Where would it be? - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Go Back   1130cc.com: The #1 Harley Davidson V-Rod Forum > V-ROD Discussions > V-ROD EFI
Reply
Thread Tools Display Modes
Old 11-12-2012, 06:04 AM   #1
Waterfreak66
Registered Full
Waterfreak66's Avatar
Images: 2
Feedback Score: 3 reviews
Where would it be?
I need to determine if this bike I recently bought has Ny sort of tuner on it. It has a CFR pipe so one would think there would be. Where would I look on the bike to find one if the PO did in fact install something?
Sent from my iPhone using Motorcycle.com Free App
Waterfreak66 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-12-2012, 07:27 AM   #2
pgilliam1
Registered Full
pgilliam1's Avatar
Feedback Score: 1 reviews
The PO may not have installed a tuner just for pipes. Take off the air box cover and see if they installed a free flow air filter. You'll most likely see a tuner in the air box or by the battery.
pgilliam1 is offline   Reply With Quote
Old 11-12-2012, 08:37 AM   #3
Waterfreak66
Registered Full
Images: 2
Had the air box open to pull the top off this weekend but didn't notice any tuner around there.
Old 11-12-2012, 08:49 AM   #4
pgilliam1
Registered Full
pgilliam1's Avatar
Depending on what model year bike you have, it may be under the pillon seat. If the PO didn't install a high flow air filter he probably didn't install a tuner. These bikes are very air flow restricted in stock form. Both the intake snorkel and OEM air filter are restrictive. Do not install a high flow air filter without a tuner. These bikes run way too lean on factory settings and will run even leaner if you open the exhaust and air flow without increasing gas flow.
Old 11-12-2012, 09:08 AM   #5
Louis
Posting From The Pub
Louis's Avatar
Images: 3
Feedback Score: 5 reviews
The engine management system has probably been flashed, either with a proper dyno tune or a stage one flash. If there is a tuner it will be close to the EMS and there will be a shot, thick wire with a big plug between the two.
Most likely a "stage 1" flash by the dealer, which will be good enough if it seems to run right.
Louis
Arnotts, D&D, SEPST, custom paint or all chrome according to mood, GRC seat, wave rotors, Muscle wheels, Burleigh bars, V-Gauge, assorted pretty bits.
2007 VRSC-AW (Fun).
2007 KTM 990 Adventure (Off Road and Touring).
2006 Triumph Daytona T955i (Evil).
2009 Fatboy (Heavily Tarted Up Show Pony).
2011 Bonneville (On long term loan).
1978 Triumph Bonneville Based Racer (Needs A Rebuild)
Louis is offline   Reply With Quote
Old 11-12-2012, 10:56 AM   #6
Waterfreak66
Registered Full
Images: 2
It seems to run pretty well. Hard to say for sure though as this is my first vtwin. I do notice popping on decel and on occassion under hard throttle there is like a slight miss probably somewhere around 4k rpms. I noticed it like three or four times now. Inside of pipe is black which seems to indicate it running rich. I pulled off the air box lid to see if that leans it out a bit. It could also have a cam for all I know. Seeps pretty lopey, but again, first vtwin.
Old 11-14-2012, 04:54 AM   #7
Waterfreak66
Registered Full
Images: 2
Do you have to have an aftermarket tuner in order to have the ecu tuned on a portable dyno?
Old 11-15-2012, 04:37 AM   #8
Louis
Louis's Avatar
Images: 3
No. There are two ways basic ways of tuning the bike:
1) A piggy back tuner, which intercepts the bike's own engine management system instructors to the fuel injectors and changes them.
2) Changing the maps in the bike's own engine management system.
Within 1) you can have systems that try and tune themselves, or systems you tune on a dyno or by crossing your fingers and using someone elses map.
Within 2), you can:
a) Get the dealer to put one of a range of pre-rolled tunes on via their "digital technician". This costs very little.
b) Use Harley's own interface, called a SEPST. This is a $20 interface on most bikes for which Harley charge you an outrageous $500. It is locked to one bike. If this had been used on yours it should have been given to you. You still need either a dyno run or some kind of fuel ratio logging tool like a Twinscan. There is a sort of SEPST clone called the Mastertune which is better and a bit cheaper, but the dealer may be unfamiliar with it.
c) Use Dynojet's new Power Vision. This does all sorts of clever things and in my view makes the SEPST obsolete. You can add the Autotune module to do your own tune.
I would guess yours has had a Stage 1 flash. The bikes run rather lean around 4K. You are probably going the wrong way leaning it off. If it seems the previous owner has put some miles on it, and it runs OK, and you don't want to spend a packet, I would leave well alone. If it has few miles, feels a bit off, and you have spare cash, I'd get a Power Vision and autotune module and have fun fiddling.
I'm assuming a fairly late model (08+) bike.
Louis
2007 VRSC-AW (Fun).
Old 11-15-2012, 05:30 AM   #9
Waterfreak66
Registered Full
Images: 2
Thanks for all the information Louis! It's actually an '05 VRSCA. Not sure how that impacts your analysis.
Old 11-15-2012, 05:47 AM   #10
Louis
Louis's Avatar
Images: 3
It means the autotune stuff probably won't work on the exhausts you have, because there are no holes for the probes. You can cut/weld in holes, but it is a pain. It also means, I think, that if it has been tuned with the tool Harley sells to end users, it will be a SERT, not a SEPST (someone else might like to check the dates on that, I came in in 2007).
So I'd say if it works leave well alone, and if you have problems, ebay for a Power Commander III and get a basic dyno run.
Louis
2007 VRSC-AW (Fun).
Old 11-15-2012, 06:20 AM   #11
Waterfreak66
Registered Full
Images: 2
Makes sense. Thanks a bunch!
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
