNRS
Registered Full
losNRS's Avatar
Quote:
Yeah, I'm going to retune it, just for piece of mind and to see the difference, if any, from my previous dyno tune. Previous tune with the same combo as current yielded 126 hp / 82 tq SAE. With the exception of twice, I use the same dyno and technician. The dyno seems "not" to be a happy one, and the tech knows what he's doing. I will post up with the previous dyno sheet, and the one after the Motobox.
Old 01-09-2013, 04:10 PM   #14
v-tron
The Riding Dutchman
v-tron's Avatar
Feedback Score: 0 reviews
Just installed the motohooligan..
The Legend Airride compressor fits just nice next to the airbox but took some time to make a proper bracket.
ID:	193523   Click image for larger version
www.nightrodders.nl
v-tron is offline   Reply With Quote
Old 01-09-2013, 04:41 PM   #15
Demthios
To boost or not??
Demthios's Avatar
Images: 19
make sure you loctite those top hex's I've had one vibrate out
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
