250 Avon or 260 Metz will fit. I have a 250 Avon on mine now.
________________________
Current 1402 Status and Checklist
Installed: HD SE II Cams, DA Fitz 58mm TBs
Delivered: 3/8" Falicon Crank, Carillo H-Beam Rods, CP Pistons M5078, DA Fitz Engine Brace, 5/16" fuel line, Destroyer Injectors, HP Fuel pump/sock, 1250 head gaskets, Eng. Gasket Set
Shipped:
Ordered: 5 bar fuel regulator, HD Case bolts, Ex Gaskets
To Do: , ARP head studs, Head Port/Polish/1mm Oversize Valves+springs, Pin bearings, 2nd Gear, Shift Shaft
