Coolant leak, help identify the culprit - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Reply
Thread Tools Display Modes
Old 07-20-2012, 06:45 PM   #1
dynamo78
Registered Full
dynamo78's Avatar
Images: 21
Garage
Feedback Score: 6 reviews
Hey,
Just got done working and noticed a coolant leak. (again)
I already tightened up the obvious clamps, so this time I just let it idle after coming home and looked for signs of leak.
It appears to be leaking from a screw on top of the front cylinder marked in the pictures. What screw is that ( check manual, but with no luck) and how do I tighten / fix it.
Sturgis is approaching fast and I need the bike to be ready for the long haul.
Thanks for inputs
(clamps are tight and checked, and it's not leaking from the waterpump)
Sent from my Motorcycle iPhone app
ID:	185802   Click image for larger version
Dynamo
" Seek and Destroy "
SOLD 2006 VRSCA Cobalt Blue SOLD
2008 VRSCDX
dynamo78 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-20-2012, 07:17 PM   #2
dynamo78
Registered Full
dynamo78's Avatar
Images: 21
Garage
Located the screw.
Number 7 in the picture: fastener and washer.
Does not appear to have a reason to leak. Anybody know if it could be possible to leak from there, or is this just an blind attachment spot on the cylinder?
Not sure where it's coming from, if not from there.
Dynamo
2008 VRSCDX
Old 07-20-2012, 07:42 PM   #3
gman57
Registered Full
gman57's Avatar
Feedback Score: 3 reviews
If leak looks like its coming from there Id check the clamp that is attached to that bolt didnt rub a hole in the hose there.
gman57 is offline   Reply With Quote
Old 07-20-2012, 09:35 PM   #4
dynamo78
Registered Full
dynamo78's Avatar
Images: 21
Garage
Yup. That was it. I took the airbox off. Then removed said clamp and found the clamp had actually cut into the pipe that's there. After starting up for a second I found the leak right there. Guess I have to order that pipe new. Hopefully the install/ removal won't be a nightmare.
ID:	185827   Click image for larger version
Dynamo
2008 VRSCDX
Old 07-21-2012, 02:27 PM   #5
dynamo78
Registered Full
dynamo78's Avatar
Images: 21
Garage
Coolant pipe is on order, takes 2-3 weeks. Shipping to Canada really sucks. For the time being I'm patching up the damaged pipe with this. Hope it holds up.
Dynamo
2008 VRSCDX
Old 07-21-2012, 09:05 PM   #6
LorAnimal
Registered Full
LorAnimal's Avatar
Feedback Score: 0 reviews
Greets, just had SAME thing happen. Pitch that "P" clamp. Also make sure to order new heat shrink clamp too. You'll need it. Also that steel putty stuff will work. Used while on my way to Laconia this year...pure magic. I also covered that temp fix with heater hose and a hose clamp.
Nick
08 Vrscdxa
LorAnimal is offline   Reply With Quote
Old 07-22-2012, 07:58 AM   #7
LorAnimal
Registered Full
LorAnimal's Avatar
Also hardest part was removing the battery plate....FYI
And you'll need a badass heatgun.
Stay Frosty...
Name:	ImageUploadedByMO Free1342961788.572478.jpg
ID:	185889   Click image for larger version
Name:	ImageUploadedByMO Free1342961808.707200.jpg
Old 07-22-2012, 07:59 AM   #8
LorAnimal
Registered Full
LorAnimal's Avatar
Hey Dynamo,
How many miles you have? Mine crapped out at 12700ish.
Old 07-22-2012, 11:02 AM   #9
dynamo78
Registered Full
dynamo78's Avatar
Images: 21
Garage
I'm around 11000 miles.
Thanks for the tips.
I did order the heat shrink clamp as well as the pipe. Also ordered the rear breather tube while I was at it.
When you say 'pitch the clamp', did you mean you are riding without it ?
Dynamo
2008 VRSCDX
Old 08-01-2012, 08:49 PM   #10
Terry6422000
CENLA V-Rodder
Terry6422000's Avatar
Garage
Feedback Score: 2 reviews
Just noticed I have a leak as well...My bike is an 04 VRSCA with just over 5200 miles on it...Believe one of the shrink clamps is the culprit. Do these have to be replaced or can you use a heat gun and reshrink and/or shrink them further if they have loosened? Guess what I'm saying is maybe they weren't properly shrinked when installed...then again the bike is 8 years old.
Any man who may be asked in this century, what he did to make his life Worthwhile, can respond with a good deal of Pride and Satisfaction, "I served in the United States Navy". JFK
Terry6422000 is offline   Reply With Quote
Old 08-03-2012, 11:34 AM   #11
nightroddersp
james
nightroddersp's Avatar
Images: 8
dam i just had mine off and i didn't see a scuff mark or any thing showing ware. it might not be the clamp. it could be an erosion problem from the inside. could you check the culprit and see if it is thinner than the rest of the pipe??? although it doesn't compute since mine has 33,000 miles on it.
nightroddersp is offline   Reply With Quote
Old 08-03-2012, 01:18 PM   #12
Luigit
Sleep is over-rated
Luigit's Avatar
Images: 14
Feedback Score: 20 reviews
mine leaked a few years ago and all i did was install a hose clamp on it. its been that way for 5 years now and not a drop.
too much of a pain in the butt to take everything out and replace just the heat shrink clamp (gates clamp as its called)
Always Ride like everyone is trying to KILL you. Why? because they are...
Luigit is offline   Reply With Quote
Old 08-03-2012, 04:32 PM   #13
pecee
Registered Full
pecee's Avatar
Feedback Score: 4 reviews
whats really fkd here is hd have known about this problem since i had a claim on my first bike in 02 yet they still use that stupid clamp idea.
pecee is offline   Reply With Quote
Old 08-03-2012, 06:06 PM   #14
Terry6422000
CENLA V-Rodder
Garage
So...does anyone know if you can get the heat shrink clam tighter by using a heat gun on it or do I need to try and replace it? I can always go with a regular clamp I guess...
Old 08-14-2012, 11:52 PM   #15
dynamo78
Registered Full
dynamo78's Avatar
Images: 21
Garage
Should be able to shrink it with a heat gun. That's what its for.
Sent from my Motorcycle iPad app
Dynamo
2008 VRSCDX
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
