Oil Filter Change/Maybe this will help - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Reply
Thread Tools Display Modes
Old 10-14-2012, 04:51 PM   #1
Uncle Fester
Lifetime Premium
Uncle Fester's Avatar
Feedback Score: 0 reviews
I don't know about anyone else, But I have always struggled getting the two bolts back in that secure the bottom of the radiator after changing the oil filter when the engine is hot. Yesterday I drained all the hot oil, but waited until today to put it back together. The bolts went back in with no issue. I can only guess it is because the metal was cool and everything lined up better that way. Hope this helps someone else.
Uncle Fester
Uncle Fester is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-14-2012, 05:30 PM   #2
luxlamf
Sanctimonious
luxlamf's Avatar
Images: 105
Feedback Score: 2 reviews
Buy a jack and you dont have to remove the bolts anymore. I have never removed the bolts.
I Ride My Bike To Trailer Rallies.
luxlamf is offline   Reply With Quote
Old 10-14-2012, 11:58 PM   #3
sammy
# 12/50 Ignite LE
sammy's Avatar
Don't need a jack, don't need to loosen the two bottom bolts, just need the correct filter wrench (cap style) for the stock filters.
GOT PAINT?
Don't be scared. We haven't lost tradition...... we've gained technology!
2004 VRSCA
Two-tone Smokey Gold with Vivid Black
SE 16G Double Barrel Exhaust
SE Airfilter
97% Pure Harley Davidson
sammy is offline   Reply With Quote
Old 10-15-2012, 12:50 AM   #4
Philthy
Registered Full
Philthy's Avatar
Images: 1
Feedback Score: 1 reviews
Quote:
Not so if you have a big hand. I wear the largest glove size out there, size 11. Even using a lift and a cap syle filter wrench, I can't squeeze my big mit in that small space to get the new filter to engage the first few threads. It is way too easy to unscrew the bottom of the radiator so you have some room to work. I won't risk cross threading that filter just to save that step.
The pilot is always the first person at the scene of the crash.
Philthy is offline   Reply With Quote
Old 10-15-2012, 12:57 AM   #5
$uicide $hift
Kickstart My Heart!!
$uicide $hift's Avatar
Garage
Feedback Score: 9 reviews
I just use an extension on my socket wrench with an oil filter wrench. Comes off nice and easy with no hassle. I don't remove the radiator bolts or jack it up either.
Quote:
Don't get all cunty, it's just my opinion.
$uicide $hift is offline   Reply With Quote
Old 10-19-2012, 01:12 PM   #6
luxlamf
Sanctimonious
luxlamf's Avatar
Images: 105
Quote:
Old 10-19-2012, 01:14 PM   #7
VrodG
Greg/Moderator
VrodG's Avatar
Images: 26
Feedback Score: 8 reviews
Quote:
Originally Posted by luxlamf View Post
VrodG is offline   Reply With Quote
Old 10-19-2012, 03:53 PM   #8
pday
(Peter)
pday's Avatar
Images: 3
I jack it up just to give me extra wiggle room under the bike. But make sure that the oil plug it clear of the cross member on the jack or it will be a friggin mess. Now I place the jack on the pan of an old dog crate whenever I am working with fluids. Learned the hard way it a lot easier to hose off a pan, then to clean the garage floor.
Peter Day
pday is offline   Reply With Quote
Old 10-19-2012, 03:57 PM   #9
CPTJAM
Lifetime Premium
CPTJAM's Avatar
Images: 21
Feedback Score: 32 reviews
Same here. I have big hands, but can thread the filter on. QMAN had a great tip - drain the night before. In the morning, install the plug, change the filter, fill, and go! Joe
TRAVELER: 2006 Roadrod VRSCR, Custom painted Ultrawhite, TTS Supercharger version2.0, TMAX, K&N, Supertrapp V5 exhaust, Pondo Caps, HC Stage II V LED tailight, "A" model bars, Corbin seat, luggage rack, Sumax bags, chrome peg mounts, '08 "D" wheels, polished, rear pulley by Pondo. Slipper clutch. More to come! Old Dyno results: 155 HP 86#TQ
COMET: 2009 AW, painted ultrawhite, a work in progress....105.18 HP, 73.98 torque;
CPTJAM is offline   Reply With Quote
Old 10-19-2012, 05:13 PM   #10
luxlamf
Sanctimonious
luxlamf's Avatar
Images: 105
Quote:
I jack it up all the way so I can lift the backend until the front tire touches the ground and drain out as much oil as possible.
Old 12-01-2012, 02:07 AM   #11
Rad_nuke
Registered Full
I ended up taking the bolts off AND jacking it up, but that is because the old filter was torqued on by the idiot who changed it before me. I tried repeatedly to turn that thing off of there with brute force.
It was on so tight that I had to go buy some oil filter pliers from Auto Zone. I love those things. The cap style filter wrench stripped out on the filter, but the pliers man-handled that thing out of there with no problems. For $10, I don't think I will ever have a garage without those pliers again.
Rad_nuke is offline   Reply With Quote
Old 12-01-2012, 07:42 AM   #12
T-Squared
"That just happened"
T-Squared's Avatar
Images: 2
http://www.craftsman.com/craftsman-o...1&blockType=L1
You can also find these in large and small sizes at places like Auto Zone.
To get the back end up, I just located the jack as far back as possible...it lifts the back end up while the front tire stays on the floor...
T-Squared is offline   Reply With Quote
Old 12-01-2012, 12:54 PM   #13
Rad_nuke
Registered Full
The problem with those is getting them around the filter in that space. The pliers definitely rocked for this job.
Old 12-01-2012, 06:09 PM   #14
T-Squared
T-Squared's Avatar
Images: 2
They worked just fine for me....
Old 12-01-2012, 06:15 PM   #15
wianb
Still riding!
wianb's Avatar
Just stab the old filter with a screwdriver, makes a good lever. Job done!
Royal British Legion Rider
Ian
I was a soldier once, and young.
2011 VRSCDX
Black Denim - V&H Comp Series 2into 1 - V&H Fuelpak - K&N Hi flow filter
wianb is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
