Can't snake wires through bars? - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Reply
Thread Tools Display Modes
Old 12-25-2012, 04:48 PM   #1
DSMRossi
Registered Full
DSMRossi's Avatar
Feedback Score: 1 reviews
I have an 03 A.
My Ma bought me some Heat Demons for Xmas, and for some reason I can't snake the harness through the bars. The kit even comes with a thin plastic snake to make short work of it, but it keeps binding up near the speedo assembly. Anybody know what could be up? Is there any other wiring in the bars I don't know about?
DSMRossi is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-25-2012, 06:55 PM   #2
bigrog74
slave to the grind
bigrog74's Avatar
Images: 24
Feedback Score: 11 reviews
Wiring in the bars is not standard on the A models unless u drill a hole in them yourself or have set of bars that are predrilled. That being said, I usually use a piece of wire like speaker wire. Thread it thru first, tape the wire that I want to pull thru to the wire, then pull it all back thru. Done it at least a dozen times and works well.
Sent from my Motorcycle iPhone app
'04 VRSCB
bigrog74 is offline   Reply With Quote
Old 12-25-2012, 09:17 PM   #3
TooRad4u
V-Rod Newb
TooRad4u's Avatar
Images: 49
Feedback Score: 3 reviews
You can also use a shop vac on one end and a piece of string. Suck the string through the bars then tie or tape onto the wires and pull them back thru. That is what I did on my '03 for my heated grips. - Jim
TooRad4u is offline   Reply With Quote
Old 12-25-2012, 09:26 PM   #4
DSMRossi
Registered Full
DSMRossi's Avatar
It was that last bend that it kept getting caught on. What I was able to do was pull the small clip that holds the harness to the bar out. In the hole the clip was in, I was able to feed 2 pieces of wire through that little hole, one going to each bar end. Then I soldered the 2 pieces of wire together and stuck them in the hole.
Speaker wire may have worked being soft like it is. Thanks guys
Old 12-25-2012, 10:08 PM   #5
HoneyB
Pat (Patrick!)
HoneyB's Avatar
Images: 14
Feedback Score: 31 reviews
I hope the hole has no burrs...
Old 12-26-2012, 04:44 AM   #6
Vambo
Vambo's Avatar
Feedback Score: 21 reviews
Grease it all up good with pulling grease.
Vambo is offline   Reply With Quote
Old 12-26-2012, 06:46 PM   #7
Luvmy04VRod
Lifetime Premium
Luvmy04VRod's Avatar
Images: 30
Feedback Score: 17 reviews
WD40?? should have worked good?
PROUD Member Post #149 Las Vegas, NV.
Lord forgive me for what I am about to do but these b@sterds must die!
I will NEVER apologize nor waste my time defending my God-given right to keep and bear arms; The more and bigger the arms, the better
Luvmy04VRod is offline   Reply With Quote
Old 12-27-2012, 04:43 AM   #8
Vambo
Vambo's Avatar
Quote:
Not the same at all.
Old 12-27-2012, 05:57 AM   #9
Luvmy04VRod
Lifetime Premium
Images: 30
Hhmmmmm, I wonder why it wouldnt have worked? Never had to do this so I am just thinking out loud. But I would have also tried the wire and taped the other wires to it aswell.
Glad you got it figured out.
Old 12-27-2012, 07:26 AM   #10
Hatchetforce
Registered Full
Hatchetforce's Avatar
We had the same issue but it was with the wires making a sharp turn. We we were able to solve this by using a different heat shrink. Be careful of using WD40 as a lube on the wires. WD40 contains petroleum which will break down many rubber products over time. It is absolute death on o-rings.
Hatchetforce is offline   Reply With Quote
Old 12-27-2012, 01:49 PM   #11
DSMRossi
Registered Full
DSMRossi's Avatar
It was the very last bend. After you clear the clamshell, you pass through that low bend and it pushes the wire towards the apex of the final bend. It was a pain in the ass. Just feed both ends of a long wire through the hole the harness clips into. Then push it towards both ends and poke the loop you're left with into the hole. No lube needed.
Old 12-27-2012, 03:34 PM   #12
pday
(Peter)
pday's Avatar
Images: 3
Quote:
That's the way I did it. Worked well. You may also use some wire lube which you can get at home depot to reduce the friction when pulling the wires through.
Peter Day
pday is offline   Reply With Quote
Old 12-29-2012, 02:00 PM   #13
bigrog74
slave to the grind
bigrog74's Avatar
Images: 24
You know you can pull that plastic harness clip out before you start?
'04 VRSCB
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
