Will a speedo from a 07 work on a 02 - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Go Back   1130cc.com: The #1 Harley Davidson V-Rod Forum > V-ROD Discussions > V-ROD Technical
Reply
Thread Tools Display Modes
Old 11-07-2012, 10:31 AM   #1
Giovaniele
Garage
Feedback Score: 0 reviews
Smile Will a speedo from a 07 work on a 02
Just wondering if a 07 cluster will work on a 02 bike the part number of the 07 is 67453-07A .. Thank you !!!
Giovaniele is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-07-2012, 11:18 AM   #2
stever975
Super Moderator
Images: 22
Feedback Score: 1 reviews
Quote:
Originally Posted by Giovaniele View Post
Just wondering if a 07 cluster will work on a 02 bike the part number of the 07 is 67453-07A ......
From what I've read here on the forum, yes, electrically it should work, however; that P/N is for the VRSCD/DX/X bikes and so you'll have some problem fitting this IM in a VRSCA IM housing (for one thing the reset switch won't line up with the hole in the housing).
stever975 is offline   Reply With Quote
Old 11-07-2012, 11:29 AM   #3
VrodG
Greg/Moderator
VrodG's Avatar
Images: 26
Feedback Score: 8 reviews
Steve I installed my 03 cluster in a 08 DX housing housing without any problems.
VrodG is offline   Reply With Quote
Old 11-07-2012, 11:54 AM   #4
stever975
Super Moderator
Images: 22
Quote:
I think that's because the reset switch for the VRSCA isn't part of the IM so you can position the switch to fit through the hole in the D/DX/X housing. The reset switch for the D/DX/X is attached to the IM and cantilevered towards the back. I'm pretty sure it won't line up with the hole in the VRSCA/AW lower cover.
Old 11-07-2012, 12:37 PM   #5
VrodG
Greg/Moderator
VrodG's Avatar
Images: 26
maybe I'm missing the point but the 03 cluster has the button attached to the cluster just like the 08 cluster.
You know I'm a little slow.
Old 11-07-2012, 12:42 PM   #6
pecee
Registered Full
pecee's Avatar
Feedback Score: 4 reviews
you are correct.
pecee is online now   Reply With Quote
Old 11-07-2012, 01:12 PM   #7
VrodG
Greg/Moderator
VrodG's Avatar
Images: 26
Quote:
Originally Posted by pecee View Post
you are correct.
about being slow?
Old 11-07-2012, 01:12 PM   #8
Giovaniele
Garage
Thanks for the info !!
Old 11-07-2012, 01:12 PM   #9
stever975
Super Moderator
Images: 22
If what you say is true then I guess there's no problem with swapping either way.
The parts catalog shows a distinct difference between three different configurations so I figured there had to be some reason the parts catalog indicates that some IMs will fit the VRSCA/AW, others will fit VRSCD/DX/X, and a third type that will fit the VRSCR.
Old 11-07-2012, 01:21 PM   #10
VrodG
Greg/Moderator
VrodG's Avatar
Images: 26
Steve its been a while since I had the 03 cluster in my hand but I think the button is attached . I have a -08 cluster setting on my desk so I know I'm right about that one. Now I did have to add 4 nut-serts to the back of the 03 cluster to be able to bolt it to the 08 b risers. When HD changed to the new fuel guage that might account for another change. Yes the R AND F cluster are another issue.
Old 11-07-2012, 01:41 PM   #11
stever975
Super Moderator
Images: 22
It's been a while since I removed mine also (and it's a pain to remove and install because I've added some things inside the cover) but the 2007 parts catalog pictures show a cantilevered reset switch on the IM for the VRSCD/DX/X and none on the IM for the VRSCAW (I guessed it was separate and attached by wires). I do see that the replacement reset switch (P/N 67854-98) is the same for all VRSC bikes so the picture for the VRSCAW IM could be wrong.
Old 11-07-2012, 04:10 PM   #12
DUTCHROD
SpeedoDocter
DUTCHROD's Avatar
Images: 66
Garage
Feedback Score: 16 reviews
took a shot of a 67392-01A(from a 04, nuts included now) 67394-07 67453-09 I believe last two are from DX
The connector pin layout is the same so it should work. Never tryed but i recall reading about it.
only thing litlle off will be the gas level gauge.
CUSTOM BUILD AND DESIGNED SPEEDO COLOR KIT'S !
-Crazy Colors gauge kits for all VR speedo's - BRIGHT!! A cruel cool easy DIY project.
website's 'News' page :
- 'DCL-BLF1' Plug 'n Play Brakelight modulator with over 115 patterns and settings
- 'DCL-HLS1' Headlight Switch for HID's
- Electronic software conversion service of MPH to KPH speedo's ! have yours done combined with a light kit now!
- soon: load equalizer
DUTCHROD is offline   Reply With Quote
Old 11-08-2012, 06:14 AM   #13
stever975
Super Moderator
Images: 22
Quote:
Originally Posted by DUTCHROD View Post
....only thing litlle off will be the gas level gauge.
I understand that even the fuel level gauge will work. The later model ultrasonic sending units are designed to produce the same signal as the older mechanical floats. Of course all of the fuel level gauges are "a little off" so I don't think you'd notice the difference.
Old 11-08-2012, 02:35 PM   #14
DUTCHROD
SpeedoDocter
DUTCHROD's Avatar
Images: 66
Garage
When i made the 'low feul light' for gaugeless bikes i noticed with the newer and older gauge a diffrence with the same 'value for the floater'.. (resistor to ground). so i made a offset adjuster. Just learn the diffrence and if you have problems with the difference PM me. i have to dive into it again but if i'm right it's easy to correct with one 10cent part in the wire.
Old 11-09-2012, 07:06 PM   #15
RustyG
Lifetime Premium
RustyG's Avatar
Images: 99
Feedback Score: 11 reviews
I/We installed a 2002 cluster on a 2003 with no proplems. THe fuel gauge even worked. The 07 model has a sonar based sending unit while the 03 had the ball and stick thingy. The gauge apparently recognizes either.
Regards,
John
Quote:
2007 VRSCX 0461 / 1400
2002 Road King Classic
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
