IAC and SEPST - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Reply
Thread Tools Display Modes
Old 11-03-2012, 06:32 PM   #1
Louis
Posting From The Pub
Louis's Avatar
Images: 3
Feedback Score: 5 reviews
IAC and SEPST
Bike shows all the signs of a dirty IAC. Stalls when hot. If it doesn't quite stall, after a bit the idle picks up and goes back to normal. I really want to finish some other stuff first before I take it off to clean / replace it. In the meantime I just saw a reference to an IAC setting in a tuner (TMAX as it happens - don't have one, don't want one). This stuff started when I switched from my PCIII to a SEPST. Are there any settings in the SEPST map that affect the IAC other than idle speed and fuel?
I'd guess not, but just checking.
Louis
Arnotts, D&D, SEPST, custom paint or all chrome according to mood, GRC seat, wave rotors, Muscle wheels, Burleigh bars, V-Gauge, assorted pretty bits.
2007 VRSC-AW (Fun).
2007 KTM 990 Adventure (Off Road and Touring).
2006 Triumph Daytona T955i (Evil).
2009 Fatboy (Heavily Tarted Up Show Pony).
2011 Bonneville (On long term loan).
1978 Triumph Bonneville Based Racer (Needs A Rebuild)
Louis is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-03-2012, 07:02 PM   #2
Dr Dave
Buy American!
Dr Dave's Avatar
Images: 93
Feedback Score: 3 reviews
Before you do that, replace your "System Relay". It's much easier and cheaper (especially if you break the fragile IAC screws that are bonded with Loctite).
Mine was doing the same thing, I thought the same thing. I removed, cleaned, and replaced my IAC with no joy (thank God that I did not break the screws).
I eventually replaced the System Relay to fix it.
Ride it like your life depended on it.
Dr Dave is offline   Reply With Quote
Old 11-04-2012, 02:00 AM   #3
Louis
Louis's Avatar
Images: 3
Hmm. Yes, I had better blitz the electrics.
Still leaves the same question though - I have unwisely used someone else's map as a base. Could they have done anything to mess up the idle other than change the fuel loading or desired idle speed?
Sent from my e1808_v75_jbaol1_5647 using Motorcycle.com App
Louis
2007 VRSC-AW (Fun).
Old 11-04-2012, 08:30 AM   #4
Karzza
all or nothing
Karzza's Avatar
Images: 2
Garage
Feedback Score: 0 reviews
It there a IAC initial calibration after uploading a map needed while using SEPST?
(Ignition on, run-switch 5s on, 5s off, 5s on, 5s off, ignition off)
300rwhp, E85 fuel
Falicon +3/8" full circle, K1, ceramic CP 4.25" pistons
Pinned cases, ARP 12mm head and main studs
Jones cams, SuperAlloy valves, titan retainers, Ferrea springs
Turbo Garret GT2860R, water cooled, Tial-housing
16 Psi Tial waste gate, Forge BOV, Treadstone IC
Bosch 190lb/hr injectors, Wabro 330lph pump
Bosch 5bar fuel regulator
Daytona VRFIgen3 ECM, Delphi 3bar MAP.
11 plates carbon fibre, billet basket, billet lifter plate
Str cut 2nd,
K&M plenum and -brace
Karzza is offline   Reply With Quote
Old 11-04-2012, 12:36 PM   #5
pecee
Registered Full
pecee's Avatar
Feedback Score: 4 reviews
Louis, if you want your bike to run as it should ,you should consider quitting the guess work tuning and buy the new daytona twin tec.
pecee is offline   Reply With Quote
Old 11-04-2012, 02:11 PM   #6
Louis
Louis's Avatar
Images: 3
I have, and use, the Daytona Twinscan.
Louis
2007 VRSC-AW (Fun).
Old 11-04-2012, 02:13 PM   #7
Louis
Louis's Avatar
Images: 3
IAC initial calibration? Not heard of it. I can try that..
Louis
2007 VRSC-AW (Fun).
Old 11-04-2012, 02:15 PM   #8
Boost
Back in Black
Boost's Avatar
Images: 35
Feedback Score: 12 reviews
stupid me just forgot to do this and I think (hope) I just fouled out some plugs.
My bikes mods (lucky enough to have 2 v-rods)
My bikes pictures
Founder of NightMare's NightRiders!
Boost is offline   Reply With Quote
Old 11-04-2012, 03:05 PM   #9
Louis
Louis's Avatar
Images: 3
Quote:
I've never done this, and can't see it in the manual either...
I'll go look harder.
[edit]
Just searched the help file in the SEPSt, can's find anything about it...
Louis
2007 VRSC-AW (Fun).
Old 11-04-2012, 03:19 PM   #10
Boost
Back in Black
Boost's Avatar
Images: 35
Just do as karzza said (Ignition on, run-switch 5s on, 5s off, 5s on, 5s off, ignition off)
before you start engine. cycle switch and look down tb and see if you can see iac go in and out. I have sprayed with carb cleaner from top. Not sure it ever did anything but thought it could not hurt if it was dirty. maybe more fuel at low rpm? I'll try to look I think there is something to adjust just can not remember what. what is tps at idle?
My bikes pictures
Old 11-04-2012, 03:57 PM   #11
Louis
Louis's Avatar
Images: 3
OK, it's easy enough! I'll do it! But I'd love to know where it is in the bloody manual, because if I have missed this rather vital sounding step, what heck else have I missed?!
Will do it tomorrow and report back.
Louis
2007 VRSC-AW (Fun).
Old 11-04-2012, 06:38 PM   #12
pgilliam1
Registered Full
pgilliam1's Avatar
Feedback Score: 1 reviews
If you're going to spray throttle body/carb cleaner into the IAC, make sure the engine is running. The cleaner will be sucked into and through the IAC for a thorough cleaning. Just spraying the cleaner onto the pintle doesn't do very much at all.
pgilliam1 is offline   Reply With Quote
Old 11-04-2012, 07:11 PM   #13
XvtxCrewzr
Crash Bandacoot
XvtxCrewzr's Avatar
Images: 7
My '05 B is having those issues,erratic idle..stalls sometimes..cleaned the IAC,and DID break a screw but was able to drill it out and retap with no problems..so System Relay? is there one on a 05?
'05 VRSCB,Sundowner seat with pillon,chrome side covers,chrome switch housings,chrome fuel cell covers,chrome brake/clutch resevoir covers,chrome engine kit,luggage rack,chrome swingarm,chrome upper/lower belt covers,pivot covers,chrome rear slotted wheel and pully,chrome girly hand levers,kuryakin grips,Avon Cobra's 200mm rear,power commander III with SE slip-ons and SE airfilter,and more chrome
Also a vintage '72 750 Norton Commando,and a Yammi XJ700 Maxim X
Now I'm REALLY
XvtxCrewzr is offline   Reply With Quote
Old 11-05-2012, 02:21 AM   #14
Louis
Louis's Avatar
Images: 3
Quote:
Yes, but it is not just the system relay, it is all the electrical gubbins: grounds would probably be top, followed by battery terminals.
In my own case I will disconnect the Twinscan and re-connect the V-Gauge so I can monitor the voltage.
Louis
2007 VRSC-AW (Fun).
Old 11-07-2012, 10:17 AM   #15
Louis
Louis's Avatar
Images: 3
Right, it isn't that.
No difference.
I am trying to finish my mapping before I fiddle, so I can get the Twinscan and its acres of wiring off at the same time, and the V-Gauge back on. But I am starting to suspect the fuel pump now or throttle body gasket now - I keep getting lean running under load however much fuel i throw at it.
Oh well, as soon as we get a few sunny days I shall finish the mapping and then tear it down fox fixs and Winter mods.
Louis
2007 VRSC-AW (Fun).
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
