Rear brake light switch - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Reply
Thread Tools Display Modes
Old 12-25-2010, 11:36 AM   #1
Jota69
Registered Full
Jota69's Avatar
Feedback Score: 3 reviews
My brake light is not working when I press the rear brake but it works when I use the front brake. I jumped the wires from the rear brake switch and the brake light turned on, so I think its a faulty brake switch.
How hard is it to change the brake switch and should I drain the brake fluid and replace it with new fluid too?
Jota69 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-25-2010, 11:49 AM   #2
sullivancorner
Lifetime Premium
Feedback Score: 11 reviews
Do a search for better aftermarket switch as there are several. You have to bleed it after you install the switch so you might as well drain fluid. Not too hard... Merry Christmas.
sullivancorner is offline   Reply With Quote
Old 12-25-2010, 02:19 PM   #3
photogger
Black Beauty
photogger's Avatar
Images: 19
Feedback Score: 5 reviews
Yep.... the switch is bad. Pretty common problem. Mine did the same thing - then started to leak. If you have any warranty left it should be covered, mine was.
'07 DX
PCIII
DDM HID
K&N/topless
Powerline exhaust
Fitzgerald 26T pulley
Progressive lowered front/rear
Blinding bright LED tail and turns
Black bling, and more black bling
photogger is offline   Reply With Quote
Old 12-25-2010, 02:53 PM   #4
taximech
Lifetime Premium
taximech's Avatar
Images: 42
I just changed mine, not very hard but I did have to remove most of the exhaust. I did not have to bleed the brake, good solid brake pedal and now a brake light, Skip
2008 VRSCDX
Vivid black with orange pearl
Tiger Racing Belt Guards, Dan's Grille Guards
Arnott Air Ride, Progressive Front Springs
Black Diamond Grips, Black Axle Covers
Many Parts Powdercoated
taximech is offline   Reply With Quote
Old 12-25-2010, 07:16 PM   #5
RustyG
Lifetime Premium
RustyG's Avatar
Images: 99
You may have to remove the exhaust depending on your year, model and exhaust system.
Just be careful. The brake lines into the junction block are just soldered in there and can break off real easy. You will buy a whole new brake line assembly if you screw it up.
Don't ask me how I know.
Regards,
John
Quote:
2007 VRSCX 0461 / 1400
2002 Road King Classic
Old 12-25-2010, 08:17 PM   #6
ElrodontheV-Rod
durata membro
ElrodontheV-Rod's Avatar
Images: 9
Even if you don't break the line,replace it with Goodrich lines because the splitter for the switch relocates the switch away from the heat.
ElrodontheV-Rod is offline   Reply With Quote
Old 12-26-2010, 06:45 AM   #7
Only 9MM
Registered Full
Only 9MM's Avatar
Feedback Score: 1 reviews
Very common problem. Mine on my 09 Softail went last month. Had to wait for replacement as they were back ordered there were so many bad. Mine was under warranty, you may want to check with dealer about warranty, recall or TSB issues. Maybe you can get yours replaced for free.
Only 9MM is offline   Reply With Quote
Old 12-28-2010, 06:45 PM   #8
MeRod
Function over Form
MeRod's Avatar
Just had mine replaced...was leaking brake fluid. Got mine from dennis kirk. It's bigger than the stock one, but much better.
http://www.denniskirk.com/jsp/produc...e=&skuId=20332
MeRod is offline   Reply With Quote
Old 01-01-2011, 07:51 PM   #9
10000rpm
Registered Full
10000rpm's Avatar
Feedback Score: 0 reviews
Hi MeRod, is the one shown in the link a direct replacement cos the description is for other HD models. Many thanks.
Yuri Orlov (Nicholas Cage's character in Lord of War): Every faction in Africa calls themselves by these noble names - Liberation this, Patriotic that, Democratic Republic of something-or-other. I guess they can't own up to what they usually are: the Federation of Worse Oppressors Than the Last Bunch of Oppressors. Often, the most barbaric atrocities occur when both combatants proclaim themselves Freedom Fighters.
10000rpm is offline   Reply With Quote
Old 01-01-2011, 08:00 PM   #10
AOW
AOW's Avatar
Images: 85
Feedback Score: 8 reviews
http://www.1130cc.com/forums/showthread.php?t=128854
SERVICE MANUAL!
embrace the "google search" function.... site:1130cc.com:
Quote:
Originally Posted by rjrivero
Nobody cares about your shit like you
Fuel gauge? We don't need no stinking Fuel gauge!!!
AOW is offline   Reply With Quote
Old 01-02-2011, 04:15 AM   #11
janoble08
Registered Full
Images: 2
Garage
i had to replace mine @15000 miles vrscdx, my dealer said it wasn't under warenty it didn't cost much however i didn't know it was broke.
janoble08 is offline   Reply With Quote
Old 01-03-2011, 07:41 PM   #12
MeRod
Function over Form
MeRod's Avatar
Quote:
Yes.....this is the direct replacement from denniskirk.com
I ordered this recently on Dec 9th
Old 01-04-2011, 12:28 PM   #13
Jota69
Registered Full
Jota69's Avatar
I got the accel brake switch and just changed the switch. Now My brake light works
Old 02-09-2011, 09:22 PM   #14
photogger
Black Beauty
photogger's Avatar
Images: 19
I just replaced my switch for the second time. 1st time the dealer replaced it with OEM part. Lasted about a year before acting up again - no light and leaking. This time I replaced it myself with a switch from Auto Zone. Duralast part # RB401, $8.99 with a lifetime warranty.
It's a little larger, but fits no problem. SCREW the dealer OEM CHEAP parts!
'07 DX
PCIII
DDM HID
K&N/topless
Powerline exhaust
Old 10-24-2011, 11:07 AM   #15
Siepel
BeerLand
Siepel's Avatar
Images: 4
Feedback Score: 2 reviews
A Dutch newspaper just published a report that H-D is recalling 300,000 vehicles world-wide in connection to faulty rear brake switches (due to excessive heat from the exhaust system). Interesting, since I just noticed a few weeks ago(!) that my switch is on its way out too!!
EDIT: Seems to be for FL platform only...
Manufacturer:
HARLEY-DAVIDSON MOTOR COMPANY
Mfr's Report Date:
OCT 19, 2011
NHTSA CAMPAIGN ID Number:
11V506000
N/A
NHTSA Action Number:
N/A
Component:
EXTERIOR LIGHTING:BRAKE LIGHTS:SWITCH
Potential Number of Units Affected:
250,757
Summary:
HARLEY-DAVIDSON IS RECALLING CERTAIN MODEL YEAR 2009-2012 TOURING, CVO TOURING AND TRIKE VEHICLES MANUFACTURED FROM JUNE 6, 2008, THROUGH SEPTEMBER 16, 2011. SEE THE ABOVE LIST FOR THE MODELS INCLUDED IN THE RECALL. THE REAR BRAKE LIGHT SWITCH MAY BE EXPOSED TO EXCESSIVE HEAT FROM THE EXHAUST SYSTEM.
Consequence:
THE EXCESSIVE HEAT MAY CAUSE THE SWITCH TO NOT ACTIVATE THE BRAKE LAMP OR ACTIVATE THE BRAKE LAMP WHEN NO BRAKE IS APPLIED AND/OR CAUSE A BRAKE FLUID LEAK AT THE BRAKE LIGHT SWITCH, AFFECTING REAR BRAKE PERFORMANCE. EITHER CONDITION MAY INCREASE THE RISK OF A CRASH.
Remedy:
HARLEY-DAVIDSON WILL NOTIFY OWNERS, AND DEALERS WILL A INSTALL A REAR BRAKE LIGHT SWITCH KIT, FREE OF CHARGE. THE SAFETY RECALL IS EXPECTED TO BEGIN ON OR ABOUT OCTOBER 31, 2011. OWNERS MAY CONTACT HARLEY-DAVIDSON AT 1-414-343-4056.
Notes:
HARLEY-DAVIDSON SAFETY RECALL NUMBER IS 0145. CUSTOMERS OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV
I love Leffe Blond
Siepel is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
