Bike Shut-off mechanisms - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Go Back   1130cc.com: The #1 Harley Davidson V-Rod Forum > V-ROD Discussions > V-ROD Technical
Reply
Thread Tools Display Modes
Old 12-08-2012, 11:05 AM   #1
FABSTER
GFYS
Images: 23
Feedback Score: 33 reviews
Question Bike Shut-off mechanisms
What kind of shut off mechanisms our bikes have (other than the lean angle shut off when the bike leans 45 degrees or more)??? Under which circumstances they come into play and shut off the bike while running?
Sponsored Links
Advertisement
Old 12-08-2012, 04:30 PM   #2
bwds
brett
bwds's Avatar
Images: 127
Feedback Score: 18 reviews
why ,lol.
bwds is offline   Reply With Quote
Old 12-08-2012, 04:43 PM   #3
HoneyB
Pat (Patrick!)
HoneyB's Avatar
Images: 14
Feedback Score: 31 reviews
Running out of gas would work!
Old 12-08-2012, 05:30 PM   #4
SteveRod 60
Registered Full
SteveRod 60's Avatar
Images: 9
Feedback Score: 0 reviews
Bike Shut off...
I'm not sure but once I was stuck in slow traffic, fans running and my bike would shut off, it would easily start again but it did this to me a couple of times that day and it hasn't done it again.
Is it possible they shut down to avoid over heating?
SteveRod 60 is offline   Reply With Quote
Old 12-08-2012, 07:24 PM   #5
RustyG
Lifetime Premium
RustyG's Avatar
Images: 99
Feedback Score: 11 reviews
Shouldn't ever get that hot. That's what the fans are for.
Regards,
John
Quote:
2007 VRSCX 0461 / 1400
2002 Road King Classic
Old 12-09-2012, 04:52 AM   #6
FABSTER
GFYS
Images: 23
Anyone has an idea if that might happen if the bike suddenly gets too lean/rich for some reason?
Old 12-09-2012, 04:55 AM   #7
ms700
Registered Full
if it gets toooo lean, and you are giving it large amounts, it would go bang.
ms700 is offline   Reply With Quote
Old 12-09-2012, 06:35 PM   #8
ELUSIVE 1
Lifetime Premium
ELUSIVE 1's Avatar
Feedback Score: 1 reviews
Quote:
Low octane watered down gas does it.
I'd rather be on my motorcycle thinking about God, then in church thinking about my motorcycle.
ELUSIVE 1 is offline   Reply With Quote
Old 12-15-2012, 11:10 AM   #9
TEAZZR
I Hate Stupid People
TEAZZR's Avatar
Quote:
WHAT DID YOU DO.....
2011 Muscle :
SE Stage II cams
58mm Destroyer TB
6.37 g/s Fuel inj.
Vance & Hines Comp. Slip-Ons
SEPST
K&N Cones - Topless
BOSS NOSS - Stealth system
TEAZZR is offline   Reply With Quote
Old 12-15-2012, 03:04 PM   #10
andrew1
Registered Full
andrew1's Avatar
My bike use to stall when i blipped the throttle. After taking the bike to the dealership, i got a custom tune and they replaced the throttle bodies.
Been fine ever since.
Im certain my problem was tuning all along
andrew1 is offline   Reply With Quote
Old 03-21-2013, 08:26 AM   #11
FABSTER
GFYS
Images: 23
Related thread I found here
http://www.1130cc.com/forums/showthr...53#post2632553
Old 03-21-2013, 09:13 AM   #12
stever975
Super Moderator
Images: 22
That thread concerns the BAS = bank angle sensor and your first post said you were interested in mechanisms other than this.
stever975 is online now   Reply With Quote
Old 03-21-2013, 09:17 AM   #13
FABSTER
GFYS
Images: 23
Quote:
I understand, I asked about any other mechanisms because I wanted to know if there where any other mechanism other than this. So is this the only factory shutoff mech on our bikes? Change in angle >45deg for more than 1 second? Thanks in advance for your help, much appreciated
Old 03-21-2013, 09:23 AM   #14
FABSTER
GFYS
Images: 23
FWIW this is my specific case:
Quote:
Same thing happens to me when I hit the nitrous and the bike is reaching top speed/rpm.... My mechanic needs to check it but he thinks it can also be the lean angle module cutting off. It happened to him when he raced his V-rod and he dumped the clutch while launching, the bike would shut off automatically apparently because of the sudden "shake". In my case I guess it might be a sudden "shake" while shifting or something, my other guess was some kind of lean/rich AFR shutdown mechanism the bike had but in my case the bike (05 SE) doesn't even have O2 sensors so I don't think such mechanism is even possible... The module is still in the stock location and no modifications have been made to the area where it's installed...
Old 03-21-2013, 09:57 AM   #15
stever975
Super Moderator
Images: 22
I understand, I asked about any other mechanisms because I wanted to know if there where any other mechanism other than this. So is this the only factory shutoff mech on our bikes? Change in angle >45deg for more than 1 second? ...
No, there's also two RPM limit engine shut-offs.
One is triggered if engine RPM hits about 7500 and the engine temperature is < 176 °F (80 °C).
The other is triggered by the RPM limit supplied by the ECM calibration file (usually set at 9100 or 9200 RPM).
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
