Ideal "idle" RPMs with Stage 2 cams, 58 mm TB?? - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Go Back   1130cc.com: The #1 Harley Davidson V-Rod Forum > V-ROD Discussions > V-ROD Hi-Performance
Reply
Thread Tools Display Modes
Old 10-30-2012, 08:04 PM   #1
FABSTER
GFYS
Images: 23
Feedback Score: 33 reviews
What's the ideal "idle" RPMs with Stage 2 cams and 58 mm TB?? Wondering since it appears that mine's idle a little bit higher than the previous time... Thanks guys
Sponsored Links
Advertisement
Old 10-30-2012, 10:40 PM   #2
vrunner79
Registered Full
vrunner79's Avatar
Feedback Score: 0 reviews
I hooked my SEPT to mine and ran a "live data" from cold idle to warm. Cold idle was around 1,400 - 1,450 . Once it warmed up it was about 1,250 - 1,300. The idle might have to be set a little higher with the increase in Air volume and if the air is getting cooler in your area the AIT I think will raise the idle to keep it from going overly rich
2009 VRSCF
vrunner79 is offline   Reply With Quote
Old 10-31-2012, 02:47 AM   #3
FABSTER
GFYS
Images: 23
Quote:
I'll try to do that this week thanks for the suggestion. I think mine is around those numbers too, at least that's what the tach says but it seldom lowers from 1300 so far, mostly 1350-1450ish
Old 10-31-2012, 03:10 PM   #4
vrunner79
Registered Full
vrunner79's Avatar
Here you go Fab. Cold idle to full warm up
http://youtu.be/4cTnDVaAEhU
2009 VRSCF
Old 11-04-2012, 09:10 AM   #5
plasticman05
Big Ugly fun guy
plasticman05's Avatar
Images: 13
I concur. With my Twin Tec, if I try to go below 1350 rpm it sometimes stalls coming up to a light when hot. Over 1440 it seems too high. I suspect that the low rpm airflow thru the larger plates with the cam overlap is causing weird pressure waves that is confusing the sensors. Might explain some of the broken plates some guys have seen. The larger plates give a steeper cross sectional area increase per degree of opening then the 53mm's.
plasticman05 is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
