rear brake failure - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Reply
Thread Tools Display Modes
Old 11-29-2012, 11:21 AM   #1
JmpMstr
Registered User
Feedback Score: 0 reviews
rear brake failure
Have an 04 VRSCB w/ 8500 miles. brakes worked no pronblem. Parked in my garage for 2 weeks while in Iraq and reurned to find the rear brake and brake light don't work. I have found no leaks or melted wires. Any recommendations?
JmpMstr is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-29-2012, 12:02 PM   #2
matt2007
Registered Full
I would try and bleed it the old fashion way to see if the master cylinder is working.Then do it by vacuum and check again and see if it is pumping.Hows the pedal feel?Look carefully around the brake switch and frame.The fluid runs along the bottom cross member and to the left side of the bike,very hard to spot.It also seems to suck air into the system more than lose fluid.The fluid level looked ok on mine so dont go by that.The switch wasn't designed to be so close to the exaust(heat)and leaks from the terminal connections when it fries.Mine went at 8000 miles.The brake light/pressure switch wont work either if the master cylinder is bad.
matt2007 is offline   Reply With Quote
Old 11-29-2012, 12:05 PM   #3
JmpMstr
Registered User
No pressure in petal at all. Agreed the heat is an issue and need to climb all over it when cool. Nothing happened that would result in failure other than sitting. Thanks for the quick reply.
Old 11-29-2012, 06:07 PM   #4
matt2007
Registered Full
Then either theres air in the system or the master cylinder is shot.Try bleeding it.
Old 11-30-2012, 01:30 PM   #5
Rich Moran
Riding the good life
Rich Moran's Avatar
Images: 191
Feedback Score: 2 reviews
The brake light switch may be the culprit.
This is a known problem with the V Rod, where the fluid gets past the hydraulic switch, leaks out and because of the location you do not see fluid anywhere.
If you find this to be the problem be sure to report it to the NHSTB I think it is as this problem is caused (if this is the case with your switch) by defective part used by Harley.
If you go to the dealership and this is th eproblem they will advise "we change these out all the time because they fail".
And yet to date no recall notice to anyone about it.
Recall to harley is a four letter word.
Member Number 433 or there abouts...original old timer
Rich Moran is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
