Other NOS systems. Not Boss Noss - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Go Back   1130cc.com: The #1 Harley Davidson V-Rod Forum > V-ROD Discussions > V-ROD Big Bore/Turbo/SC/NOS area
Reply
Thread Tools Display Modes
Old 10-03-2012, 07:38 PM   #1
vrunner79
Registered Full
vrunner79's Avatar
Feedback Score: 0 reviews
has anyone tried and other NOS systems besides the Boss Noss, Like Holly, Pingel, ZEX, Edelbrock? Most wet systems you would tap into the Schrader valve so when the spray comes on the factory fuel system supplies the the extra fuel. Not sure if the factory pump is capible of supplying the fuel for NOS. (no more then a 30hp hit on a progressive controller) Other systems are dry so the fuel injectors supply the fuel but something needs to tell the computer to add more fuel once the system is activated. I still am interested in Boss Noss, nothing wrong with keeping options open
2009 VRSCF
vrunner79 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-03-2012, 08:07 PM   #2
It's Anarchy
Registered Full
It's Anarchy's Avatar
I use a dual bottle Harley system by dynotune. Mine is the 4th bike down on the page
http://www.dynotunenitrous.com/store...rley_bikes.asp
Sent from my iPhone 5 using Motorcycle
2011 V Rod Nightrod Special
Sedona Orange
Screamin Eagle Air Filter
Screamin Eagle Super Tuner
Stage 2 Cam Kit
Destroyer Throttle Body
Tall Velocity Stacks
Destroyer Eagle Pro 6.3 g/s Injectors
Vance and Hines Widows Slipons (removed)
Topless Air Box
Modified Lower Air Box
Barnett Clutch
Toxic Big Rig Pipes w/Flow 9 baffles
MB Products 11" Black on Black Rear Shocks
Dynotune Twin Bottle Harley Nitrous Kit
Member of the 10 sec Club
Member of the 9 Sec Club
It's Anarchy is offline   Reply With Quote
Old 10-03-2012, 09:25 PM   #3
fastfail
Registered Full
fastfail's Avatar
Garage
Feedback Score: 5 reviews
Are you using a dry kit they have then?
Check out my garage for my BEAST of a NRS!
Lot's of turbo and nitrous neons
69 Camaro: Small Block (Soon LSxT)
88 TRX250r Custom Beast
Big ass K10
Escalade Tuned and retarted
Follow me on Instagram
Check out this bike on YouTube
fastfail is offline   Reply With Quote
Old 10-03-2012, 09:48 PM   #4
It's Anarchy
Registered Full
Yeah dry system and I have had the bike tuned since and I run cams, Destroyer TB, and 6.3 injectors and can safely spray the 50 shot.if you have any questions pm your number ill be glad to go over the whole system with you.
Sedona Orange
Stage 2 Cam Kit
Topless Air Box
Barnett Clutch
Old 10-03-2012, 09:50 PM   #5
2oo6niterod
drag racer
2oo6niterod's Avatar
Images: 8
Feedback Score: 22 reviews
pm sent
1998 Farmington Dragway Street Car Champion 83 Impala
2009 Farmington Dragway Motorcycle Champion 06 VRSCD
2013 Manufactures Cup Super Comp 8.90 Champion Crew Chief 06 Destroyer
2005 XL1200C
<<<<-----fuel management
<<<----shift lights
2oo6niterod is offline   Reply With Quote
Old 10-03-2012, 09:56 PM   #6
vrunner79
Registered Full
vrunner79's Avatar
PM sent to you
2009 VRSCF
Old 10-04-2012, 05:21 PM   #7
It's Anarchy
Registered Full
Quote:
Originally Posted by 2oo6niterod View Post
pm sent
No PM
Sedona Orange
Stage 2 Cam Kit
Topless Air Box
Barnett Clutch
Old 11-16-2012, 02:51 AM   #8
rejector
Retired/Fired
rejector's Avatar
Anyone have any info of the dynotune basic NOS system. It retails for 375 USD and as i am new to the world of NOS would appreciate any advice based on the following. The item is planned for a nitrod special 07 based in Indonesia and relatively hot climate all year round/crap fuel.
I have a doebeck plug play for a 1250 nitrod and the company advises it can be used on the 1130 engine on base settings and adjustable to suit. The idea really is to only use the NOS at HP 20 and max HP 30 for shows and occasional stress relieving moments. Again any points of view, advice re setup is much appreciated.
rejector is offline   Reply With Quote
Old 11-16-2012, 06:03 AM   #9
It's Anarchy
Registered Full
You should be fine as long as you pick the Harley EFI kit. That kit has a nice quick release bottle bracket so you can remove the bottle if its to hot out but honestly I never removed mine even on the 100 degree plus days...it actually raises the bottle pressure which is good.the kit is simple to install and should only take a couple hours. It doesn't tell you where to mount the spray nozzles but there you can mount them right in the air filter cover and you do have to have the IAT sensor close to the spray. PM me if you have questions.
Sent from my iPhone using Motorcycle.com App
Sedona Orange
Stage 2 Cam Kit
Topless Air Box
Barnett Clutch
Old 11-16-2012, 06:28 AM   #10
FABSTER
GFYS
Images: 23
Feedback Score: 33 reviews
Why the AIT sensor close to the spray, To make the AFR richer? You spray it in the air filter cabity or nozzles at the velocity stacs? Any pics of your setup?
Old 11-16-2012, 06:45 AM   #11
It's Anarchy
Registered Full
When I spoke to Steve at Dyno Tune he told me to put the IAT sensor as close to the spray as possible. I do have pictures in my profile album if you want to see them. My nozzles are mounted one on each tall side of the air filter cover on the side You get good mixture crossing the spray
Sedona Orange
Stage 2 Cam Kit
Topless Air Box
Barnett Clutch
Old 11-16-2012, 07:08 AM   #12
FABSTER
GFYS
Images: 23
Copy that
Old 11-16-2012, 07:10 AM   #13
FABSTER
GFYS
Images: 23
Anarchy, I tried to access your album but I get a "missing link" message...
Old 11-16-2012, 08:43 AM   #14
It's Anarchy
Registered Full
Quote:
Give me a bit to see what's going on with it, I'm at work right now but will look ASAP
Sedona Orange
Stage 2 Cam Kit
Topless Air Box
Barnett Clutch
Old 11-16-2012, 08:55 AM   #15
It's Anarchy
Registered Full
this should work
http://www.1130cc.com/forums/album.p...pictureid=4357
Sedona Orange
Stage 2 Cam Kit
Topless Air Box
Barnett Clutch
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
