destroyer rebuild intervals - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Go Back   1130cc.com: The #1 Harley Davidson V-Rod Forum > Specific Model > VRXSE
Reply
Thread Tools Display Modes
Old 12-08-2012, 04:02 PM   #1
Tassie Phantom
Registered Full
Tassie Phantom's Avatar
Garage
Feedback Score: 0 reviews
how often are people freshening up destroyer motors, rings bottom end brgs etc?
Regards
Phantom
Best 60 ft = 1.358
Best 330 = 3.813
Best 1/8th = 5.911
Best ET = 9.461
Best MPH = 141.77
Tassie Phantom is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-08-2012, 10:28 PM   #2
TaxmanHog
Noel
TaxmanHog's Avatar
Images: 277
Garage
Feedback Score: 2 reviews
I'm no expert, but will relate what I experienced & plan to do, YMMV.......
2011 Season I made 176 passes, the rings were OK but I replaced them anyway, the heads got a clean up & light porting, I installed new MAP Sensor & Injectors, and finished the must do mechanical fixes to the tranny (V&H 2nd gear), had already done the clutch basket. Also changed the Secondary cam chains for good measure. Bearings are a must do once the case is split.
2012 Season I made 76 passes, I do not plan to pull the engine at all, I will be changing the Throttle Body, as I am concerned about the cross shafts breaking, the unit I have has been erratic with idle stability.
2013 Season I anticipate making at least 45 passes in a New England only race season, I'm not sure how many AHDRA races I'll make, but each event I make as many as 20 passes in a Friday to Sunday time frame. By the end of 2013 I will probably be at the point where I will pull it, might change the rods, rings and freshen the heads including valve guides. Inspect the tranny, might do an under cut
2006 VRXSE Destroyer
VRD-941 & ET-943
60: 1.393
ET: 9.661
Mph: 139.34
Check Your Grounds
TaxmanHog is offline   Reply With Quote
Old 12-09-2012, 04:56 AM   #3
Tassie Phantom
Registered Full
Garage
thanx taxman glad to see you got your times down.
Regards
Phantom
Best 60 ft = 1.358
Best 330 = 3.813
Best 1/8th = 5.911
Best ET = 9.461
Best MPH = 141.77
Old 12-09-2012, 03:00 PM   #4
dmfcavu
Lifetime Premium
dmfcavu's Avatar
Feedback Score: 1 reviews
2012 was my first year, bought the Destroyer in November, 2011. Prior owner said they had 34 passes on it since new. I had about 180 Racepak files downloaded, and I know I missed several. I would estimate I had at least 200 passes since buying it. That means at least 230, maybe as many as 250.
Interestingly, my quickest time was the last event of the year and I thought it might have been getting tired - an assumption based only on the number of passes on the engine.
Upon tear-down, Lou remarked the engine really looked good, the only problem being worn valve guides. In prior conversations with Lou, he mentioned having seen Destroyers with as many as 250 passes. That's probably the outer limit, or at least getting close.
What has your experience been?
DMFCAVU
AMRA VMOD Plate No. ONE!
In Pursuit of The World's Quickest & Fastest VROD
VMOD National Record Holder 1/8 & 1/4 Mile ET
5.417 & 8.631
2013 Manufacturers Cup Super Comp (8.90 Index) Champion
2013 Manufacturers Cup Pro Fuel Top 10 In Points
Pro Fuel Nitro Harley
Best ET - 7.32/180MPH
Best 60' - 1.18
Best Adrenaline Rush Ever!
AMRA Pro 6.90 Fuel Pilot
NHRA License PFH
dmfcavu is offline   Reply With Quote
Old 12-10-2012, 02:58 AM   #5
Tassie Phantom
Registered Full
Garage
thanx guys have about 140 passes on it not looking at pulling it down until june prob another 50 passes.
Regards
Phantom
Best 60 ft = 1.358
Best 330 = 3.813
Best 1/8th = 5.911
Best ET = 9.461
Best MPH = 141.77
Old 04-13-2013, 06:58 AM   #6
Tassie Phantom
Registered Full
Garage
pulled the motor down to freshen up with 140 odd passes, valve springs were well shot and an inlet cam was picking up a bucket, pistons ok, replaced rings and gave light hone, replaced shift forks and shafts as preventative measure, and installed v&h second gear, replaced big end and main brgs and rod bolts. picked up 7hp form before and after.
Regards
Phantom
Best 60 ft = 1.358
Best 330 = 3.813
Best 1/8th = 5.911
Best ET = 9.461
Best MPH = 141.77
Old 04-13-2013, 07:37 AM   #7
dmfcavu
Lifetime Premium
dmfcavu's Avatar
Great update Tassie, thanks.
DMFCAVU
5.417 & 8.631
Best 60' - 1.18
NHRA License PFH
Old 04-13-2013, 09:25 AM   #8
TaxmanHog
Noel
TaxmanHog's Avatar
Images: 277
Garage
Good news, now you can be rest assured during ~your~ off season that she is ready to go when it's time to resume racing!!
VRD-941 & ET-943
60: 1.393
ET: 9.661
Mph: 139.34
Check Your Grounds
Old 04-14-2013, 06:02 AM   #9
Tassie Phantom
Registered Full
Garage
no off season noel, tested today and killed a clutch race in sydney in 3 weeks, Brisbane in another 6 weeks and then I miss a couple of rounds before the sept and november rounds.
Regards
Phantom
Best 60 ft = 1.358
Best 330 = 3.813
Best 1/8th = 5.911
Best ET = 9.461
Best MPH = 141.77
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
