Stage 2 - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Go Back   1130cc.com: The #1 Harley Davidson V-Rod Forum > V-ROD Discussions > V-ROD Hi-Performance
Reply
Thread Tools Display Modes
Old 12-23-2012, 10:14 AM   #1
AZ-D-ROD
Registered User
AZ-D-ROD's Avatar
Feedback Score: 0 reviews
Stage 2
Just got my bike back from dealership. Full stage 1. Already want to start stage 2 work. Anyone know the best setup? Stage 1 made it sound good, but far from what I'm looking for as far as power. Especially in the low end.
AZ-D-ROD is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-23-2012, 11:00 AM   #2
slim_b_kool
Registered Full
slim_b_kool's Avatar
Garage
Well first off the vrod isn't known for low end torque. I used SE stage 2 cams in my motor and they are pretty popular. No real need to change injectors or throttle bodies unless going to a big bore. The vrod makes good power but weighs alot. We are limited as far as how much power we can make because of engine case design.
slim_b_kool is offline   Reply With Quote
Old 12-23-2012, 11:02 AM   #3
AZ-D-ROD
Registered User
AZ-D-ROD's Avatar
Thanks Slim. What kinda gains did the SE Cam work give ya?
Old 12-23-2012, 12:01 PM   #4
Malcomx
Feedback Score: 2 reviews
Don't know anything about stages, but about the only things you can do to a V-Rod for more power are a good tune, cams, big bore, NOS, and forced induction.
Malcomx is offline   Reply With Quote
Old 12-23-2012, 12:11 PM   #5
slim_b_kool
Registered Full
Garage
Quote:
usually 10 or 15 hp at the ground.
Old 12-23-2012, 12:16 PM   #6
rippie74
1130cc is enuff 4 me
rippie74's Avatar
Images: 3
Feedback Score: 9 reviews
I went from 103HP to 119HP with the SE2 cam install & dyno tune.
2003 100th Anniversary V_Twin_Racing_Street_Custom_A_Model_V-ROD
Iceberg Blue 8K H.I.D. Conversion
Progressive Suspension
Sundowner
Fender Base Plate/Low Sissy Bar/Luggage Rack
UE Trick Tank
Keyless Ignition Upgrade
Slipper Clutch
Drilled Belt Guards
Superchicken covers
100th Anniv. Windshield
Topless
SE2 Cams
Chromex Coated CFR
Amsoil
Metzeler
Screamin Eagle Race Tuner
rippie74 is offline   Reply With Quote
Old 12-23-2012, 12:23 PM   #7
AZ-D-ROD
Registered User
AZ-D-ROD's Avatar
Any idea on what the cost is for having the SE stage 2 cams done at a dealership?
Sent from my iPhone using Motorcycle.com Free App
Old 12-23-2012, 12:40 PM   #8
Demthios
To boost or not??
Demthios's Avatar
Images: 19
Feedback Score: 4 reviews
Depends on the dealers, mine quote around 1200 for labor and the cams. I just ended up having them down when I went big bore.
Demthios is offline   Reply With Quote
Old 12-23-2012, 12:43 PM   #9
rippie74
rippie74's Avatar
Images: 3
My SE2 cam install & (dyno tune @ 2.5 hours) was I think, $560.00 or $590.00. I know it defineately was not over $600.00. The cams cost me $418.00 shipped to my door from Elvis @ Hales HD. Scott @ Fitzgerald Motorsports reffered me to him, both Great guys. So all in all it was around $1000.00. I've heard of dealerships charging as high as $1800.00 for this same install (insane). I had Vreelands do mine because they are experts @ everything VRSC.
Sundowner
UE Trick Tank
Slipper Clutch
Drilled Belt Guards
Superchicken covers
Topless
SE2 Cams
Chromex Coated CFR
Amsoil
Metzeler
Old 12-23-2012, 12:50 PM   #10
AZ-D-ROD
Registered User
AZ-D-ROD's Avatar
Thanks! I'm dealing with the 1,800 people I guess. Dealer charges 500 for Dyno alone!!!
Old 12-23-2012, 04:25 PM   #11
slim_b_kool
Registered Full
Garage
It pays to shop around. I got cams, TBs, injectors and dyno time was less than that. I wouldn't pay $500 for dyno time. My dealer was around $300.
Old 12-23-2012, 06:33 PM   #12
vrunner79
Registered Full
vrunner79's Avatar
$500 for Dyno time is a rip off to tune cams.. $250 here.
2009 VRSCF
vrunner79 is offline   Reply With Quote
Old 12-23-2012, 06:41 PM   #13
rippie74
rippie74's Avatar
Images: 3
$66/hr for 2.5 hours = $165.00. Plus tax it & was like $180.00ish. That is what I paid for my dyno tune. Also make sure the dealership/mechanic knows what they are doing as far as the install on your bike. I've heard of guys getting charged & arm & a leg & they wound up with a bike that gained a whopping 3HP (no BS). It is curcial that you have a mechanic who is well versed in the VRSC platform do these cams
Oh yea, Uhhh.... $500.00? That's a sign that they litterally have no idea what they are doing as far as "dyno tuning" goes.
I would tell that "stealership" to GTFO LOL.
Sundowner
UE Trick Tank
Slipper Clutch
Drilled Belt Guards
Superchicken covers
Topless
SE2 Cams
Chromex Coated CFR
Amsoil
Metzeler
Old 12-23-2012, 10:36 PM   #14
vrunner79
Registered Full
vrunner79's Avatar
On the tuning for sure.. the stealership I was tuned at couldn't get the engine to pull beyond 7,500 rpms and they kept trying to tell me "that's all it has in it" Were traned in dyno tuning, Blah Blah Blah.. All mighty HD techs... I already knew the problem was in the map they were using because I reached out to Vreelands and they told me what the problem was. After a day and 1/2 on the dyno they finally listened and made me sign a waver that I was having them do something outside of what a HD tech would do and wouldn't you know it, It worked perfect!! Moral of the story, Beware of HD service techs unless they work on "V's" on a regular basis
2009 VRSCF
Old 12-24-2012, 07:41 AM   #15
rippie74
rippie74's Avatar
Images: 3
^^^^ YUP, You have to use the Stage I map & build the A/F ratios off that in order to tune your bike when the SE2 cams are installed.
Sundowner
UE Trick Tank
Slipper Clutch
Drilled Belt Guards
Superchicken covers
Topless
SE2 Cams
Chromex Coated CFR
Amsoil
Metzeler
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
