Motorcycle lift use? - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Reply
Thread Tools Display Modes
Old 11-12-2012, 04:42 PM   #1
Sled Dog
Registered Full
Sled Dog's Avatar
Feedback Score: 0 reviews
Another newbie question. My 3rd of the night and you guys are batting 1000!!!!! How do I use this Craftsman lift? I can guess go under bike with lift and lift... But what supports it? I also have some straps that came with it ( its a friends). Where do they go? A picture would be great. Thanks again for the help.
Sled Dog is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-12-2012, 05:56 PM   #2
langwilliams
Registered Full
simple...roll it under the bike, center it on the frame between the radiator an swing arm. Roll it under it will probably hit the left side frame. Just pull the bike up straight of the side kick stand. Slowly pump it up until it makes contact with the bike. Make sure there's a few inches of lift pad is showing on both sides. Slowly pump some more an see how balanced it feels. you can lower it an move it forward or back to balance it then repeat. then pump it up an make sure the safety lock on the jack engages.
langwilliams is offline   Reply With Quote
Old 11-12-2012, 05:58 PM   #3
langwilliams
Registered Full
read the directions on lowering it. I think different brands work differently. With My cheap harbor freight you have to quickly push the lowering pedal with your foot to lower it slowly. If you push it slowly the bike will drop like a rock. backwards I know. Make sure the kick stand is down an you're hold the handbars firmly while lowering.
Old 11-12-2012, 06:29 PM   #4
HoneyB
Pat (Patrick!)
HoneyB's Avatar
Images: 14
Feedback Score: 31 reviews
For the straps, I lift my seat to put one strap across, And put the other over the frame, near the battery. My air box is off, of course.
Old 11-12-2012, 06:57 PM   #5
RustyG
Lifetime Premium
RustyG's Avatar
Images: 99
Feedback Score: 11 reviews
I strap my bike down with one strap over the lower frame rails in front of the engine. Just make sure you don't "pinch" wires or brake lines.
The second strap wraps around the left passenger foot peg.
Regards,
John
Quote:
2007 VRSCX 0461 / 1400
2002 Road King Classic
Old 11-12-2012, 09:37 PM   #6
langwilliams
Registered Full
i don't strap it down unless I'm doing a job where it will be unattended while on it. When I rebuilt the tranny in my shovelhead I bolted two 2x8" to it with 2x4 bracing securing them together. I also used jack stands under the ends to stablize it. Made a nice work bench while doing a major job.
Old 11-13-2012, 09:53 AM   #7
FastVRJohnny
Images: 13
BE VERY CAREFUL WHEN YOU TURN THE HANDLE TO RELEASE PRESSURE!!!!! If you don't do so slowly, the bike will literally drop like it fell out of the sky. There's been a few members hurt by the Sears lift, thank God, I'm not one of them.
Also, the lift locks in a few different places. So when you release the pressure to lower, it may seem stuck before lowering all the way. Put pressure on the lift and unlock the lever by lifting it up.
FastVRJohnny is offline   Reply With Quote
Old 11-13-2012, 09:58 AM   #8
FastVRJohnny
Images: 13
If you try to center the bike with the kickstand down, it gets in the way. By sitting on the bike with stand up, you'll find true center pretty easy. Be sure the lift is all the way under the bike or she'll tip off the lift.
Like others have said, use the straps with the airbox off.
Old 11-13-2012, 10:32 AM   #9
luxlamf
Sanctimonious
luxlamf's Avatar
Images: 105
Feedback Score: 2 reviews
always keep the jiffystand DOWN!!
I Ride My Bike To Trailer Rallies.
luxlamf is offline   Reply With Quote
Old 11-13-2012, 10:49 AM   #10
FastVRJohnny
Images: 13
I never do, too hard to center and too hard to get at the oil drain plug. If the bike falls off the lift, the stand isn't going to do you any good. If you use the straps, you'll never have an issue.
Old 11-13-2012, 12:49 PM   #11
harleynurse
caferacer
harleynurse's Avatar
Images: 30
Feedback Score: 27 reviews
Call me over cautious or deviating from the conventional norm, but I'm planning to hang top front and rear pulleys/straps from the workshops rafters, while VRod is on the lift. When I work alone,I drink and burn Thai stick incense.....objects tend to get TiPsY.
cafe-racer ,LANE~SPLITTER. Century rider x5.
07 NRS~ California with over 50,000 miles.
07 NRS~ "SOLD"..Nevada with over 50,000 miles.
03VRSCA "SOLD" after 50,000 miles.
harleynurse is offline   Reply With Quote
Old 11-13-2012, 01:18 PM   #12
FastVRJohnny
Images: 13
I do that with my Buells. With the underslung exhaust, I can't use the Sears lift. I have a set of PitBull stands, but those are never enough.
Old 11-13-2012, 01:45 PM   #13
luxlamf
Sanctimonious
luxlamf's Avatar
Images: 105
Oil changes: I raise the bike up as HIGH as it will go, strap it to the lift, open drain plug and remove old filter, when "Done" draining I then lower the bike to the middle height on jack strap it down again and lift the rear tire until the front tire touches the ground to drain the rest of the oil out.
Old 11-13-2012, 01:49 PM   #14
FastVRJohnny
Images: 13
Why don't you just use the medium height for everything?
Old 11-13-2012, 01:50 PM   #15
ELUSIVE 1
Lifetime Premium
ELUSIVE 1's Avatar
Feedback Score: 1 reviews
Quote:
But first spin it around the block to warm up the motor.
I'd rather be on my motorcycle thinking about God, then in church thinking about my motorcycle.
ELUSIVE 1 is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
