Lower airbox gasket - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Reply
Thread Tools Display Modes
Old 12-09-2012, 05:25 PM   #1
rattletrap
Check that P clamp!
rattletrap's Avatar
Images: 23
Garage
Feedback Score: 12 reviews
Lower airbox gasket
It seems like every time I pull the airbox this $10 gasket falls apart and it's never in stock at the dealer. This time I didn't notice until I was reassembling it after the valve lash adjustment and didn't want to wait another week to order one in.
I used a silicone iPad cover from Dollar Tree and made a $1 forever gasket for that bugger! The pic is just the leftovers, the finished product is already one the bike. I have a nice set of hole punches so the bolt holes turned out more precise than the scissor cuts around the rest of it.
-rAtTLeTrAp
Running without hills is like motorcycling without corners.
“Go out and preach the Gospel, and if you have to, use words.”
rattletrap is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-09-2012, 07:09 PM   #2
Dr Dave
Buy American!
Dr Dave's Avatar
Images: 93
Feedback Score: 3 reviews
Good job! Tell us how well that silicone gasket works under the minimum vacuum of the intake. I'm curious if it will migrate into the throttle valve.
Ride it like your life depended on it.
Dr Dave is offline   Reply With Quote
Old 12-09-2012, 09:24 PM   #3
rattletrap
Check that P clamp!
rattletrap's Avatar
Images: 23
Garage
Quote:
Is that supposed to be sarcasm?
I don't think there's any chance of that. This material is .105" thick and a lot sturdier than the paper one. I don't think the heat is going to affect it either, they make bakeware out of the same stuff. I'm sure it seals better and it isn't going anywhere.
If it was going to eat a gasket due to the vacuum it would have eaten a chunk of a stock one by now. I've replaced 4 of them and they all come off in pieces, but none of them had any missing.
-rAtTLeTrAp
Old 12-09-2012, 09:32 PM   #4
rattletrap
Check that P clamp!
rattletrap's Avatar
Images: 23
Garage
The same material also worked great for the gasket on my rear master cover for the pressure bleeder.
-rAtTLeTrAp
Old 12-09-2012, 09:55 PM   #5
rc4man
EXCELSIOR
rc4man's Avatar
Feedback Score: 4 reviews
Silicone doesn't like gasoline. Brake fluid is another matter.
"V" Rod Forman, '04 Anodized "B", 50th B-day gift from wife.
rc4man is offline   Reply With Quote
Old 12-09-2012, 10:19 PM   #6
rattletrap
Check that P clamp!
rattletrap's Avatar
Images: 23
Garage
Quote:
I didn't think silicone was affected by gasoline once it's cured. Maybe I'll have to find something better to make with. Any suggestions aside from the paper stuff the stock one is made with?
-rAtTLeTrAp
Old 12-09-2012, 10:23 PM   #7
HoneyB
Pat (Patrick!)
HoneyB's Avatar
Images: 14
Feedback Score: 31 reviews
How about the "Cork type" gasket material, that you can buy in sheets from most Auto Parts stores? I always made Dirt Bike gaskets out of it.
Old 12-09-2012, 11:14 PM   #8
rattletrap
Check that P clamp!
rattletrap's Avatar
Images: 23
Garage
Cork isn't recommended for fuel either. It looks like nitrile rubber is the way to go. I should be able to find a sheet of that at the autoparts store for about $10. No cheaper than the stock gasket, but I won't have to wait for it and with any luck, it might still last longer.
Thanks for the heads-up rc4man!
-rAtTLeTrAp
Old 12-10-2012, 12:43 AM   #9
sullivancorner
Lifetime Premium
Feedback Score: 11 reviews
Pm me your address and I will send you several oem gaskets...free. I keep a few extra's around. The last thing you want is to suck anything other fuel down into the intake. Happy Holiday's.
sullivancorner is offline   Reply With Quote
Old 12-10-2012, 10:33 AM   #10
rattletrap
Check that P clamp!
rattletrap's Avatar
Images: 23
Garage
Quote:
Thanks sullivancorner! Stuff like that is what makes this forum what it is.
PM sent.
-rAtTLeTrAp
Old 12-10-2012, 09:19 PM   #11
rattletrap
Check that P clamp!
rattletrap's Avatar
Images: 23
Garage
I had to see for myself, so I soaked a piece of that silicone in fuel overnight and it swelled like a sponge. I doubt that it would get that level of exposure being at the top of the throttle body, but it's still a poor choice for gasket material near fuel when there are better alternatives available. I checked Oreiley's and found a roll of the same stuff the stock one is made out of for $6, Felpro rubber-fiber. In a pinch this would do fine if the dealer didn't have one in stock, which is usually the case.
At least I got my dollar's worth out of that silicone for my pressure bleeder. That thing worked like a champ! After 6 years of service my fluid looked like mud.
-rAtTLeTrAp
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
