Gas question - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Reply
Thread Tools Display Modes
Old 10-08-2012, 05:44 AM   #1
steveiep68
Registered Full
Images: 4
Feedback Score: 0 reviews
Gas question
Hi, I've just read that normal unleaded gas will not be available here in Thailand from Jan, to save on pollution/enviroment. They are stopping production.
We have something called gasohol in 91 and 95 octane for quite sometime, will i need to alter anything on my 2004 A? Ive never used it. If i can avoid having to go into the motor it would be good, there are not many Harley trained techs here thats for sure. I searched for gasohol on the forum, im guessing it is some blend? There's millions of scooters here and they run on reg gas 91 which i have been using fine.
steveiep68 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-08-2012, 06:21 AM   #2
BT
POST LIMITER
BT's Avatar
No idea.......if u PM member Shed he lives in Thailand he may have some insights.......
BT is offline   Reply With Quote
Old 10-08-2012, 06:31 AM   #3
mikeinatlanta
The Massive Pr1ck
mikeinatlanta's Avatar
Do you know the alcohol content? Any will affect tune but if it's above 10% you must do a dyno tune to richen the mixture. Alcohol has less energy per unit so you will lean it out. So long as you don't max out the injectors, just the dyno tune is fine. Next issue will be damage caused to fuel system components from the alcohol. No need to worry though because you will have to change them anyway so you might as well ride it and see what breaks (after the tune that is). Bonus is you can bump the compression on your next build.
mikeinatlanta is offline   Reply With Quote
Old 10-08-2012, 08:46 AM   #4
ELUSIVE 1
Lifetime Premium
ELUSIVE 1's Avatar
Feedback Score: 1 reviews
Locate an airport and fill up with airplane fuel.
ELUSIVE 1 is offline   Reply With Quote
Old 10-08-2012, 09:12 AM   #5
steveiep68
Registered Full
Images: 4
Quote:
Please tell me you are not being serious ??
Old 10-08-2012, 02:47 PM   #6
tray
That U in my mirror?
tray's Avatar
Images: 163
I feel the need...The need for Speed!!!
2006 SE2 - Topless, SERT, Rinehart 2-1, Rick's Tank, Slipper Clutch, Progressive 440's rear with Progressive Fork springs, 8.5" Renegade "Venice" wheel with 260Metz (courtesy of HogPro), Lyndall Brake Pads, Custom Paint by Cutting Edge Illusions (formerly JE Illusions), LED's by Custom Dynamics. Kuryakyn ISO grips and Pegs, GR Custom Side Mount Plate.
You don't drown by falling in the water; you drown by staying there. - Edwin Louis Cole
tray is offline   Reply With Quote
Old 10-08-2012, 10:08 PM   #7
langwilliams
Registered Full
If it's available now buy some gas cans an stock up
langwilliams is offline   Reply With Quote
Old 10-08-2012, 10:24 PM   #8
TEAZZR
I Hate Stupid People
TEAZZR's Avatar
OMG!! This kind of suggestion is a Engine Rebuilders Dream...
2011 Muscle :
SE Stage II cams
58mm Destroyer TB
6.37 g/s Fuel inj.
Vance & Hines Comp. Slip-Ons
SEPST
K&N Cones - Topless
BOSS NOSS - Stealth system
TEAZZR is offline   Reply With Quote
Old 10-09-2012, 07:20 AM   #9
steveiep68
Registered Full
Images: 4
Quote:
Thanks, i have contacted Shed and he has been very helpful
Old 10-09-2012, 12:59 PM   #10
Philthy
Registered Full
Philthy's Avatar
Images: 1
In the US we have up to 10% alcohol blends in our gasoline and the bikes will run on it, but won't give you as good gas mileage as they would on gas without alcohol. I haven't had any fuel system problems from it and it doesn't seem to affect power output, just gas mileage.
The pilot is always the first person at the scene of the crash.
Philthy is offline   Reply With Quote
Old 10-09-2012, 03:01 PM   #11
ELUSIVE 1
Lifetime Premium
ELUSIVE 1's Avatar
Quote:
Yes,I'm serious. I've filled up with airplane fuel a few times in corn country where gas station Octane levels dip into the 87% range.
Rocket fuel I've used was 102 or higher.
Old 10-09-2012, 03:08 PM   #12
pecee
Registered Full
pecee's Avatar
Feedback Score: 4 reviews
Maybe im mistaken, but i think aircraft fuel has lead content which is a no go if you are running the cats still in the exhaust.
pecee is online now   Reply With Quote
Old 10-09-2012, 03:17 PM   #13
ELUSIVE 1
Lifetime Premium
ELUSIVE 1's Avatar
Quote:
I've removed the VRods catalytic converter and baffles....using powerline. Good point.
Old 10-09-2012, 04:52 PM   #14
Mikeee
Registered Full
Mikeee's Avatar
Up to 10% ethanol is acceptable in your bike. I've done tests, unscientific as they might be, on MPG difference between premium gasoline with 10% ethanol and straight non-ethanol, and the outcome depended more on my individual riding habits on each particular tank, than anything conclusive that one fuel affected my MPG one way or another. Some tanks of E10 delivered better MPG than straight gas, and sometimes it went the other way.
Only thing you've got to watch is methanol. Under no circumstances use a gasoline with methanol blended into it, or you'll have some serious fuel system damage.
Mikeee is offline   Reply With Quote
Old 10-09-2012, 04:56 PM   #15
harleynurse
caferacer
harleynurse's Avatar
Images: 30
Feedback Score: 27 reviews
I've pumped airplane fuel out of Reno without any changes in velocity or performance. Definitely didn't sputter or stall.
cafe-racer ,LANE~SPLITTER. Century rider x5.
07 NRS~ California with over 50,000 miles.
07 NRS~ "SOLD"..Nevada with over 50,000 miles.
03VRSCA "SOLD" after 50,000 miles.
harleynurse is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
