TAB auto tuner issues - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Go Back   1130cc.com: The #1 Harley Davidson V-Rod Forum > V-ROD Discussions > V-ROD EFI
Reply
Thread Tools Display Modes
Old 10-16-2012, 10:09 AM   #1
Joshua022
Registered Full
Feedback Score: 0 reviews
Im running, supertrapp slip-ons with no baffles and the open cover so its as loud as possible, Im also running topless with the IAT sensor zip-tied into the lower box.
My auto tuner doesn't seem to 100% be handling the change from stock, its idle bounces from 1k to 1.5-1.8k, and it still feels like it stutters occasionally going down the road.
Is this the nature of the autotuner? or is it a possibility mines is faulty?
2013 VRSCDX Matte white!
Supertrapp slip-ons (no discs/or covers)
TAB auto tuner
Joshua022 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-16-2012, 10:19 AM   #2
cramos1279
Juice
cramos1279's Avatar
It could be your setup. Give Tab a call they are awesome and will work with you. I tried the autotuner but it didn't work for me.
'12 Black Denim (Sinister Color) V-Rod Muscle Stage 1
*Tab Pipes Without Muffler Baffles (LOUD)
*SE Super Tuner, SE High Flow Filter, Dynoed
*Progress Suspension Series 444 12inch Dropped
*Custom Sprocket Cover, Clutch Cover, Derby Cover, SwingArm Covers, Cam Covers
*Metzeler 260/Front
*Belt Guardless Top/Bottom (Raw Look)
*Custom Plate
*Strapless, Reflectorless (Front & Back)
*Stock Plate Vertical
*Rear Footpegless
*Willie G Handgrips, Footpegs, Clutch
*GR Customs Radiator Grills
cramos1279 is offline   Reply With Quote
Old 10-16-2012, 10:35 AM   #3
FIREFIGHTER
Registered Full
Give Justin at Tab a call and he will be able to work it out for you ! I have found their customer service to be second to none .
FIREFIGHTER is offline   Reply With Quote
Old 10-20-2012, 06:14 PM   #4
teardropz98
Registered User
Josh,
I have the EXACT same issue with my 2013 Night Rod Special. Too scared to ride it with these issues. I sent TAB a email(its the weekend). I'll have to call them on Monday. You get any response from them since?
teardropz98 is offline   Reply With Quote
Old 10-20-2012, 06:59 PM   #5
FIREFIGHTER
Registered Full
Just a thought but Im not sure from what Iv been told anyways that the auto-tuner cant handle going topless ?? hi flow filter yes but nothing more .Im sure they will straighten it out for you though .
Old 10-20-2012, 07:04 PM   #6
Joshua022
Registered Full
I saw another member say that they had one and when they tried to go topless it ran like mine, so I have put the box top back on but haven't got to rid it yet to see if it fixes it.
TAB said it could be air getting in around the gasket thinks under the bottom intake box, or a bad throttle position sensor. He then said if they don't fix it I can by pass the auto tuner and see what that does.
TAB auto tuner
Old 10-22-2012, 08:06 PM   #7
Joshua022
Registered Full
Put the top of the air box back on and might have actually gotten worse at idle.
I'll pull it all apart one night this week and see if its the gasket things or the tuner itself
TAB auto tuner
Old 10-24-2012, 06:49 PM   #8
FIREFIGHTER
Registered Full
Any updates on your tuner ?
Old 10-25-2012, 07:46 PM   #9
Joshua022
Registered Full
still having issues, I put the top on and it didnt help, I checked the 2 things TAB told me too and nothing then I swapped back my factory TPS to bypass the autotuner and it still ran bad, and when I say ran bad its 90% the idle it will jump from 1100-1400 like its got a big lopey cam in it.
10%being the occasional studder at slow speeds going down the road.
Also I noticed under the air box, the thing with hoses attached to it between the two plenums seem to be leaking oil?? is that normal?
kinda afraid Im gonna have to take it back to the dealer, and Im wondering if I need to take the autotuner and harness all the way out or if they will care.
TAB auto tuner
Old 10-29-2012, 04:53 PM   #10
FIREFIGHTER
Registered Full
How are you doing with your tuner problems?
Old 10-30-2012, 04:39 PM   #11
Joshua022
Registered Full
still have issues, havent burnt the last bit of gas out so I can refill with more and see if it was just gas related. Its been really windy and cold here lately, and Ive been real busy with work.
TAB auto tuner
Old 11-05-2012, 06:54 AM   #12
Nite Rodder
Registered User
There are other threads speaking about oil leaking on top of the motor. Here is one:
http://www.1130cc.com/forums/showthr...light=oil+leak
I did read another which I can't find now speaking of the bike running rough because of it. Check them out. Would like to hear an update. I just installed the tab auto tuner and tab slip on baffless pipes. Took it out for a 10 minute ride and felt really smooth so far. Way smoother at low speeds with the auto tuner installed.
Nite Rodder is offline   Reply With Quote
Old 11-14-2012, 12:54 PM   #13
FIREFIGHTER
Registered Full
Ta auto tuner
Im going to purchase a Tab tuner this winter so Im always interested to hear how guys have made out with them and you cant beat the customer service !
Old 11-15-2012, 03:18 AM   #14
BT
POST LIMITER
BT's Avatar
Send DOITLAYNSTYLE a pm... He trailed it for awhile for Tab......he couldn't get it to work past a certain range.....
BT is offline   Reply With Quote
Old 11-15-2012, 03:37 AM   #15
Barlow606
Registered Full
Barlow606's Avatar
I have just recently but the tab back slash slip ons, k & n high flow air filter and tab auto tuner on my 07 dx and it sounds and runs like a dream best mod I hand done ... The tuner I used had 10 preset maps in it that we're pre tuned to specific pipes used on specific model bikes... If you have this option could you possibly have the wrong map selected on the dial... Eg on my model rod with the back slash pipes and air filter I needed to turn the little dial using a tiny screw driver to map 7... Hopefully it's just simething simple like that.. If not tab were fantastic with there customer service,.. Even tho I am in Australia
Sent from my iPhone using Motorcycle.com Free App
Barlow606 is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
