still popping on decel, after removing catalytic from exhaust - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Go Back   1130cc.com: The #1 Harley Davidson V-Rod Forum > V-ROD Discussions > V-ROD EFI
Reply
Thread Tools Display Modes
Old 12-03-2012, 04:55 AM   #1
Cossack
Registered Full
Cossack's Avatar
Images: 2
Feedback Score: 0 reviews
Have been reading a few posts on how to remove the decel popping. The problem started after removing the cat. conv. from the exhaust on my '10 DX, after believing that it'd be an slight improvement in running cooler and more responsive. The decel popping only occurs riding arround town etc. I did have it dyno'd again after the cat was removed, but no improvement.
I was told that " he is happy with the AFR line" and auto-tune? has been selected on my SEPST , and "hopefully it sort itself". It's been 4 weeks and NO better.
Topless, slip-ons ( with small baffles )
Any ideas that i should look at? Please be note that i've limited knowledge in tuning. Dyno results below
Name:	night rod 002.jpg
ID:	192024   Click image for larger version
Name:	night rod 003.jpg
Cossack is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-03-2012, 10:53 AM   #2
pgilliam1
Registered Full
pgilliam1's Avatar
Feedback Score: 1 reviews
- Put the CAT back on
- Put the OE mufflers back on
- Get a different tuner or new map for SEPST
Limited options here -
pgilliam1 is offline   Reply With Quote
Old 12-03-2012, 04:45 PM   #3
TEAZZR
I Hate Stupid People
TEAZZR's Avatar
there is no auto-tune available for the SEPST. The problem will not fix it self.
IMO put the top back on your air intake and see if it helps out alittle on the deceal popping. ( probably won't fix all of it ).
Then find a shop who knows what the F they are doing!!!
2011 Muscle :
SE Stage II cams
58mm Destroyer TB
6.37 g/s Fuel inj.
Vance & Hines Comp. Slip-Ons
SEPST
K&N Cones - Topless
BOSS NOSS - Stealth system
TEAZZR is offline   Reply With Quote
Old 12-03-2012, 05:23 PM   #4
rsc
Killer Service Inc.
rsc's Avatar
Images: 1
Garage
Feedback Score: 8 reviews
increase the fuel in the first row in the VE table for both cylinders.
Only try thi if you know what you are doing!!!!
2003 turbo
2012 Ultra Classic
V-rod mechanics 101:
Old 12-03-2012, 06:46 PM   #5
VRSCSE RIDER
Registered Full
Thats what I did on my PCIII no more Decel popping...0 Throttle Position up to 5K RPM add 20%...
VRSCSE RIDER is offline   Reply With Quote
Old 12-04-2012, 06:48 PM   #6
swtalbot
She f...in Hates me!
swtalbot's Avatar
Images: 7
Feedback Score: 6 reviews
Quote:
I had the same problem after my dyno tune. It needs more fuel when the throttle is closed and you are decelerating.
With fuel injection on an engine that has open loop control. (an engine without oxygen sensors) the injectors go to an idle fuel position when you close the throttle. If you are still moving and in gear the fuel air mixture goes very lean! Way above 14 to 1 and the exhaust pops. On closed loop systems the oxygen sensors sense this condition and adjust the fuel automatically. On bikes without sensors you need to increase the fuel when the rpm is above idle (make it richer) and the problem is gone. Your dyno tune graph shows the reason it pops. To lean at low throttle positions. Just try and increase the throttle a little bit when decelerating and the problem will go away. This proves it needs more fuel.
Quote:
I believe the D model is one of the finest VRSC models to date!
2006 Night Rod
PC III, K & N filter
Forward controls
5 Gallon UE tank
Vance & Hines Double Barrel Exhaust
200 Metzler, Progressive 440 rears
Custom swing arm pivot caps By Superchicken
Custom Derby And Clutch cover from Superchicken
swtalbot is offline   Reply With Quote
Old 12-05-2012, 04:03 AM   #7
Cossack
Registered Full
Cossack's Avatar
Images: 2
Thanks for the ideas, when riding in the hills etc. the decel popping has gone. My guess is what you guys have been saying, add small amounts of fuel down low. I will go back to my original place to do the dyno...
Old 12-05-2012, 04:15 AM   #8
Louis
Posting From The Pub
Louis's Avatar
Images: 3
Feedback Score: 5 reviews
Dyno runs just show what happens at max throtte, so I don't see what thy have to do with anything.
If you remove the cat there will be two results - very slightly better airflow, which means the bike runs very slightly leaner, so needs very slightly richening, ansd there is less restriction down the pipe so the sound of fuel burning in the pipe (AKA decel popping) will be more audible.
So, options:
1) The change is very small, so the popping should be too. If it is loud enough to worry about then it is probably an air leak at the headers. Are they tight?
2) If the flow is better, maybe your tuner should be adding a bit of fuel to the map? Never mind the high end.
3) If you really want to tune out decel popping, you need to try adding (normally) or subtracting (less usually) fuel on the decel settings and the 0% throttle positions in the SEPST. However, I am surprised this is needed just for CAT removal. An air leak seems more likely to me.
Anyone else removed a cat?
Louis
Arnotts, D&D, SEPST, custom paint or all chrome according to mood, GRC seat, wave rotors, Muscle wheels, Burleigh bars, V-Gauge, assorted pretty bits.
2007 VRSC-AW (Fun).
2007 KTM 990 Adventure (Off Road and Touring).
2006 Triumph Daytona T955i (Evil).
2009 Fatboy (Heavily Tarted Up Show Pony).
2011 Bonneville (On long term loan).
1978 Triumph Bonneville Based Racer (Needs A Rebuild)
Louis is offline   Reply With Quote
Old 12-16-2012, 04:53 AM   #9
Cossack
Registered Full
Cossack's Avatar
Images: 2
Thanks Louis, i have altered the baffles slightly. They did have a 20mm hole in the ends. I drilled them to 26mm and added two extra 11mm holes around the outside of the baffles. This, with removal of the cat has the bike just right, sound wise.
I'll have another look at the headers. Do you know what they need to be torqued to?
Old 12-20-2012, 05:31 AM   #10
V8SUPERSTAR
Registered Full
V8SUPERSTAR's Avatar
i drilled out my cats completely, and have same problem, with v+h comp slip ons.
loud popping after let go of throttle both in town and on highway
V8SUPERSTAR is offline   Reply With Quote
Old 01-06-2013, 09:00 AM   #11
SvFiat
Kidzap
Images: 2
In your map you have a decel enleanment setting. Decrease the numbers in that chart by 10% at a time till the popping stops.
Have Fun :SvFiat
SvFiat is offline   Reply With Quote
Old 01-26-2013, 02:38 AM   #12
Cossack
Registered Full
Cossack's Avatar
Images: 2
dropped the bike to Aldo at peter stevens and told him about the issues. Had it sorted in no time. Like you guys said, he added more fuel. No gains in removing the cat power wise, but i reckon bike runs a little cooler.
Old 02-11-2013, 04:59 PM   #13
FatbyRR
Registered Full
Feedback Score: 2 reviews
Quote:
as an old calibrator, I can tell you it's better to add the fuel in the VE tables. Decel enleanment is "active" with every negitive delta throttle. So you would add "more" fuel every time you decrease throttle with decel enleanment. DE is just like AE it accounts for delta changes in throttle and the associated tranport lag times for scheduled fuel vs. actual throttle (manifold filling ) effect.
VE's will help the over run condidtions without hitting all those points under "normal" throttle operation.
FatbyRR is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
