help dot 5 - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Reply
Thread Tools Display Modes
Old 11-25-2012, 01:30 PM   #1
italianrick
Registered Full
italianrick's Avatar
Images: 1
Garage
Feedback Score: 0 reviews
help dot 5
Ok i did my rear brakes today. My son in law came out and asked if he could help i said sure put a little brake fluid in . He did and it was dot 5. After he put a capful in he told me the fluid he put in was purple and the fliid in the master cylinder was not it was a dark clear. Its my fault for not checking. But the cover said dot 5 so i assumed it was dot in it . My question will only a cap full cause me problems.? Or should i remove all the fluid out of the resivior. I have not used the rear brake peddel at all.
italianrick is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-25-2012, 01:57 PM   #2
VrodG
Greg/Moderator
VrodG's Avatar
Images: 26
Feedback Score: 8 reviews
New Dot 5 is purple.
VrodG is offline   Reply With Quote
Old 11-25-2012, 03:45 PM   #3
swtalbot
She f...in Hates me!
swtalbot's Avatar
Images: 7
Feedback Score: 6 reviews
From Wikipedia
DOT 5 is a silicone-based brake fluid (contains at least 70% by weight of a diorgano polysiloxane[1]).
Unlike polyethylene glycol based fluids, it is hydrophobic. Its chief advantage over other forms of brake fluid is that silicone exhibits a more stable viscosity index in extreme temperatures. It is widely used in the antique automobile arena as well as it does not damage paint.
Using DOT 5 in a DOT 3 or DOT 4 system without proper flushing will cause damage to the seals and cause brake failure. DOT 5 brake fluid is not compatible with anti-lock brake systems. DOT 5 brake fluid absorbs a small amount of air requiring care when bleeding the system of air.
Quote:
I believe the D model is one of the finest VRSC models to date!
2006 Night Rod
PC III, K & N filter
Forward controls
5 Gallon UE tank
Vance & Hines Double Barrel Exhaust
200 Metzler, Progressive 440 rears
Custom swing arm pivot caps By Superchicken
Custom Derby And Clutch cover from Superchicken
swtalbot is offline   Reply With Quote
Old 11-25-2012, 03:54 PM   #4
rattletrap
Check that P clamp!
rattletrap's Avatar
Images: 23
Garage
Feedback Score: 12 reviews
If the cover says Dot5, it was most likely Dot5 in there already. It just loses it's color and gets nasty looking with age. A little fresh stuff in there won't hurt, but it's a good idea to just flush the system if it doesn't look clean and purple. Especially if you haven't done it before and you have any doubts about what was in there.
-rAtTLeTrAp
Running without hills is like motorcycling without corners.
“Go out and preach the Gospel, and if you have to, use words.”
rattletrap is offline   Reply With Quote
Old 11-25-2012, 03:57 PM   #5
capngeo
George
capngeo's Avatar
Images: 163
Feedback Score: 10 reviews
Quote:
^^^^^^^ There, Sir is the correct answer^^^^^^^^^
Prices on
are Negotiable!
____________________________________________
The World's ONLY "
" V-Rod
Ol' Bubba, Popes of Hell MC
You start the game of life with a full pot o' luck and an empty pot o' experience...
The object is to fill the pot of experience before you empty the pot of luck
capngeo is offline   Reply With Quote
Old 11-25-2012, 04:29 PM   #6
rattletrap
Check that P clamp!
rattletrap's Avatar
Images: 23
Garage
You can flush the system quick and easy with a DIY pressure bleeder. The real deal by Max isn't being sold here anymore, but you can build your own for about $30 with stuff from Home Depot.
Here's a link to what I'm talking about.
www.1130cc.com/forums/showthread.php?t=42544
Does anyone know what happened to Max's video that shows it in action?
-rAtTLeTrAp
Old 11-25-2012, 06:18 PM   #7
italianrick
Registered Full
Images: 1
Garage
thanks for all info. I am going to flush entire system since as long as i owned this bike it has not been done, Bike is an 02A and probably has never been done
Old 11-25-2012, 06:32 PM   #8
swtalbot
swtalbot's Avatar
Images: 7
If it has never been done than the oil was dot 4. That is what was put in at the factory. Referring back to my other post Dot4 and dot5 are not compatible with each other. Dot 4 is a polyethylene glycol based fluid. Dot 5 is a silicone-based fluid. The only other difference is the boiling point.
2006 Night Rod
Forward controls
5 Gallon UE tank
Old 11-25-2012, 09:32 PM   #9
pwrman
Registered Idiot
pwrman's Avatar
Err on the side of caution, complete flush and refiil
pwrman is offline   Reply With Quote
Old 11-26-2012, 04:08 AM   #10
SvFiat
Kidzap
Images: 2
Feedback Score: 1 reviews
If your going to flush your hydraulics in your brakes and clutch you might as well refill with DOT 5.1 as it's a better version of DOT 4.
Have Fun :SvFiat
SvFiat is offline   Reply With Quote
Old 11-26-2012, 08:24 AM   #11
Elgavilan
The Hawk
Elgavilan's Avatar
Images: 21
Feedback Score: 14 reviews
Quote:
The factory used Dot 5 in the early bikes, I'm not sure exactly when they changed to Dot 4 but my 2003 requires Dot 5.
Mike
It's not how fast you go, it's how fast you get there!
Elgavilan is offline   Reply With Quote
Old 11-26-2012, 08:58 AM   #12
rc4man
EXCELSIOR
rc4man's Avatar
Feedback Score: 4 reviews
They switched to DOT 4 with the Brembo braked bikes.
DOT 5 as other types will yellow or brown as it ages, it was explained once to me as being like poop, it all goes in different colors but all comes out brown. If yours looks that way it just needs flushing. Do it and you'll appreciate the improvement.
"V" Rod Forman, '04 Anodized "B", 50th B-day gift from wife.
rc4man is offline   Reply With Quote
Old 11-26-2012, 11:18 AM   #13
FABSTER
GFYS
Images: 23
Feedback Score: 33 reviews
Anyone other than VrodG using Dot 5 on Brembo calipers?
Old 11-26-2012, 12:20 PM   #14
stever975
Super Moderator
Images: 22
Quote:
I am, but not the HD calipers. I use DOT 5 fluid in Brembo model P4 34/34 (these are 4 piston / 4 pad calipers like those used for front calipers on the Ducati 998).
stever975 is offline   Reply With Quote
Old 11-26-2012, 03:52 PM   #15
vroder
Blowin' Smoke
vroder's Avatar
Images: 6
Um, not to argue, but my '02 came from the factory with DOT-5 in the brakes and clutch. I've since changed the fluid, staying with DOT-5, and have had no issues with the brakes, or clutch.
Independent "A" owner
vroder is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
