Arnott air-ride questions? - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Go Back   1130cc.com: The #1 Harley Davidson V-Rod Forum > Specific Model > VRSCDX
Reply
Thread Tools Display Modes
Old 12-10-2012, 02:29 PM   #1
pipps83
Registered Full
Feedback Score: 1 reviews
Hi! I just ordered a complete set of arnott shocks for my NRS. My questions about the shocks is can you lower and rise the shocks when you have say for example your wife sitting on the bike in the rear?
pipps83 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-10-2012, 02:55 PM   #2
bwds
brett
bwds's Avatar
Images: 127
Feedback Score: 18 reviews
I do .but my wife only weighs 50 kg
bwds is offline   Reply With Quote
Old 12-10-2012, 03:10 PM   #3
pday
(Peter)
pday's Avatar
Images: 3
Have adjusted on the fly with wife on the back, no problem at all.
Peter Day
pday is offline   Reply With Quote
Old 12-10-2012, 04:44 PM   #4
DUTCHROD
SpeedoDocter
DUTCHROD's Avatar
Images: 66
Garage
Feedback Score: 16 reviews
I adjust my wife on the fly... Naaah, shocks do fine...
CUSTOM BUILD AND DESIGNED SPEEDO COLOR KIT'S !
-Crazy Colors gauge kits for all VR speedo's - BRIGHT!! A cruel cool easy DIY project.
website's 'News' page :
- 'DCL-BLF1' Plug 'n Play Brakelight modulator with over 115 patterns and settings
- 'DCL-HLS1' Headlight Switch for HID's
- Electronic software conversion service of MPH to KPH speedo's ! have yours done combined with a light kit now!
- soon: load equalizer
DUTCHROD is offline   Reply With Quote
Old 12-11-2012, 03:41 AM   #5
Tassie Phantom
Registered Full
Tassie Phantom's Avatar
Garage
Feedback Score: 0 reviews
make sure you have the little filter they supply fitted to slow the drop down to a managable level. Mine dropped too qwik without it
Regards
Phantom
Best 60 ft = 1.358
Best 330 = 3.813
Best 1/8th = 5.911
Best ET = 9.461
Best MPH = 141.77
Tassie Phantom is offline   Reply With Quote
Old 12-11-2012, 04:58 AM   #6
pipps83
Registered Full
Thanks for all the usefull info guys!
Old 12-11-2012, 07:56 AM   #7
ogri45
Registered User
ogri45's Avatar
I was advised away from an air-ride system on my bike because they have been known to lose pressure whilst riding?
ogri45 is offline   Reply With Quote
Old 12-12-2012, 04:14 AM   #8
pipps83
Registered Full
Is it complicated to install the shocks with all the hardware that comes with the kit? How many hours can i count with?
Old 12-12-2012, 04:54 PM   #9
tjvrod
Registered Full
This is a simple system to install follow the instructions. I even modified the install by installing everything in the air box. You see I use the little storage pocket under my fuse box and inbetween the fuel tank to store my magnum disk lock and a pen and pad, just incase i ever need a pen and pad LOL see pics
It may even pay to tig weld the mounting bracket before you install it. see my post..
Other than that you will enjoy the system.
http://www.1130cc.com/forums/showthread.php?t=172166
ID:	192438   Click image for larger version
2007 VRSCDX 1246cc Night Rod Special MY08- Black Denim
-SCREAMIN' EAGLE PRO STAGE II PERFORMANCE KIT
-Daytona Twin Tec Twin Tuner
-CFR Pipe wrapped with Vmod Baffle
-OME Headers Ceramic coated
-Arnott Air Suspension
-SuperBrace
-GhostRider Derby & Clutch covers
-260 Metzler
-BikeTec Headlight & Guage relocation kit
-Zodiac Drag Style Handlebars
-Gulf Western Oil
-NGK Sparks
-145.7hp out rear wheel
No real than you are.
tjvrod is offline   Reply With Quote
Old 12-12-2012, 04:57 PM   #10
tjvrod
Registered Full
Quote:
Filter??? must be a new thing, mine just has a little screw to adjust the flow rate.
-SuperBrace
-260 Metzler
-Gulf Western Oil
-NGK Sparks
Old 12-12-2012, 05:17 PM   #11
DUTCHROD
SpeedoDocter
DUTCHROD's Avatar
Images: 66
Garage
you had a flow adjuster. i asked for that but the guy at arnott's sayd they took it out for costs ...and everybody seemd to want it to drop fast... well, not me
I took a leftover piece of tubing and fixed that in the blowoff outlet. routed it to the louve upfront. molt it with a lighter and made a pince with a plier leaving a small hole... now i have a nice audible HISSSSSS....
Old 12-17-2012, 06:26 PM   #12
gijack22
Registered Full
Go with platinum air ride if your loosing air while your riding...they store the air in the shock and never loose air! Best on the market!
gijack22 is offline   Reply With Quote
Old 12-18-2012, 02:25 PM   #13
HDandBuell
DTH-DLR
HDandBuell's Avatar
Images: 14
Feedback Score: 15 reviews
I have no problems raising to adjust for more load on the fly. Also, I have had no problems with air escaping while I ride. Occasionally, it the bike is in the garage for along period of time, the shock will be airless.
'07 VRSCDX Vivid/Denim
HDandBuell is offline   Reply With Quote
Old 12-18-2012, 02:46 PM   #14
2009NRS
Registered Full
2009NRS's Avatar
can height be adjust while riding (at a slow speed) or just while at a complet stop?
2009 Night Rod Special
Force Streetfighter exhaust
K&N Air Filter
Power Commander V
Arnott air ride
2009NRS is offline   Reply With Quote
Old 12-18-2012, 04:48 PM   #15
alex2494
Lifetime Premium
alex2494's Avatar
Quote:
Speed doesn't matter. You can raise or lower any time
Sent from my Motorcycle iPhone app
alex2494 is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
