Signal light eliminator - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Go Back   1130cc.com: The #1 Harley Davidson V-Rod Forum > Specific Model > VRSCDX
Reply
Thread Tools Display Modes
Old 12-30-2012, 06:43 PM   #1
Whip65
Registered Full
Whip65's Avatar
Feedback Score: 0 reviews
Where can you buy signal light eliminator/relocate kits for my new NRS?
Thanks new at this
Whip65 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-30-2012, 08:04 PM   #2
_R_
Registered Full
_R_'s Avatar
Feedback Score: 3 reviews
There was a guy on eBay who use to fabricate them. I tried to look him up but could not find him. He usually fabricates Nissan Z parts and since he had a vrod, he fabricated these too. Maybe someone on the forum knows him and can help you out. With his kit you could mount the rear turn signals near the upper fastner of the rear shocks.
[SIGPIC][/SIGPIC]
_R_ is offline   Reply With Quote
Old 12-30-2012, 08:14 PM   #3
Rift
Registered Full
Rift's Avatar
I don't know about the 12/13 but my 11 has bag attachment holes in the under fender that many people have just taken small plates of steel and relocated there lights there. About mid fender you should feel tiny holes if they are still there. Four holes in a little steel plate will move em to a pretty good spot. I had planned on using this but instead I got the led strip for the bottom rear of the fender
Rift is offline   Reply With Quote
Old 12-30-2012, 08:55 PM   #4
darkdx
Registered Full
Feedback Score: 1 reviews
I just ran across a pretty nice set up for the 12/13 rear turn signals....check out chromeglow.com. It's a led strip set up that wraps around the underneath of the rear fender.
Sent from my iPhone using Motorcycle.com Free App
darkdx is offline   Reply With Quote
Old 12-30-2012, 09:26 PM   #5
killerVRod
Registered Full
killerVRod's Avatar
Images: 15
Feedback Score: 16 reviews
Are there spacers between the shock and the frame?
-Keith
Present : 2013 NRS with AlteredStateDesign controls,sidemount, lights,headlight holder, sprocket cover, handlebars.
Past : Custom Lapis Blue V-Rod (Rick's 240 Lector wheel setup,chrome swingarm,Rizoma bars,signal relocators,LED rear lights,V-mod pipes,Custom cut sidemount plate,11.5" SmoothRide shocks,spike grips,Custom cut mirrors, 3" tribal forward controls)
killerVRod is offline   Reply With Quote
Old 12-31-2012, 02:46 PM   #6
Lason
Registered Full
Lason's Avatar
There is a hole on either side right behind the shock mounts on the inner fender. Kinda behind the reflector. I just made "L" brackets out of 14ga sheetmetal and bolted them there. Had to lengthen the wiring but wasnt too hard. Looks a million times better. Also used a dremel and shaved off the mounts on the stock dogs ass, that was after this pic was taken though, I dont have any real good ones of that. Looks factory now.
2013 Night Rod Special
-ABS/Security
-DDM Tuning HID
-Customled tail light flasher module
-Memphis Shades Bullet Fairing
-Dynojet Power Vision
-Vance and Hines Comp 2-1
-K&N air filter
Lason is offline   Reply With Quote
Old 12-31-2012, 07:15 PM   #7
Whip65
Registered Full
Whip65's Avatar
Tail lights look awesome there. How does the V&H 2 into 1 sound thinking of going with the black widow slip ons send me more pics of you bike
Thanks
Old 12-31-2012, 08:20 PM   #8
Lason
Registered Full
Lason's Avatar
The V&H sound great. Everyone here seems to run it. No real pics of my bike. I took this one the other day though.
Sent from my Nexus 7 using Motorcycle.com Free App
-ABS/Security
-DDM Tuning HID
-K&N air filter
Old 01-06-2013, 07:41 PM   #9
megaduty
Registered Full
megaduty's Avatar
Images: 2
Looks clean Lason!
How you liking the VH 2into1 and Power Vision tuner combo?
Also, is that the HD gear display unit on your left handle bar? Worth the investment?
I'm just North-East of you in McKinney.
megaduty is offline   Reply With Quote
Old 01-07-2013, 12:49 PM   #10
Lason
Registered Full
Lason's Avatar
Quote:
Originally Posted by megaduty View Post
Looks clean Lason!
Loving the pipe and tuner, no issues with either. I think the fit could have been a little better on the pipe but no complaints really. I mainly use the PV for water temp gauge now.
The thing on the left if actually just a 3 switch housing from Harley. I put it on there for the LED lighting I installed. Looks factory but the housing a bit bigger than I would have liked. It houses up to 3 switches, I only have one on in that pic and have since installed another but havent used it yet. I was going to wire the killerglass LED seperate from the rest of the bike but changed my mind.
-ABS/Security
-DDM Tuning HID
-K&N air filter
Old 01-07-2013, 05:44 PM   #11
DUTCHROD
SpeedoDocter
DUTCHROD's Avatar
Images: 66
Garage
Quote:
that would be MegaZ.
CUSTOM BUILD AND DESIGNED SPEEDO COLOR KIT'S !
-Crazy Colors gauge kits for all VR speedo's - BRIGHT!! A cruel cool easy DIY project.
website's 'News' page :
- 'DCL-BLF1' Plug 'n Play Brakelight modulator with over 115 patterns and settings
- 'DCL-HLS1' Headlight Switch for HID's
- Electronic software conversion service of MPH to KPH speedo's ! have yours done combined with a light kit now!
- soon: load equalizer
DUTCHROD is offline   Reply With Quote
Old 01-07-2013, 06:43 PM   #12
_R_
Registered Full
_R_'s Avatar
Quote:
You are absolutely right, Sir.
[SIGPIC][/SIGPIC]
Old 01-07-2013, 10:49 PM   #13
Whip65
Registered Full
Whip65's Avatar
Just fabbing up some brackets to move my tail lights also going to make a bracket for the license plate get rid of the stock part all together. Considering putting new Muscle mirrors on with the built in signal lights, just paint them flat black. Think they should fit. I'll post some pics later.
Old 01-09-2013, 07:06 PM   #14
_R_
Registered Full
_R_'s Avatar
In case someone needs them in the future.
http://www.ebay.com/itm/251210406681...84.m1423.l2649
[SIGPIC][/SIGPIC]
Old 01-19-2013, 02:06 AM   #15
megaduty
Registered Full
megaduty's Avatar
Images: 2
I just chopped my tail and relocated my rear signals to the shock tower upper bolts and installed a side mount plate:
I also installed some cheap temporary rear LED pole signals ($20 Ebay)
Got an HD vid for my Arnott shock install that shows them in motion:
https://www.youtube.com/watch?featur...&v=mj3yqQ7pE5M
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
