Stage II Cams Driveability Review - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Go Back   1130cc.com: The #1 Harley Davidson V-Rod Forum > V-ROD Discussions > V-ROD Hi-Performance
Reply
Thread Tools Display Modes
Old 04-16-2012, 07:48 PM   #1
Dr Dave
Buy American!
Dr Dave's Avatar
Images: 93
Feedback Score: 3 reviews
Post Stage II Cams Driveability Review
I've been searching for a review of the driveability of the Screamin Eagle cams to no avail. I've seen the dyno sheets and they're very impressive, but we don't ride our bikes on the dyno.
IF YOU OWN THESE CAMS, please comment on the street-ability of your bike now vs stock cams:
Is it hard to start?
Does it pull better down low, mid range, upper RPM?
Does it run rough?
Does it stall?
Does it suck gas?
Is it noisy?
Does it run hotter?
Is it smooth?
Is it a mistake for the commuter to use these cams?
Are they worth the money ($400 + install + dyno tune) to you?
Dr Dave is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-16-2012, 08:41 PM   #2
dmirod
liquid smooth
dmirod's Avatar
Feedback Score: 0 reviews
Street ability is good. I've put 1000 miles on since getting the cams installed. No issues with hard starts or getting hot. It pulls hard in upper rpm range. I get between 29 and 32 mpg depending on how hard I ride. My dyno numbers were 114hp and 77tq before cams. After cams they went up to 133hp and 83tq. Definitely worth the money for an increase of 19hp and 6tq at the back wheel.
Sent from my Motorcycle iPhone app
dmirod is offline   Reply With Quote
Old 04-16-2012, 08:53 PM   #3
TEAZZR
I Hate Stupid People
TEAZZR's Avatar
Is it hard to start?No
Does it pull better down low, mid range, upper RPM?The way mine is set up.. Mid - High Rpm
Does it run rough?A little rumble , not rough
Does it stall?No
Does it suck gas?The way I ride. YES !! Hitting Nitrous & High Rpm's I get about 20 - 25 miles to the gallon. I have mine set rich for the nitrous
Is it noisy?They are noisy. But can't hear when I'm above 5500 Rpm's due to Vance & Hines Slip -ons.
Does it run hotter?I haven't noticed
Is it smooth? Compared to Stock.. No . More Beefy feeling.
Is it a mistake for the commuter to use these cams?Thats definately a personal choice
Are they worth the money ($400 + install + dyno tune) to you?Worth the money to Purchase YES.. I Did my own install and Created my own Maps
2011 Muscle :
SE Stage II cams
58mm Destroyer TB
6.37 g/s Fuel inj.
Vance & Hines Comp. Slip-Ons
SEPST
K&N Cones - Topless
BOSS NOSS - Stealth system
TEAZZR is offline   Reply With Quote
Old 04-16-2012, 09:05 PM   #4
grimy
Registered Full
grimy's Avatar
Subscribed.
I've read of airheads installing cams themselves, is this possible? Obviously a dyno would still be needed. Any "how to's"?
Would the 26t help with the low end torque and cams for high end power?
Semper Fi
USMC Sgt 2004-2012
08 VRSCDXA-PCV+Autotune-BUB 7-Topless-SE AF-26T Fitz pulley-Progressive 440 Rear-Progressive Fork Springs-SE Fork Oil-VRSCA Bars-Superbrace-Ron's Fork Covers-Fork Boot Covers-Joker Shift Linkage-Joker Bar End Mirrors-Performance Machine Grips-Heat Demons-KillerGlass-DDM HID Kit-Kurykan ISO stirrup pegs-Sundowner Seats f/r-Powerlet Plug
grimy is offline   Reply With Quote
Old 04-17-2012, 12:01 AM   #5
pecee
Registered Full
pecee's Avatar
Feedback Score: 4 reviews
my set up gives me more low mid range torque. using thundermax at the mo but converting to daytona tt as soon as ive a chance to do it.these cams are quite streetable.unfortunately it now sucks gas.on a brisk ride i use 1/3 more gas than a k13r.same speeds.when i compare the gas consumption to any other bike its quite sobering.takes the buzz right off.
pecee is offline   Reply With Quote
Old 04-17-2012, 02:40 AM   #6
FABSTER
GFYS
Images: 23
Feedback Score: 33 reviews
Dave, how's your riding style? If you like to crank up the throttle from time to time (or all the time like some of us ) then you should install them definitely! It's a mid-high RPM improving mod, so you'll get the best of it if you like to ride your bike hard.
Old 04-17-2012, 04:21 AM   #7
Hadye
The Pharoah Rider
Hadye's Avatar
Images: 10
OK, consider me the Newbie of this thread. read many threads that PCV doesn't work with Stage II cams, so it is a must to have SEPST?
[SIGPIC][/SIGPIC]
Hadye is offline   Reply With Quote
Old 04-17-2012, 06:00 AM   #8
kcmc
Registered Full
kcmc's Avatar
Feedback Score: 1 reviews
kcmc is offline   Reply With Quote
Old 04-17-2012, 07:09 AM   #9
VrodPete
Elephant Motors Rock
VrodPete's Avatar
Images: 23
TEAZZR gave you all the answers I would give you.
I had the cams in before I did the stroke, and thought it was WELL worth the money. At idle you will get more of that long duration cam "lope" in the motor, and a lot more chatter from the TB blades. After that it's all GRINS. Smaller power gains down low, bigger up top - the motor really comes alive around 4500RPM.
That additional noise you're hearing? That's YOU hollerin'.
I had mine tuned with the Mastertune - no flat spots and a big pull all the way up to my 9400 RPM redline.
'08 VRSCAW
1402 Oilman Elephant Motor - Fitzgerald Motorsports Style
(Fourteen-Oh-Twous Copicaticus)
HD SE II Cams, 3/8" Falicon Crank, Carillo Rods, CP Pistons, DA Fitz Engine Brace, Destroyer Injectors, Doherty oil pan, DA Fitz Head Port/Polish/+1mm Valves+springs, DA Fitz 58mm TBs, ARP studs, V&H 2nd Gear+Shift Shaft, Motohouligan Airbox, Wegner 2->1 Exhaust with Supertrapp V5
152.77 HP, 101.06 TQ
Other Toys: '01 BMW K1200LT, '76 Honda CB550F, '81 Mooney M20J
VrodPete is offline   Reply With Quote
Old 04-17-2012, 07:26 AM   #10
rippie74
1130cc is enuff 4 me
rippie74's Avatar
Images: 3
Feedback Score: 9 reviews
Quote:
Originally Posted by dr dave View Post
i've been searching for a review of the driveability of the screamin eagle cams to no avail. I've seen the dyno sheets and they're very impressive, but we don't ride our bikes on the dyno.
If you own these cams, please comment on the street-ability of your bike now vs stock cams:
Is it hard to start? No
does it pull better down low, mid range, upper rpm? Yes
does it run rough? No
does it stall? No
does it suck gas? Only if you twist your right wrist
is it noisy? No
does it run hotter? No
is it smooth? Yes
is it a mistake for the commuter to use these cams? No
are they worth the money ($400 + install + dyno tune) to you? Y.E.S!.
For me... The best way I can describe it is.. It's like having a Big Block Chevelle between your legs.
BEFORE:
AFTER:
2003 100th Anniversary V_Twin_Racing_Street_Custom_A_Model_V-ROD
Iceberg Blue 8K H.I.D. Conversion
Progressive Suspension
Sundowner
Fender Base Plate/Low Sissy Bar/Luggage Rack
UE Trick Tank
Keyless Ignition Upgrade
Slipper Clutch
Drilled Belt Guards
Superchicken covers
100th Anniv. Windshield
Topless
SE2 Cams
Chromex Coated CFR
Amsoil
Metzeler
Screamin Eagle Race Tuner
rippie74 is offline   Reply With Quote
Old 04-17-2012, 12:07 PM   #11
santeg
Fah q 2
santeg's Avatar
Images: 31
the best hp for the money,after a year i still grin when i hammer it, as for mpg, all depends on your wrist,
these motors should of came from the factory with these babies.
Motor oils are like women. There are all different types, but most do a good job of lubing your crank.
santeg is offline   Reply With Quote
Old 04-17-2012, 07:13 PM   #12
rsc
Killer Service Inc.
rsc's Avatar
Images: 1
Garage
Feedback Score: 8 reviews
Take my word for it:
Leave it stock!!!!!
2003 turbo
2012 Ultra Classic
V-rod mechanics 101:
Old 04-17-2012, 07:36 PM   #13
ncvrodracer
Registered Full
ncvrodracer's Avatar
Images: 38
Feedback Score: 16 reviews
Is it hard to start? No, but I keep mine on a battery tender
Does it pull better down low, mid range, upper RPM? Mid and Upper
Does it run rough? No
Does it stall? No
Does it suck gas? Little more, because you will be twisting it more
Is it noisy? Little bit, but in a good way..
Does it run hotter? nope
Is it smooth? yes
Is it a mistake for the commuter to use these cams? I dont think so...
Are they worth the money ($400 + install + dyno tune) to you? YES
Best To Date
1.53 60 foot
6.793 1/8 mile
102.180 mph
New member 10 second club..
10.713 1/4 mile
123..17 mph
"Now Your Using Your Clutch Management Jimmy"
A Ninja V-rod.....
ncvrodracer is offline   Reply With Quote
Old 04-17-2012, 09:15 PM   #14
pfbmgd
Registered Full
pfbmgd's Avatar
Feedback Score: 5 reviews
How many hours shop time to install the cams .
2008 VRSCDXA
Thundermax
Rinehart 2-1
Topless
Avon tires
Progressive springs front
Progressive 444 rear
pfbmgd is offline   Reply With Quote
Old 04-18-2012, 01:49 AM   #15
bogie
VRSCF
bogie's Avatar
Images: 3
Garage
Quote:
usually quoted 4 hours + dyno time, so best part of a day, at least 7 hours ...still thinking about it myself, got some other things on the list to do first
cheers
bogie
bogie is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
