rear brake sensor - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Reply
Thread Tools Display Modes
Old 11-03-2012, 09:19 AM   #1
rbccustoms
Registered Full
rbccustoms's Avatar
Feedback Score: 1 reviews
Angry rear brake sensor
went for a ride on my vrscf and got less than a block away and smoke and brurning wire smell comes from under air box..
the sensor that feeds into the brake module was melting? any one ever seen or heard of this? i guess its for the rear brake has two wires and is just under front right cover..
no idea how to remove it its behind the frame rail and the brake lines
2009 vrscf, flipped turn signals, custom guards on radiator inlets, topless, pcV w autotune, V&H comp exhasut, Destroyer throttle bodies, stacks and injectors, K&n filter, drilled intake panels, Hanny riser mod.
oh and that damn sissy pad that riuned rear fender.
rbccustoms is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-03-2012, 11:01 AM   #2
pgilliam1
Registered Full
pgilliam1's Avatar
This is typical and a known failure on these bikes. It's very easy to replace - it just unscrews. Replace it with Auto Zone part# RB401 and be done with it. If you use the Harley part replacement it will be the same part and will do it again. There will be brake fluid that comes out when you remove the sensor and you'll have to bleed the system after you replace the part. Be sure to use a teflon thread compound or teflon tape on the threads when installed. Good Luck!
pgilliam1 is offline   Reply With Quote
Old 11-03-2012, 01:34 PM   #3
Louis
Posting From The Pub
Louis's Avatar
Images: 3
Feedback Score: 5 reviews
It's not a sensor per se, it is the brake light switch. Known issue. You can get an aftermarket part which is less prone to melting, but you might also ask why it is getting so hot. Check for lean running or a badly designed aftermarket exhaust that is too close. Thanks to the bunny huggers, the stock bike runs too lean as well. If you want to keep the stock exhaust, fit a tuner. Not only will it stop the brake switch meting, but the bike will run way better.
Louis
Arnotts, D&D, SEPST, custom paint or all chrome according to mood, GRC seat, wave rotors, Muscle wheels, Burleigh bars, V-Gauge, assorted pretty bits.
2007 VRSC-AW (Fun).
2007 KTM 990 Adventure (Off Road and Touring).
2006 Triumph Daytona T955i (Evil).
2009 Fatboy (Heavily Tarted Up Show Pony).
2011 Bonneville (On long term loan).
1978 Triumph Bonneville Based Racer (Needs A Rebuild)
Louis is offline   Reply With Quote
Old 11-03-2012, 02:44 PM   #4
lastinline
on the hwy to hell
lastinline's Avatar
Feedback Score: 14 reviews
Mine quit working as we'll ABS model so not near the exhaust everything works fine just the brake light off rear pedal but front does the job, looks to be a PITA to change so probably won't unless absolutely have to
Sent from my iPhone using Motorcycle.com Free App
09 Red Hot Sunglow VRSCF
lastinline is offline   Reply With Quote
Old 11-03-2012, 07:14 PM   #5
ELUSIVE 1
Lifetime Premium
ELUSIVE 1's Avatar
Your rear brake & light are absolutely necessary.
I'd rather be on my motorcycle thinking about God, then in church thinking about my motorcycle.
ELUSIVE 1 is offline   Reply With Quote
Old 11-03-2012, 08:06 PM   #6
lastinline
on the hwy to hell
lastinline's Avatar
Quote:
the brake light illuminates by way of the front switch, don't use rear only therefore no hazards to me or anyone
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
