Destroyer cluth hub need help - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Go Back   1130cc.com: The #1 Harley Davidson V-Rod Forum > Specific Model > VRXSE
Reply
Thread Tools Display Modes
Old 06-25-2012, 11:58 AM   #1
jrspm
Registered Full
jrspm's Avatar
Feedback Score: 0 reviews
Has anyone had problems with the destroyer clutch hub cracking? For some reason I have been breaking clutch hubs every time I go racing. They crack along the large snap ring groove. I am thinking of welding around the groove to help support the hub. I have tried different clutches, packed clutch at different thicknesses and it still cracks. Everything else, including the V&H clutch basket and transmission shaft are fine. I wanted to go to Tulsa, but without getting clutch hub problem fixed it would be a waste of time. Any help would be appreciated.
Thanks,
John
ID:	184291   Click image for larger version
jrspm is offline   Reply With Quote
Sponsored Links
Advertisement
Old 06-25-2012, 08:15 PM   #2
grandpawgriz
Registered Full
grandpawgriz's Avatar
Images: 3
How many times has this happened? What is your clutch set up? Are you using Barnett stuff??
Griz
2011 AHDRA Sportsman Rookie of the year
Endorsed by the state of Ohio since 1976
Power by Vreeland's Harley-Davidson
Best 60' 1.438
Best 1/8th 6.181 @ 111.37 MPH
Best 1/4 9.783 @ 136.10 MPH
855 LBS at the starting line
grandpawgriz is offline   Reply With Quote
Old 06-26-2012, 08:26 AM   #3
jrspm
Registered Full
jrspm's Avatar
It has happened four times, two times in two races. I use six washers on the arms the middle static spring with a .050 shim and harley clutch plates, have also used energy one plates.
Old 06-27-2012, 11:27 AM   #4
clint6776
Registered Full
How long have you been running the V@H clutch basket? Also, what was the last thing/ adjustment you made to the clutch before this problem started or did the problem start after a brand new set of plates were installed?
clint6776 is offline   Reply With Quote
Old 06-27-2012, 01:10 PM   #5
jrspm
Registered Full
jrspm's Avatar
I have always had the V&H basket and used the same set up only this year I have a new motor and have gained 20LBS. Ray Vreeland told me I should use a heaver static spring.I am going to try that this weekend at my local track.
Old 06-27-2012, 08:20 PM   #6
TaxmanHog
Noel
TaxmanHog's Avatar
Images: 277
Garage
Feedback Score: 2 reviews
Quote:
Thanks,
John
You're probably aware, but TULSA was canceled this week do to bad heat conditions.
Have you ensured proper alignment of the pressure plate and hub?
It's easy to think that they will fit in any of the five positions, but in reality they only fit up correctly in one position.
I have not noticed any cracking yet, but I recall reading some ancient threads on the topic
2006 VRXSE Destroyer
VRD-941 & ET-943
60: 1.393
ET: 9.661
Mph: 139.34
Check Your Grounds
TaxmanHog is offline   Reply With Quote
Old 06-28-2012, 11:29 AM   #7
clint6776
Registered Full
Correct me if I'm wrong but if you weigh more wouldn't you want to lower your static spring pressure? Allowing the clutch to slip a little more to get you out of the hole without bogging. This has been the base of my problem the entire season so far. Went with medium (heavy duty) springs and bogged, then went with the lightest springs(medium duty) plus .150 of shim under each one and started bouncing of the limiter almost instantly.
Old 06-28-2012, 11:45 AM   #8
grandpawgriz
Registered Full
Images: 3
bogging
Quote:
I weigh 300lbs in leather, 850 on the scales after a pass. I got the red springs in with no shims and leave at 7500 to 8000 with no bog on stock gearing. We are in the process of changing the gearing to get a little better 60' and to be farther into 5th in the traps. The taller MT or Goodyear is messing with my plans
Griz
Best 60' 1.438
Old 06-28-2012, 11:45 AM   #9
TaxmanHog
Noel
TaxmanHog's Avatar
Images: 277
Garage
You're on the correct principal, but also look at final drive ratio, going lower on the front sprocket and or higher on the rear will also help
Sent from my droid
VRD-941 & ET-943
60: 1.393
ET: 9.661
Mph: 139.34
Check Your Grounds
Old 06-28-2012, 12:55 PM   #10
clint6776
Registered Full
To start, I didn't mean to take away from this mans thread. I wish him well with finding his problem.
Now I am totally lost. I way 240 with leathers and helmet. LOL what a nightmare this has become. Try try try again!
So you think I'm going the wrong way with my rear sprocket? Should have went up with the # of teeth?
Old 06-28-2012, 12:59 PM   #11
patm
AIM Bagger Edition
patm's Avatar
Garage
Feedback Score: 77 reviews
Going lower on the front gets you out of the hole faster but you'll have to do something to keep you from running out of gear at the big end.
patm is offline   Reply With Quote
Old 06-28-2012, 03:50 PM   #12
jrspm
Registered Full
jrspm's Avatar
I was told @230 lbs. I need the red springs,four washers on arms and adjust leaving with tire pressure.
Old 06-28-2012, 04:44 PM   #13
TaxmanHog
Noel
TaxmanHog's Avatar
Images: 277
Garage
Quote:
Sometimes I think the variable, is the power the engine is producing, yours has been graced by the hands of Ray Vreeland, I'll bet that baby is ticking & kicking wonderfuly.
I do not think I have the best tune, so I am still working around the Tire & gearing factors. I was thinking of putting the ROBS DYNO tune back in my ECM, I know his tune helped me last fall!
VRD-941 & ET-943
60: 1.393
ET: 9.661
Mph: 139.34
Check Your Grounds
Old 06-29-2012, 05:34 AM   #14
clint6776
Registered Full
Have yet to even put mine on the dyno. Just another expense I can't afford at the moment. Bike seems to be running pretty fat right now and has a hard time idling which I am sure is a part of my problem. For now I will stick with gearing changes.
Old 06-29-2012, 05:43 AM   #15
clint6776
Registered Full
Also, with the M/T, I have enough gear to go way past the trap. I think I will try a tooth less on the front sprocket. Thanks for the tips gang. For some reason I was thinking the opposite but now it makes sense. Rookie mistake, hehe!
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
