Going Turbo, with help from you experts! - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Go Back   1130cc.com: The #1 Harley Davidson V-Rod Forum > V-ROD Discussions > V-ROD Big Bore/Turbo/SC/NOS area
Reply
Thread Tools Display Modes
Old 03-21-2012, 01:00 AM   #1
Pono
Registered Full
Pono's Avatar
Feedback Score: 0 reviews
So I have been checking out heaps of the threads on here and doing a little research on a turbo for my 2010 muscle. I want to build something similar to the Trask kit available and would appreciate any help I can get with it. I only just decided last couple days to actually attempt it as I got hold of a fabricator who is willing to make me a plenum, manifold and exhaust!!
This wont be an overnight project as the bike is allready stripped for paint/powdercoating but hoping to have it finished over the next 2-3 months. Reason I am not going a ready made kit is.. well $$$$$..
*Im going to go with a garrett gt2554r or possibly gt2860r
*Im planning to get a v-band connector for the outlet to suit a 3" exhaust.
*making exhaust connect to a silencer mounted to the stock muffler mound.
Anyhow, the first query I have is about the plenum. I put a pic up of what I think is a Trask plenum and circled/lettered the hose connections on the plenum and would like to know were they each go. Also I read that a 'v' channel is used inside the plenum to regulate air flow... Is that right?
Any help would be great!! Cheers guys!
Pono is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-21-2012, 01:09 AM   #2
Ozracer
Night Rod Muscle
Ozracer's Avatar
bold move pono good luck mate....
2011 Night Rod Muscle
Build:
Ozracer is offline   Reply With Quote
Old 03-21-2012, 01:19 AM   #3
Pono
Registered Full
Pono's Avatar
Thanks mate Im sure Ill need it. .
Old 03-21-2012, 01:30 AM   #4
Karzza
all or nothing
Karzza's Avatar
Images: 2
Garage
I would prefer gtr2560 if you will stay below 16Psi.
300rwhp, E85 fuel
Falicon +3/8" full circle, K1, ceramic CP 4.25" pistons
Pinned cases, ARP 12mm head and main studs
Jones cams, SuperAlloy valves, titan retainers, Ferrea springs
Turbo Garret GT2860R, water cooled, Tial-housing
16 Psi Tial waste gate, Forge BOV, Treadstone IC
Bosch 190lb/hr injectors, Wabro 330lph pump
Bosch 5bar fuel regulator
Daytona VRFIgen3 ECM, Delphi 3bar MAP.
11 plates carbon fibre, billet basket, billet lifter plate
Str cut 2nd,
K&M plenum and -brace
Karzza is offline   Reply With Quote
Old 03-21-2012, 01:41 AM   #5
Pono
Registered Full
Pono's Avatar
planning on staying well below 16psi with stock internals...Crazy figures Karzza! WOW!!
Old 03-21-2012, 05:25 AM   #6
rsc
Killer Service Inc.
rsc's Avatar
Images: 1
Garage
Feedback Score: 8 reviews
a pressure hose to Boost Gauge and Fuel Regulator
b breather hose / feed to air intake filter or seperate catch filter.
c front case breather hose
d rear case breather hose
Square welded onto Cyinder is a oil catch from the cases and self drain back through the same hose.
Good Luck
2003 turbo
2012 Ultra Classic
V-rod mechanics 101:
Old 03-21-2012, 05:53 PM   #7
FABSTER
GFYS
Images: 23
Feedback Score: 33 reviews
Old 03-21-2012, 06:10 PM   #8
blumj88
ISU
blumj88's Avatar
Feedback Score: 16 reviews
2003 100th silver and black
Topless Amsoil Filter
VRFI3
CFR
blumj88 is offline   Reply With Quote
Old 03-21-2012, 07:25 PM   #9
rsc
Killer Service Inc.
rsc's Avatar
Images: 1
Garage
I want some ice cream.
2003 turbo
2012 Ultra Classic
Old 03-21-2012, 08:04 PM   #10
Demthios
To boost or not??
Demthios's Avatar
Images: 19
Feedback Score: 4 reviews
Demthios is offline   Reply With Quote
Old 03-23-2012, 04:35 PM   #11
00ttvr6
Registered Full
"Also I read that a 'v' channel is used inside the plenum to regulate air flow... Is that right"
08 DX
topless, filterless, f/r fenderless, guageless
signaless, beltguard delete, f/r air ride, grc seat, clipons Joker bar arm mirrors, RH 2/1
PCV, 250 Duncrap, xr1200 h/l trim
Custom side mount plate
Muscle wheels
04 Dyna
08 Duramax
09 G8 GT
00ttvr6 is offline   Reply With Quote
Old 03-23-2012, 05:06 PM   #12
ncvrodracer
Registered Full
ncvrodracer's Avatar
Images: 38
Quote:
Best To Date
1.53 60 foot
6.793 1/8 mile
102.180 mph
New member 10 second club..
10.713 1/4 mile
123..17 mph
"Now Your Using Your Clutch Management Jimmy"
A Ninja V-rod.....
ncvrodracer is offline   Reply With Quote
Old 03-23-2012, 10:50 PM   #13
Bruce Helland
Registered Full
Feedback Score: 3 reviews
The 'v channel' is just a length of angle welded in the plenum. If you are designing your own system consider reading up on plenum design. Lots of good information available.
Bruce Helland is offline   Reply With Quote
Old 03-24-2012, 07:29 AM   #14
Pono
Registered Full
Pono's Avatar
This is what I mean.
Old 03-25-2012, 12:26 AM   #15
Bruce Helland
Registered Full
That is the angle I was talking about. Due to the charge inlet position at the rear this angle is used to keep the rear cylinder from being 'overloaded'. Design a plenum with more even distribution and you can eliminate this obstruction.
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
