Price difference between 1350 & 1402 bb - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Go Back   1130cc.com: The #1 Harley Davidson V-Rod Forum > V-ROD Discussions > V-ROD Big Bore/Turbo/SC/NOS area
Reply
Thread Tools Display Modes
Old 12-17-2012, 05:57 AM   #1
Ozracer
Night Rod Muscle
Ozracer's Avatar
Feedback Score: 0 reviews
Guys whats the major cost differences between these two builds?
2011 Night Rod Muscle
Build:
Ozracer is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-17-2012, 08:51 AM   #2
Demthios
To boost or not??
Demthios's Avatar
Images: 19
Feedback Score: 4 reviews
The only difference that I know of is the crank, and the clearances for the crank. Pretty much everything else I think is done the same really between them. I got a great deal on my crank for my 1350 build, but the 1402 cranks were pretty spendy.
Demthios is offline   Reply With Quote
Old 12-17-2012, 09:01 AM   #3
stomper
REVOLUTION !!!
stomper's Avatar
Images: 37
Feedback Score: 19 reviews
Quote:
Usually around $1500 and up - depending on supply
4 Play 4 Ever
Brian Raguso
1975 - 2007
stomper is offline   Reply With Quote
Old 12-17-2012, 01:33 PM   #4
Ozracer
Night Rod Muscle
Ozracer's Avatar
So what would you have to lay down for each crank i cant see there being 1500 difference between each crank
Build:
Old 12-17-2012, 01:34 PM   #5
Ozracer
Night Rod Muscle
Ozracer's Avatar
Withva 1402 can you use stock pistons and rods or do they both have to change.
Build:
Old 12-17-2012, 07:42 PM   #6
sburke91
'04 1300
sburke91's Avatar
Images: 18
Feedback Score: 9 reviews
For a 1350, you either need stock pistons and shorter rods, or aftermarket pistons (CP typically) and the stock rods.
For a 1402, you need both aftermarket pistons (CP again), and shorter rods.
The crank is also more expensive, as I don't think there's a reweld crank option for a 3/8" crank.
Sean Burke--Delaware OH
'04 VSRCA
1300 'Baby Destroyer' Stroker
SE Heads, Jones Cams/Valves/Springs
Destroyer TB and Injectors
CP Pistons
Bub 7 2-1
Delphi/SERT, sometimes TSII for tuning
Lots of other bits and pieces
Coming someday (if I ever get around to plumbing it):
sburke91 is offline   Reply With Quote
Old 12-17-2012, 07:55 PM   #7
FABSTER
GFYS
Images: 23
Feedback Score: 33 reviews
Scott Fitz ( OHIO V-Rod) should have all the answers
Old 12-18-2012, 04:04 AM   #8
Ozracer
Night Rod Muscle
Ozracer's Avatar
So it's a complete new machines crank is it for a 1402
Sent from my iPhone using Motorcycle.com Free App
Build:
Old 12-18-2012, 05:54 AM   #9
stomper
REVOLUTION !!!
stomper's Avatar
Images: 37
http://www.faliconcranks.com/cranks_price.html
Falicon website for the 3/8 crank - showing price of $2100!!
4 Play 4 Ever
Brian Raguso
1975 - 2007
Old 12-18-2012, 06:24 AM   #10
Z16monte
Registered Full
Z16monte's Avatar
Images: 37
Feedback Score: 2 reviews
Is the Falicon a full circle crank?
Political Correctness is a doctrine fostered by a delusional, illogical liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
Z16monte is offline   Reply With Quote
Old 12-18-2012, 07:16 AM   #11
WhosUrBuddiee
Registered Full
Yes it is a full circle. Also with a 1402, you would need larger injectors, engine brace, and other little goodies. Expect to pay around 5k for a 1350 and 7k for a 1402. (Cheaper of course if you can do the work yourself)
WhosUrBuddiee is offline   Reply With Quote
Old 12-18-2012, 08:33 AM   #12
Demthios
To boost or not??
Demthios's Avatar
Images: 19
Most people go with larger injectors and engine brace when they do the 1350 as well. From most of the builds I've seen on here, pretty much most difference between the two crank. And heck I think I put 7k into mine easily with free labor Thanks again Rod & Lane!
Old 12-18-2012, 09:01 AM   #13
WhosUrBuddiee
Registered Full
I ment it they go from a good idea to necessary.
Old 12-19-2012, 12:30 AM   #14
Ozracer
Night Rod Muscle
Ozracer's Avatar
Demthios shit I cant believe its that costly without labour that just killed it for me when you can get more power with a blower and turbo and have a couple of grand loose change in your pocket...
Build:
Old 12-19-2012, 06:31 AM   #15
VrodPete
Elephant Motors Rock
VrodPete's Avatar
Images: 23
Feedback Score: 3 reviews
Stealth ain't cheap, but it sure is fun!
'08 VRSCAW
1402 Oilman Elephant Motor - Fitzgerald Motorsports Style
(Fourteen-Oh-Twous Copicaticus)
HD SE II Cams, 3/8" Falicon Crank, Carillo Rods, CP Pistons, DA Fitz Engine Brace, Destroyer Injectors, Doherty oil pan, DA Fitz Head Port/Polish/+1mm Valves+springs, DA Fitz 58mm TBs, ARP studs, V&H 2nd Gear+Shift Shaft, Motohouligan Airbox, Wegner 2->1 Exhaust with Supertrapp V5
152.77 HP, 101.06 TQ
Other Toys: '01 BMW K1200LT, '76 Honda CB550F, '81 Mooney M20J
VrodPete is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
