dragracing problem - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Go Back   1130cc.com: The #1 Harley Davidson V-Rod Forum > V-ROD Discussions > V-ROD Big Bore/Turbo/SC/NOS area
Reply
Thread Tools Display Modes
Old 06-03-2012, 04:12 PM   #1
Jan-Dirk
Autobanmod
Jan-Dirk's Avatar
Images: 361
Garage
Feedback Score: 0 reviews
dragracing problem
my engine runs wonderful on countryroads and in town but on a dragstrip it starts sputtering all day long.
Today sucked! I changed sparkplugs, reduced boost, used BAD V-R's Temperature override switch, put in different fuel - nothing helped.
When the boost kicked in it started sputtering / misfiring but AFR was ok.
On the way back home all was ok again.
Maybe the ECM gets confused by the burnout / hitting the rev limiter?
Hog of Steel
Jan-Dirk is offline   Reply With Quote
Sponsored Links
Advertisement
Old 06-03-2012, 04:21 PM   #2
Karzza
all or nothing
Karzza's Avatar
Images: 2
Garage
...go to VRFI gen3(4) and you can see afterwards all what has happened at drag strip.
300rwhp, E85 fuel
Falicon +3/8" full circle, K1, ceramic CP 4.25" pistons
Billet oil-pan, pinned cases and ceramic bearings, 12mm head and main studs
Jones cams, SuperAlloy valves, titan retainers, springs
Turbo Garret GT2560R, water cooled
16 Psi Forge waste gate and BOV, Valeo i-cooler
Black Ops 172lb/hr injectors, Wabro 255lph pump
Porsche tbo 5bar fuel regulator
Daytona VRFIgen3 ECM, KMS 3bar MAP.
11 plates carbon fibre lock-up, billet basket
Str cut 2nd,
K&M plenum and -brace
Karzza is offline   Reply With Quote
Old 06-04-2012, 10:53 AM   #3
Demon Blue
Registered Full
Demon Blue's Avatar
Images: 2
When you changed plugs did you tighten the gap any or use the same gap? Just a thought in case the boost was putting out the spark.
Demon Blue is offline   Reply With Quote
Old 06-04-2012, 12:03 PM   #4
Jan-Dirk
Autobanmod
Jan-Dirk's Avatar
Images: 361
Garage
I put in used Iridiums with normal gap.
Everything was normal again on the way home from the dragstrip, including several miles Autobahn, hard launches from a traffic light wide open throttle through all gears.
I have contacted Messrs Daytona Twintec regarding VRFI...
Hog of Steel
Old 06-04-2012, 12:05 PM   #5
Jan-Dirk
Autobanmod
Jan-Dirk's Avatar
Images: 361
Garage
Boost putting out the spark, that's exactly how it felt.
But why only on a dragstrip?
Hog of Steel
Old 06-05-2012, 11:48 AM   #6
Demon Blue
Registered Full
Demon Blue's Avatar
Images: 2
My guess would be that on the strip when the traciton is there it makes more load on the motor.
On the street there is less traction (more wheelspin) and hence less load on the engine.
I have had that problem before on turbo cars and you have already addressed the obvious issues (reduced boost, increased fuel pressure/octane etc.) so that is where I would look next and hopefully it helps.
Keep us informed
Mit freundlichen Grüssen
Old 06-05-2012, 01:14 PM   #7
Lane
TURBONATOR
Lane's Avatar
Feedback Score: 4 reviews
Jan
I don't run the boost you do but I gap my iridums at .020 and it doesn't miss a beat.
Sent from my PC36100 using Motorcycle.com Free App
Very interesting short read....
(AKA) Have Your Cake And Eat It To
THE TURBONATOR
06 SE (Lane-r-ized)
Everything I say is for entertainment purpose only
Lane is offline   Reply With Quote
Old 06-05-2012, 01:47 PM   #8
Jan-Dirk
Autobanmod
Jan-Dirk's Avatar
Images: 361
Garage
Thank you all for your advises, your feedback is highly appreciated.
Meanwhile I have ordered a VRFI ECM, always wanted to have one because of other issues with the stock ECM.
For sure I will follow up spark plug gapping.
Hog of Steel
Old 11-11-2012, 11:52 AM   #9
nitroslick
Registered Full
Images: 4
Garage
Feedback Score: 1 reviews
i would place a bet its down to fuel flow ,have you still got the original v-rod fuel filter in the tank ? i had exactly the same problem and fitted a sytec bullet filter in its place in the tank bike feels a lot stronger since i did this but its the season end here so will get a power run on the local dyno as i put v/h street cams in as well
nitroslick is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
