'08 Rod feels like it's missing - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Reply
Thread Tools Display Modes
Old 09-05-2012, 09:01 AM   #1
V313
Registered Full
Feedback Score: 0 reviews
I just purchased an '08 Rod from a dealer after riding a '91 sporter for 21 years. The bike seems to be in excellent shape only 4200 miles on it and man is it fast. However, the longer I ride her the more it seems that it's not running exactly right ie; slight bucking and occasional popping from the exhaust. I'm running 93 octane and was wondering if the fuel map was off a little for the Vance and Hines 2 into 1 exhaust. It also seems to enjoy large amounts of fuel even without seriously twisting the throttle.
Anyone know if this is a common occurence and how is it fixed.
V313 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 09-05-2012, 09:08 AM   #2
pgilliam1
Registered Full
pgilliam1's Avatar
Feedback Score: 1 reviews
Fuel mapping, especially when modded, on these bikes is a huge issue. Go to the EFI forum and get comfortable.
pgilliam1 is offline   Reply With Quote
Old 09-05-2012, 12:03 PM   #3
V313
Registered Full
Thanks for the reply, i thought that might have something to do with it. I'll look into it.
Thanks again
Old 09-26-2012, 10:00 AM   #4
V313
Registered Full
I took the bike back to the dealer as the salesman told me if I had any problems that he would take care of it. Well guess what, I was told that there is nothing wrong with the bike and that the mechanic who test drove it said it ran fine. I was told there were no mapping issues and then I was questioned or rather insulted as to how I was riding her, when was I shifting and stupid questions like that.
Anyway I invested in a V&H Fuelpak based on the fact that I was running their exhaust and figured it would cure my problems. Well it helped a little but I still feel a miss when riding in a lower gear 2nd or 3rd running at a steady 3000 or 4000 RPM and of course the popping through the exhaust.
I'm about to take the bike back to the dealer and tell them where they can put it, I haven't even made the first payment yet.
Any help would be appreciated.
Old 09-26-2012, 11:05 AM   #5
rc4man
EXCELSIOR
rc4man's Avatar
Feedback Score: 4 reviews
I can understand your frustration with dealers. They go into denial anytime V-rods show up or are mentioned.
These things run lean as stock and more so with the fitting of aftermarket exhausts. There's alot of guys around that have favorite brands of fuel mapping devices but the important thing is to get advice or help from someone knowledgeable with the particular combination of pipe and mapper you have. Do some research and inquiry here in the EFI section. Find an independent shop that will perform a Dyno tune locally, if one exists. Often this is the only cure.
"V" Rod Forman, '04 Anodized "B", 50th B-day gift from wife.
rc4man is offline   Reply With Quote
Old 12-06-2012, 05:03 PM   #6
lt_crabby
Registered Full
lt_crabby's Avatar
I've got a 2007 VRSCX with the V&H 2-1. I just purchased it from a private seller about a month ago. The more I ride it, the more I feel the same thing is happening as you describe. I don't have gauges so I'm not sure about the speed/RPM, but I can say it idles fine and runs nice and smooth on the highway in 5th above ~65mph. However, at the bottom end of each gear i.e. 2nd & ~20mph, 3rd & ~35mph, engine seems to be missing and I get the popping noise as well. If I shift down it sounds like the engine RPM is much too high. If you didn't return the bike and discovered the problem please let me know!
lt_crabby is offline   Reply With Quote
Old 12-06-2012, 07:07 PM   #7
pgilliam1
Registered Full
pgilliam1's Avatar
I will also add that these bikes are very air intake restricted. If you don't have a K&N or UNI air filter you should get one. The airbox top also restricts intake air via the small snorkle. So after you install the new air filter try taking off the top of the airbox (just lay the IAT sensor that's clipped onto the airbox top in the bottom of the airbox while test riding). Taking the top of the airbox off will make the bike much louder, but you will notice a huge improvement in accelleration and it may help your problems and help gas mileage as well.
Good luck!
Old 12-06-2012, 10:18 PM   #8
jon1zc
Life is great!
Images: 6
Garage
Feedback Score: 13 reviews
I would look at your map values for Idle. The decel pop is when you are reverting idle from high rpm. If you give it a little bit of gas on decel and no more pop, then you need to add more fuel into your idle value mix..
jon1zc is offline   Reply With Quote
Old 12-07-2012, 09:57 AM   #9
V313
Registered Full
After the stealer told me nothing was wrong with the bike I purchased a V&H fuelpak, real ez install but it didn't help. Wrote H-D a letter told em I owned H-D's for 25 years and was a share holder too and was insulted by the service mgr.
Service mgr is no longer there and I was asked to bring the bike back as it should have come with the Screamin Eagle power commander. Anyway they worked on the bike and yes it was never setup right so they tweaked it which made some great improvements BUT it still pops and misses as you described. I dropped the bike back off at the dealer and they are now going to Dyno tune it at their expense. I realize I didn't really answer your question but if you are not sure if the bike was setup right for the exhaust system I have a like new V&H Fuelpak I can make you a deal on.
Old 12-07-2012, 10:23 AM   #10
PD87
Registered Full
PD87's Avatar
Images: 55
Feedback Score: 3 reviews
A couple of issues with your second post (and Im not defending the dealers, my bike has never been back there) but you cannot ride/shift a Vrod like a Sportster. The Vrod runs better on higher rpm's. Two, changing to a V and H fuel pack doesnt make a big diffrence, its the map thats loaded that determines how it will run. Without someone putting it on a dyno and tunning it, you wont know. Before you blow up in the dealership and go ranting spend a little time here and learn about the bike.....good luck
PD87 is offline   Reply With Quote
Old 12-07-2012, 10:27 AM   #11
PD87
Registered Full
PD87's Avatar
Images: 55
Sorry it was your third post I was responding to. Also if you have a V and H Comp exhaust, they are a short pipe, without an expert tune they will pop a little. I have one, I know. The longer the pipe and the better the tune, the least amount of decel pop...
Old 12-07-2012, 08:26 PM   #12
pwrman
Registered Idiot
pwrman's Avatar
Feedback Score: 6 reviews
20 mph in 2nd gear? Really? I don't hit second until 60 mph
pwrman is offline   Reply With Quote
Old 01-04-2013, 10:13 AM   #13
V313
Registered Full
The dealer Dyno tuned my bike and the missing and popping are history, besides I got almost a 10 HP increase as well as a big jump in torque. Gave me dyno print outs of before and after, fuel/air was way off, obviously.
Old 01-04-2013, 08:40 PM   #14
RustyG
Lifetime Premium
RustyG's Avatar
Images: 99
Feedback Score: 11 reviews
The V-Rod engine is a racing engine. It was designed to run at higher rpm's Running it below 4K rpm's will result in some lugging and poor performance. Popping is the results of lack of detonization of the fuel in the combustion chamber by,more than likely, incorrect fuel mixture.
I am a very conservative rider but I know enough to not give it large amounts of gas if in a higher gear at low rpm's. Keep the revs up and you will be happy.
Regards,
John
Quote:
2007 VRSCX 0461 / 1400
2002 Road King Classic
Old 01-04-2013, 08:45 PM   #15
RustyG
Lifetime Premium
RustyG's Avatar
Images: 99
IMHO having any bike tuned at a H-D Dealer is not a good idea. In talks with a dealer I frequent the dealers are required to tune to EPA specifications which results in poor performance on the V-Rod. Best to find a real good independant and have them tune it for performance running.
Regards,
John
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
