Chain Drive Tips Wanted - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Go Back   1130cc.com: The #1 Harley Davidson V-Rod Forum > V-ROD Discussions > V-ROD Racing
Reply
Thread Tools Display Modes
Old 11-16-2012, 05:53 AM   #1
Aus-rodder
Quarter Miler
Garage
Feedback Score: 0 reviews
Question Chain Drive Tips Wanted
I'm running an almost stock 2006 VRSCD. Modded pipes, topless, K&N high flow filter & a PC3.
Internals are stock, no cam work, etc.
Still running stock gearing (30 tooth front pulley) .
I did buy a 26 tooth pulley but it won't fit my bike
Currently running the 1/4 in 11.6 crossing the line at 118mph.
Looking to change to chain drive to reduce the gearing. Hoping this will get my 60' times down and cut a few tenths of my ET.
Any tips on what sprockets I should be running front and rear on a near stock 1130?
Don't mind if it becomes unsuitable for long hauls. I have two other Harleys for daily riding and cruising.
The Night Rod is mainly ridden to, from and down the track.
Willowbank Dragway Street Bike Champion 2012
2005 XL1200C sporty
2008 FXDL Low Rider
2006 VSCRD Night Rod
PC111, K&N Filter (no airbox)
Ultima forks
Ikon Shocks
Rick's Long Range Tank
Drag Bars
Speedin' Emu Mufflers
[SIGPIC][/SIGPIC]
Ride it like your ex-wife's lawyer is after you!
Aus-rodder is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-16-2012, 09:17 AM   #2
swampboogiedoug
Registered Full
swampboogiedoug's Avatar
Feedback Score: 11 reviews
When you say the 26T won't fit, why ? There is some clearanceing necessary and possible belt swap, depending on tooth count on your current one. What are you'e 60' times now ! My personal suggestion is stick with the belt, stronger, lighter, less maintenance. The only ones who need chain are full time racers that need to adjust gearing at multiple tracks each weekend. That doesn't sound like you.
swampboogiedoug is offline   Reply With Quote
Old 11-16-2012, 09:35 AM   #3
LL Cool K
Insane inda membrane
LL Cool K's Avatar
Images: 161
Feedback Score: 5 reviews
Trask now makes a rear wheel adapter for V-Rod wheels to convert to chain drive.
If you see da Police
Warn A Brother!
In loving memory of Betty Boost! 1929-1996
Winner of the 2012 Midwest Thunder7 Johnny Hotfoot Award... Best Rat Bike!
LL Cool K is offline   Reply With Quote
Old 11-16-2012, 12:49 PM   #4
big rich
JESUS IS LORD
big rich's Avatar
Feedback Score: 4 reviews
My Brother has a kit check www.vreelandsharley.com in the V-Rod parts section.
"GOD is good all the time"
LET'S RACE
big rich is offline   Reply With Quote
Old 11-16-2012, 02:06 PM   #5
Aus-rodder
Quarter Miler
Garage
Quote:
Originally Posted by swampboogiedoug View Post
When you say the 26T won't fit, why ? The internal diameter of the 26 tooth pulley is too small to fit over the drive shaft housing. There is no way the pulley can be machined to fit, there's just no excess metal to take out.
There is some clearanceing necessary and possible belt swap, depending on tooth count on your current one. I bought a shorter belt to suit with the 26T pulley.
What are you'e 60' times now ! Running 1.9 sometimes a high 1.8
My personal suggestion is stick with the belt, stronger, lighter, less maintenance. Tried going down that path. Am out of pocket a pile of cash and have nothing to show for it but some spare parts hanging on the wall of the workshop.
The only ones who need chain are full time racers that need to adjust gearing at multiple tracks each weekend. If I go chain drive and need to fine tune ratios, it is a very affordable option to grab another sprocket with a different tooth count. Not so with belt drive. There are a gazillion ratios available for chain drive. With belt drive the options are limited. Extremely limited if one doesn't live in the States.
That doesn't sound like you. This is my race bike. Street registered so I can ride it to the track but purchsed solely to be my drag bike.
2005 XL1200C sporty
2008 FXDL Low Rider
Ultima forks
Ikon Shocks
Drag Bars
[SIGPIC][/SIGPIC]
Old 11-16-2012, 02:09 PM   #6
Aus-rodder
Quarter Miler
Garage
Thanks for the replies guys but I already know where to buy the parts.
Looking for guidance from someone who's gone chain drive as to what ratio to try for starters.
I'm thinking 21 front & 58 rear. ????????
2005 XL1200C sporty
2008 FXDL Low Rider
Ultima forks
Ikon Shocks
Drag Bars
[SIGPIC][/SIGPIC]
Old 11-16-2012, 04:02 PM   #7
2oo6niterod
drag racer
2oo6niterod's Avatar
Images: 8
Feedback Score: 22 reviews
thats a good start. ncvrodracer has went to a chain and i think thats his gearing. send him a pm, he ain't here a lot but will gladly help you. tell him robbie sent you.
1998 Farmington Dragway Street Car Champion 83 Impala
2009 Farmington Dragway Motorcycle Champion 06 VRSCD
2013 Manufactures Cup Super Comp 8.90 Champion Crew Chief 06 Destroyer
2005 XL1200C / 98 GSXR 1268 5.60 no bar bike.
<<<<-----fuel management
<<<----shift lights
2oo6niterod is offline   Reply With Quote
Old 11-18-2012, 04:27 AM   #8
Aus-rodder
Quarter Miler
Garage
Many thanks Robbie, I'll send him a PM.
2005 XL1200C sporty
2008 FXDL Low Rider
Ultima forks
Ikon Shocks
Drag Bars
[SIGPIC][/SIGPIC]
Old 11-18-2012, 10:07 AM   #9
tellis0721
Registered Full
I purchased my chain setup through vreelands hd i went with a 19 t front 54 t rear it gave me a 2.84 gear ratio 21/58 gives you a 2.76 ratio which is the same as 26t front pulley belt setup divide your rear sprocket teeth by your front sprocket teeth gives you your gear ratio i think noel on here has a spread sheet on this
Sent from my myTouch_4G_Slide using Motorcycle.com Free App
tellis0721 is offline   Reply With Quote
Old 11-18-2012, 11:10 AM   #10
TaxmanHog
Noel
TaxmanHog's Avatar
Images: 277
Garage
Feedback Score: 2 reviews
For those interested in Gearing variations, try this tool, very useful !!!
http://gearingcommander.com/
2006 VRXSE Destroyer
VRD-941 & ET-943
60: 1.393
ET: 9.661
Mph: 139.34
Check Your Grounds
TaxmanHog is offline   Reply With Quote
Old 11-18-2012, 01:57 PM   #11
Aus-rodder
Quarter Miler
Garage
Quote:
Many thanks.
Any reason for smaller srockets front and back in preference to the same ratio using 21 tooth front? Better clearance somewhere perhaps?
2005 XL1200C sporty
2008 FXDL Low Rider
Ultima forks
Ikon Shocks
Drag Bars
[SIGPIC][/SIGPIC]
Old 11-18-2012, 02:01 PM   #12
Aus-rodder
Quarter Miler
Garage
Thanks Noel,
That Gearing Commander is awesome!
It will certainly resolve a few arguments in the racing team b/s sessions.
2005 XL1200C sporty
2008 FXDL Low Rider
Ultima forks
Ikon Shocks
Drag Bars
[SIGPIC][/SIGPIC]
Old 11-19-2012, 06:53 AM   #13
tellis0721
Registered Full
There is no real reason for smaller sprockets over larger diameter ones a 19t front sprocket would be smallest i would go anything smaller in front would possibly put the chain in a bind and or contact the swingarm also with the vrod swingarm there is not much adjustment depending on sprocket sizes will affect how many links you cut off the chain and have enough adjustment in the swingarm to adjust the slack out of the chain
Old 11-20-2012, 06:40 AM   #14
FABSTER
GFYS
Images: 23
Feedback Score: 33 reviews
Quote:
This is my race bike. Street registered so I can ride it to the track but purchased solely to be my drag bike.
You can also get some Stage 2 cams in there and you'll love the improvement, a couple bucks more than the chain conversion but well worth the expense
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
