6 Speed Transmission revisited - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Go Back   1130cc.com: The #1 Harley Davidson V-Rod Forum > V-ROD Discussions > V-ROD Hi-Performance
Reply
Thread Tools Display Modes
Old 05-01-2012, 03:34 PM   #1
NodakSpeedFreak
Registered User
Feedback Score: 0 reviews
Ok, I know there are alot of posts on 6 speed transmissions for the Vrod, but I have a question for you more knowledgeable types. I did a google on 6 speed transmission for vrod and it took me to jpcycles.com to a generic right side 6 speed transmission. Just wondering if this would work on a 2011 Nightrod Special? Would be nice to know before I spend close to $1k.
NodakSpeedFreak is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-01-2012, 03:39 PM   #2
vrodderD
VRSCD's Rule!
vrodderD's Avatar
Images: 101
Feedback Score: 22 reviews
Nope. HD Aircooled types have a separate housing for the tranny and it can be changed out to whatever you want/afford.
Vrod tranny is integrated into the engine case, so you're stuck with 5.
2006 VRSCD Nightrod
1250 heads w/SE2 Cams
Rinehart 2-1 exhaust
2012 FLHX Street Glide
Bone Stock (for now)
vrodderD is offline   Reply With Quote
Old 05-01-2012, 03:51 PM   #3
cycorod
cycorod's Avatar
Images: 41
Feedback Score: 3 reviews
Can you change the gears themselves? I think V/H CHANGE THE 2ND gear???
cycorod is offline   Reply With Quote
Old 05-01-2012, 04:00 PM   #4
mardymac42
ramma jamma
mardymac42's Avatar
Images: 5
Garage
Feedback Score: 6 reviews
yeah. just a higher 5th gear cog would be cool. bring it down a couple thou rpm's at 70 mph?
'03A27.5kMi
LEFT EARDRUM DAMAGE THX TO MYCAR47562
topless
K&N, stealer flash>pc3, homegrown 2 into 1, diy flange tool, Reactors & .99 matching pulley, 28T
mardymac42 is offline   Reply With Quote
Old 05-01-2012, 04:37 PM   #5
stevel
www.badpenny.org
stevel's Avatar
Images: 3
Feedback Score: 23 reviews
Quote:
Much easier and cheaper to change the final drive gearing.Even a chain conversion to run whatever sprockets you want would be way cheaper than a new gearbox.......
Steve
Ride a Harley? Live in Great Britain?
Then the
is the club for you.....
stevel is offline   Reply With Quote
Old 05-01-2012, 04:52 PM   #6
TaxmanHog
Noel
TaxmanHog's Avatar
Images: 277
Garage
Feedback Score: 2 reviews
Exclamation
Quote:
Yes they did, but this gear is designed to facilitate racing, the stock 2nd gear has more narrow teeth in a helical cut which have been known to break under racing conditions.
VH, makes two versions of 2nd gear one which complies the Destroyer setup and is an acceptable substitute to remain in SPEC compliance with VRD class racing rules. The gear on the far right is the new VH 2nd gear.
The other, also a straight cut gear is designed for street bikes that might be under greater stress due to BiG bore, Nitrous or Turbo applications that are being raced.
The ratio changes on these gears are negligible.
I'm with the other guys who suggest changing your final drive ratio to get the high gear engine RPM's down, but don't compare the RPMs to an EVO or TC, the Revolution engine is much happier at a higher number, get acclimated to it.
2006 VRXSE Destroyer
VRD-941 & ET-943
60: 1.393
ET: 9.661
Mph: 139.34
Check Your Grounds
TaxmanHog is online now   Reply With Quote
Old 05-02-2012, 12:26 PM   #7
SE V-ROD Tom
Registered Full
SE V-ROD Tom's Avatar
Feedback Score: 5 reviews
I'm still waiting to acquire pieces/parts so I can get with a gear vendor to investigate different gearing. I'm not really willing to pull the working engine out to do this....
Changing either pulley only changes final drive, I want my cake and eat it too.... lower 1st gear like running a 26t pulley, and then 5th to be like when running a 30t.
'05 Cherry Screamin Eagle UE 5 gal tank, Keyless mod, 200mm rear, Sundowner, Thundermax, H-D Tribal Mirrors, Trask Turbo kit, Ballistic battery, Swing Wing Pegs
'05 Teal/Blue Screamin Eagle Sundowner seat, Thundermax, H-D Tribal Mirrors, V-Modded Stock Pipes, Ballistic battery,
SE V-ROD Tom is offline   Reply With Quote
Old 05-02-2012, 01:08 PM   #8
myvrodrocks
myvrodrocks
myvrodrocks's Avatar
Images: 95
Feedback Score: 24 reviews
Even if you could find a vendor to make custom gears, you won't have clearance in the case.
myvrodrocks is offline   Reply With Quote
Old 05-03-2012, 10:50 AM   #9
mardymac42
ramma jamma
mardymac42's Avatar
Images: 5
Garage
Make a case with room? Would a higher ratio 5th gear seriously just not fit? Sorry, I haven't been in a tranny yet myself.
'03A27.5kMi
topless
Old 05-03-2012, 02:16 PM   #10
calereeves
calereeves's Avatar
Quote:
Thats the answer I've been looking for for a good while! I asked this very same question about a year or so ago--and asked if there were any physical limitations inside the tranny case to prevent a taller 5th from being installed.... money considerations for the gear itself aside... nobody ever gave me a straight answer. What part causes the interference? Is it just a very tight tolerance to the case?
calereeves is offline   Reply With Quote
Old 05-03-2012, 04:23 PM   #11
ohioVROD
Senior Member
ohioVROD's Avatar
Images: 107
Feedback Score: 31 reviews
BINGO zero room I have wrenched on more transmissions then I care to talk about and there is literally no additional room for a taller 5th gear per say.
D.A. FITZGERALD CO., INC. / FITZGERALD MOTORSPORTS Your one stop performance VRod shop!
Authorized dealer for Vance & Hines, MegaCycle Cams, CP Pistons, Brown's Plating, Carrilo Rods, ARP Studs, Falicon Crankshafts and Diamond Heads.
Services offered: Case Boring-26T Pulley-58mm Throttle Body-Slotting Sprockets-Pinning of Bearings-Custom Machined Wheels & Rear Pulleys- Engine Brace Kit
Contact us at
ohioVROD is offline   Reply With Quote
Old 05-03-2012, 04:37 PM   #12
Karzza
all or nothing
Karzza's Avatar
Images: 2
Garage
The 6th gear is as easy to build than a 3rd cylinder.
300rwhp, E85 fuel
Falicon +3/8" full circle, K1, ceramic CP 4.25" pistons
Billet oil-pan, pinned cases and ceramic bearings, 12mm head and main studs
Jones cams, SuperAlloy valves, titan retainers, springs
Turbo Garret GT2560R, water cooled
16 Psi Forge waste gate and BOV, Valeo i-cooler
Black Ops 172lb/hr injectors, Wabro 255lph pump
Porsche tbo 5bar fuel regulator
Daytona VRFIgen3 ECM, KMS 3bar MAP.
11 plates carbon fibre lock-up, billet basket
Str cut 2nd,
K&M plenum and -brace
Karzza is offline   Reply With Quote
Old 05-03-2012, 04:56 PM   #13
myvrodrocks
myvrodrocks
Images: 95
Check out the photo above. I circled the edge of fifth in the attachment. This the gear that needs to grow and its opposing gear to shrink. If I am not mistaken, 5th is part of the shaft meaning you would need to manufacture the whole output shaft...I could be wrong.
Anyway, in my attachment I circled where the gear would hit the case. Looks as if there is room. but you can't see down around the bottom. It's very close.
Old 05-03-2012, 05:10 PM   #14
myvrodrocks
myvrodrocks
Images: 95
Quote:
Maybe...but that has been done...
Old 05-03-2012, 06:22 PM   #15
rippie74
1130cc is enuff 4 me
rippie74's Avatar
Images: 3
Feedback Score: 9 reviews
I think our bikes with 5 gears is perfect. I used to wish for a 6th gear out on the highway, but what would it really do for us? Maybe drop the revs by 300-400 rpms & 75mph? It's not worth it. In 5th gear @ 50 mph I'm @ 3000 rpm. (In these bikes thats on the verge of lugging the motor (bad) If you had a 6th gear & shifted into it you'd be lugging the motor @ say 2500-2600rpm. That would do damage to the motor over time. I hope HD never adds a 6th gear.
2003 100th Anniversary V_Twin_Racing_Street_Custom_A_Model_V-ROD
Iceberg Blue 8K H.I.D. Conversion
Progressive Suspension
Sundowner
Fender Base Plate/Low Sissy Bar/Luggage Rack
UE Trick Tank
Keyless Ignition Upgrade
Slipper Clutch
Drilled Belt Guards
Superchicken covers
100th Anniv. Windshield
Topless
SE2 Cams
Chromex Coated CFR
Amsoil
Metzeler
Screamin Eagle Race Tuner
rippie74 is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
