Where are you routing your side-mount license plate LED wire? - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Go Back   1130cc.com: The #1 Harley Davidson V-Rod Forum > Specific Model > VRSCDX
Reply
Thread Tools Display Modes
Old 04-24-2012, 09:26 AM   #1
thapr3dat0r
V-Rocket
Feedback Score: 0 reviews
I just installed a side mount license plate and noticed several people run them also. I have a few ideas about where I can route the wire but want to see what others have done. Obviously looking for the cleanest install with the wire not showing.
Thanks in advance
2012 VRSCDX 10th Anniversary Edition - Chrome/Silver
thapr3dat0r is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-24-2012, 10:40 AM   #2
mardymac42
ramma jamma
mardymac42's Avatar
Images: 5
Garage
Feedback Score: 6 reviews
not showing.....duct tape to bottom of swingarm for me! then zip-tied to frame up beside gas tank
'03A27.5kMi
LEFT EARDRUM DAMAGE THX TO MYCAR47562
topless
K&N, stealer flash>pc3, homegrown 2 into 1, diy flange tool, Reactors & .99 matching pulley, 28T
mardymac42 is offline   Reply With Quote
Old 04-24-2012, 02:46 PM   #3
tswcoaltrain
coaltrain
tswcoaltrain's Avatar
Feedback Score: 1 reviews
Through the left side of the swing arm. There are two rubber plugs in the arm. One in the front inside face and one near the left rear inside of the swing arm. In order to get your wire through the swing arm first pull the plugs out, blow compressed air through the front hole while feeding a piece of string through the hole. The air will force the string through he swing arm and out the rear hole, then tie your wire to the string and pull the wire through the swing arm and route wire between frame and gas tank on left side.
2009 VRSCDX: Tab slash cut baffled slip ons, TAB fueler,topless, drag bars, Cut rear fender, Flipped mirrors, Turn run light module, Toxic inc 1 1/2" front lowering kit, cut 1 1/4" rear factory spring, lowered front head light, Avon 250 rear tire, side mount license plate.
tswcoaltrain is offline   Reply With Quote
Old 04-24-2012, 04:11 PM   #4
mnerren
Registered Abuser
mnerren's Avatar
Images: 86
Garage
Feedback Score: 3 reviews
I went through swing arm as described above too.
2002 VRSCA
2012 Street Glide
mnerren is offline   Reply With Quote
Old 04-25-2012, 05:34 AM   #5
thapr3dat0r
V-Rocket
Ok, I did see those two plugs on the inside of the swingarm. That's a very clever method. I was thinking about using a magnet somehow. Thanks!!
Old 04-25-2012, 05:39 AM   #6
thapr3dat0r
V-Rocket
One more question. Where did you guys tap the wires into? The factory license plate light wire? My electrical skills are lacking.
Old 04-25-2012, 09:02 AM   #7
tswcoaltrain
coaltrain
simply tie into the wire under the rear pillion that goes to (or went to ) to factory license plate bulb. This way the new license plate frame will function like the factory one did. Keep in mind that if you use a LED license plate frame that the polarity must be correct or the LED's will not work.
Old 04-25-2012, 09:26 AM   #8
thapr3dat0r
V-Rocket
Quote:
Ok, got it. So you removed the rear seat to access the wire?
Old 04-25-2012, 01:04 PM   #9
tswcoaltrain
coaltrain
Correct. just remove the rear pillion seat.
Old 04-25-2012, 02:40 PM   #10
thapr3dat0r
V-Rocket
Got it, thanks!
Old 07-15-2012, 07:16 PM   #11
hksigman
Registered Full
hksigman's Avatar
Garage
anyone know if this will work for a 2012?
[SIGPIC][/SIGPIC]
2005 Silver Roadking
2006 Black Deluxe
2007 Orange Roadglide
2012 Denim Black Night Rod
hksigman is offline   Reply With Quote
Old 07-15-2012, 07:36 PM   #12
_R_
Registered Full
_R_'s Avatar
my plate is mounted on the lower shock bolt and the wires go behind the shock and are zip tied to the left shock.
[SIGPIC][/SIGPIC]
_R_ is offline   Reply With Quote
Old 07-16-2012, 01:42 PM   #13
63echo
Registered Full
63echo's Avatar
Garage
Feedback Score: 2 reviews
Quote:
Sure will!
63echo is offline   Reply With Quote
Old 07-16-2012, 02:39 PM   #14
akakillroy
H VROD 5
I can find the rear inside grommet on the swing arm (VRSCB 05') but I can't find anywhere to get it our on the front of the swing arm.
akakillroy is offline   Reply With Quote
Old 07-16-2012, 02:56 PM   #15
pday
(Peter)
pday's Avatar
Images: 3
My current Hog Pro swing arm doesn't have the same access holes that my old stock one does so I ran the wires down behind the inner fender then out to the right side of the swing arm (my plate is one the right). then I ran it through the same retaining clip that the rear brake line goes through and out to the plate in a plastic sheeth.
Peter Day
pday is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
