broken throttle shaft - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Reply
Thread Tools Display Modes
Old 03-10-2012, 04:08 PM   #1
pecee
Registered Full
pecee's Avatar
Feedback Score: 4 reviews
I had a failure on the front cyl throttle shaft yesterday.now i thought this problem was limited to the 58mm bore shafts but no.mine are still the standard 53mm bores but running stage two cams with powerline exh.firstly, i had a cracked head then this and am wondering weather these cams are worth the unreliability i am experiencing with this motor. i have over 50000km on these cams and 70000+ on the motor,not nearly enough to call it wear and tear.Are others out there having failures also with the standard shafts/ 53mm bores?
pecee is online now   Reply With Quote
Sponsored Links
Advertisement
Old 03-10-2012, 04:13 PM   #2
TaxmanHog
Noel
TaxmanHog's Avatar
Images: 277
Garage
Feedback Score: 2 reviews
2006 VRXSE Destroyer
VRD-941 & ET-943
60: 1.393
ET: 9.661
Mph: 139.34
Check Your Grounds
TaxmanHog is online now   Reply With Quote
Old 03-10-2012, 05:34 PM   #3
losNRS
Registered Full
losNRS's Avatar
Pecee, I have the same set up as you on my 08 Dx. However, I only have 30K miles on mine, and so far, have no problem with heads and/or throttle shafts. Also, I do ride my bike hard. The low mileage is do to splitting riding duties with a 93 Softail and a 91 FXR that eventually I sold to my buddy. A while back, I asked this same question to Scott (Ohio Vrod) and was told that no problem with the stock Tbodies. So far, that seems to be the case to my knowledge. Still, I check mine from time to time. I know this doesn't help much, wish I could give you more. Good luck, Bro.
losNRS is offline   Reply With Quote
Old 03-11-2012, 04:25 PM   #4
TEAZZR
I Hate Stupid People
TEAZZR's Avatar
Feedback Score: 0 reviews
Broken throttle shafts are caused by excessive vibrations/wear .. The buterflies were probably fluttering. With the miles on your bike & running the stage II cams I think it is just that. Service the upper end and replace the broken TB. ( I wouldn't fix it unless you rebuild the whole thing. )
2011 Muscle :
SE Stage II cams
58mm Destroyer TB
6.37 g/s Fuel inj.
Vance & Hines Comp. Slip-Ons
SEPST
K&N Cones - Topless
BOSS NOSS - Stealth system
TEAZZR is offline   Reply With Quote
Old 03-11-2012, 04:37 PM   #5
Karzza
all or nothing
Karzza's Avatar
Images: 2
Garage
I think that a long duration of stage II cams could have something to do with the saft failures. A low rpm compression pressure back flow (reversion) can cause some extra load and vibration for the safts.
300rwhp, E85 fuel
Falicon +3/8" full circle, K1, ceramic CP 4.25" pistons
Billet oil-pan, pinned cases and ceramic bearings, 12mm head and main studs
Jones cams, SuperAlloy valves, titan retainers, springs
Turbo Garret GT2560R, water cooled
16 Psi Forge waste gate and BOV, Valeo i-cooler
Black Ops 172lb/hr injectors, Wabro 255lph pump
Porsche tbo 5bar fuel regulator
Daytona VRFIgen3 ECM, KMS 3bar MAP.
11 plates carbon fibre lock-up, billet basket
Str cut 2nd,
K&M plenum and -brace
Karzza is offline   Reply With Quote
Old 03-12-2012, 03:39 PM   #6
Jan-Dirk
Autobanmod
Jan-Dirk's Avatar
Images: 361
Garage
Quote:
Hog of Steel
Jan-Dirk is offline   Reply With Quote
Old 03-12-2012, 10:54 PM   #7
SickRick
Lifetime Premium
SickRick's Avatar
Feedback Score: 3 reviews
Scott (OhioVRod) has also come up with a design to upgrade the shafts to thicker shafts to reduce/eliminate breakage. They tend to break at the screw, then drop the screw into the motor (NICE!).
Rick
'10 VRSCDX
Motor: V&H Heads/+1MM-V&H 2:1-SEII Cams-K&N Cones/Bypass - R&D Race Tranny/1:8 2nd/Ceramic Brngs
SEPST:139.87HP/87.1TQ
Rolling: Penske 8983NR/TD AK-20 Dual-Lyndall Rotors/Red+-Brembo P4/34 Calipers-BST CF's-Ceramic Brngs-Conti RA's- Microline Hydraulics
Looks: Polished SS Bolts-Rizoma Rearset/Pegs-Trucklite/LEDMirrors-LED Tail-BlueLED Gages-PVD Black Fork Tubes-Woodcraft Clip-Ons-NMC Windshield(s)-Cluster Relo- Valentine-1 - Blinder 905c
SickRick is offline   Reply With Quote
Old 03-12-2012, 11:39 PM   #8
o2man98
The 1402 Originator
o2man98's Avatar
Images: 67
Feedback Score: 106 reviews
Quote:
Better watch what you say. I suggested this way back and was kicked in the ass for it.
Independent AMSOIL Premier Direct Jobber
-E-mail me at
Call me at 920-860-0116 for ordering. Best times will be after 5pm weekdays or anytime weekends.
Contact me directly for forum member pricing as Authorized Dealers are not allowed to advertise discounted rates publicly.
Get DEALER COST immediately on your first order by following these instructions.
o2man98 is offline   Reply With Quote
Old 03-13-2012, 12:26 AM   #9
Karzza
all or nothing
Karzza's Avatar
Images: 2
Garage
Sorry, did I a technical or commercial mistake?
No meaning to scare anyone.
300rwhp, E85 fuel
Str cut 2nd,
Old 03-13-2012, 01:36 AM   #10
o2man98
The 1402 Originator
o2man98's Avatar
Images: 67
No no! It was a joke. In the past I suggested that it was a reverberation or harmonics issue and everyone argued that fact against me. I agree with you 100%.
-E-mail me at
Old 03-13-2012, 02:13 AM   #11
Karzza
all or nothing
Karzza's Avatar
Images: 2
Garage
ok, I'm not a native english, sometimes do not catch the message.
300rwhp, E85 fuel
Str cut 2nd,
Old 03-13-2012, 03:08 AM   #12
pecee
Registered Full
pecee's Avatar
I am lucky then ,the screw was just sitting there waiting to drop...Im going to look into welding the butterfly to the shaft as an experiment.
Old 03-13-2012, 11:25 AM   #13
ElrodontheV-Rod
durata membro
ElrodontheV-Rod's Avatar
Images: 9
Feedback Score: 5 reviews
Quote:
Would this be from the over-lap at idle ? Like at the split second the intake and exhaust are both opened,just before tdc,running pressure back up the intake and putting opposite force on the throttle blades.
I think this is why.cure would be stronger metal for the shafts,and or a larger diameter shaft.
ElrodontheV-Rod is offline   Reply With Quote
Old 03-13-2012, 07:32 PM   #14
pecee
Registered Full
pecee's Avatar
Yes ,you guys are all right as to the cause im sure.I have taken the old t/body to a master machinist and discussed the issue.He is of the belief that a full shaft slotted for the butterfly will be better than the original half shaft .he is going to make new shafts in that config for me.he wasnt too keen on using tool steel tho because he felt it wouldnt stand the vibrations and probably crack too.welding was not an option.he will screw and loctite the butterflys in.no peening.
Old 03-14-2012, 02:27 PM   #15
SickRick
Lifetime Premium
SickRick's Avatar
Quote:
I think Scott Tig's the screw to the shaft. Welding the butterfly to the shaft, would make this pretty much impossible to disassemble in the future.
Though I do like his idea of larger diameter shafts - which he pretty much does as part of his 58mm upgrade to stock TB's (which he can also upgrade on one's already done, and Destroyer TB's).
There is some reversion (if you want to call it that) from the higher lift/faster ramp/overlap of these cams - as evidenced by the seeming inability of (supposed) autotuners to cope with the intake charge "bleeding through" during overlap and causing the WideBands to freak out and lean the mix. Also the observation of how much noisier these cams are. There probably is more vibration and potential "puffing" against the back of the butterflies (at least more than with stock), putting extra stress on the shafts, causing premature breakage.
Rick
'10 VRSCDX
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
