User review: TV-3 and Cobra Power Pro on 2012 VRSCDX's - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Go Back   1130cc.com: The #1 Harley Davidson V-Rod Forum > V-ROD Discussions > V-ROD EFI
Reply
Thread Tools Display Modes
Old 09-07-2012, 09:51 PM   #1
Z06_Pilot
Lifetime Premium
Feedback Score: 0 reviews
Hi folks,
I thought I would post my experience with these two fuelers. The TV-3 was on a 2012 NRS, and the Cobra Fi2000 Power Pro is on my current ride, a 2012 VRSCDX-Anniversary.
Ease of installation: hands down, the Cobra wins. connections to the o2 sensors and the injector plugs. A 20 minute job. The 6 connections for the TV-3 made the install take an hour.
Initial problems: Cobra wins again. The TV-3 was throwing codes, killing the motor on occasion, and sputtering a great deal. Required a good deal of testing to figure out a couple of the harness pins were not terminated properly. A new wiring harness fixed the issue.
The Cobra caused some hesitation and surging between 3k and 4k in any gear when cruising. A call to Cobra and it was resolved. They set a default fuel level when cruising, and depending upon the stock mapping, that can be off a little. They have a digital enrichment adjustment pot on the pcb board that allows you to increase or decrease the fuel delivery during cruising. Works perfectly after I applied an increase.
Support: Hands down, Cobra. The Terry support folks maintained from the beginning that there was no way the problem could be theirs. They offered no assistance in troubleshooting or diagnosing the problem. The tech at my dealership took it upon himself to ohm out all the pins in the harness to find the problem.
Phil at Cobra support absolutely rocks. The guy seems to know everything about fuel management and exactly how the Cobra unit interacts with the HD map and ECU. He told me right off the bat how to make the fuel level adjustment for cruising since the auto tuning feature only operates during acceleration or deceleration.
Performance: this is what we are after, right? The Cobra wins again. While the TV-3 certainly richens up the fuel mix and improves throttle response, the Cobra takes it to another level. Perhaps its the sampling rate of 80/second, but the throttle response is absolutely immediate, and the bike desperately wants to get to red line as quickly as possible.
Either unit will certainly improve on the oxygen-starved stock setup. In my case, the Cobra just gets the job done better with fantastic technical support.
-'12 VRSCDX-Anniversary w/ABS, Tab baffled slip-ons, Cobra Fi2000 PowerPro Tuner, Tab hi-flo filter
-'13 FXSBSE CVO Breakout-Crimson Red, V/H Big Radius 2-2, Power Vision fueler
..."took a bead on the northern plains and just rolled that power on...." Bob Seger, "Roll Me Away"
Z06_Pilot is offline   Reply With Quote
Sponsored Links
Advertisement
Old 09-07-2012, 10:55 PM   #2
grimy
Registered Full
grimy's Avatar
Feedback Score: 3 reviews
Nice review/comparison, it's clear which tuner you prefer I'm curious to see how I handles different pipes, SE cams, different sizes stacks, turbo's, super chargers, big bores...
Sent from my Motorcycle iPhone app
Semper Fi
USMC Sgt 2004-2012
08 VRSCDXA-PCV+Autotune-BUB 7-Topless-SE AF-26T Fitz pulley-Progressive 440 Rear-Progressive Fork Springs-SE Fork Oil-VRSCA Bars-Superbrace-Ron's Fork Covers-Fork Boot Covers-Joker Shift Linkage-Joker Bar End Mirrors-Performance Machine Grips-Heat Demons-KillerGlass-DDM HID Kit-Kurykan ISO stirrup pegs-Sundowner Seats f/r-Powerlet Plug
grimy is offline   Reply With Quote
Old 09-08-2012, 12:55 PM   #3
Z06_Pilot
Lifetime Premium
You know, I felt the TV-3 was fine while I had it. When I got my "newer" 2012, instead of moving the TV-3 over, I went with the Cobra just because another V-Rod rider who works at my local dealership raved about it's performance.
Old 09-08-2012, 01:36 PM   #4
DungeonWorks
20 Eyes in my Head
DungeonWorks's Avatar
Thanks Z06 Pilot!
Quote:
I submit to you that if a man hasn't discovered something he will die for, he isn't fit to live.
Martin Luther King Jr., Speech in Detroit, June 23, 1963
DungeonWorks is offline   Reply With Quote
Old 12-18-2012, 04:15 PM   #5
JV Rod
Lifetime Premium
JV Rod's Avatar
Garage
Thanks for the info! I'm looking at getting the Cobra and sharing of your experience is huge in terms of helping me pull the trigger!
Vivid Black VRSCF: V&H Slips, SERT & Topless.
Oh yeah, I'm strapped!
JV Rod is offline   Reply With Quote
Old 12-18-2012, 04:26 PM   #6
Z06_Pilot
Lifetime Premium
Quote:
Hey JV,
I've been running it for a couple of months now and I have no complaints. I did have to adjust the digital fuel regulation setting on the circuit board inside the unit to richen up the fuel when cruising.
You simply pop the top off, use a small screwdriver, and turn the rheostat dial a notch or two to eliminate any popping you might be experiencing on decel.
I am still very pleased with it!
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
