belt tension help ! - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Reply
Thread Tools Display Modes
Old 06-11-2010, 10:48 AM   #1
nfn
Registered Full
nfn's Avatar
Images: 8
Feedback Score: 0 reviews
belt tension help !
Hi all,
had new tyre put on by HD dealer drive belt was quite tight (as per normal) done around 60 miles and its a lot looser now ?
it can be moved from the top to bottom of the lower guard adjustment marks
is this normal ? or has the axle moved forward a touch because its not tight enough ?
any advice would be great.
NFN "NO F*CKING NONSENSE
2008 DX (ABS) tag "SO BAD"
Digitek USB charger
Digitek Power gauge
Digitek integrated Smart Signals 5-1
arnotts air ride/Exotic rear fender
HID's
fork sleeve's
VH Comp 2-1
VH fueler-KN air filter
Rev-shift light
Topless/horn upgrade/powder coated controls
custom mirrors/AW rear seat
Garmin 660/Amsoil/side mount
MS biketec 4" extended controls
Rad grills
Text Alert
VRSCX fatbars
SE fork oil
Diamond grips
El cheapo heated grips
mod belt guards
nfn is offline   Reply With Quote
Sponsored Links
Advertisement
Old 06-11-2010, 10:52 AM   #2
redracer95
Registered Full
redracer95's Avatar
Images: 45
Feedback Score: 18 reviews
i don't think the dealer tighten the axle to proper torque spec. and did not check the belt for proper tension. jmo
redracer95 is offline   Reply With Quote
Old 06-11-2010, 10:53 AM   #3
Gdub
Registered Full
Gdub's Avatar
Images: 80
Feedback Score: 7 reviews
I have always heard if you can take the belt and twist it, so it is basically vertical instead of horizontal, it is about right. See if the axle nut is tight.
Gdub is offline   Reply With Quote
Old 06-11-2010, 11:07 AM   #4
redracer95
Registered Full
redracer95's Avatar
Images: 45
rear axle nut torque spec for a 2007 dx- 190-203Nm/140-150ft-lbs.
rear belt deflection from section 1 page 30
with 10# of upward force, verify that the belt deflects 8mm or about 5/16-3/8"
with no rider on motorcycle
Old 06-11-2010, 11:19 AM   #5
stever975
Super Moderator
Images: 22
Feedback Score: 1 reviews
Quote:
Originally Posted by nfn View Post
...had new tyre put on by HD dealer drive belt was quite tight (as per normal) done around 60 miles and its a lot looser now ?
is this normal ? or has the axle moved forward a touch because its not tight enough ? ...
Don’t ride the bike as is. You’ll ruin the belt if it jumps sprocket teeth.
If you don’t have a torque wrench to tighten the axle nut to 140 to 150 ft•lbs (190 to 203 Nm) and a belt tensioning tool then have the knuckle heads that installed the tire (tyre) pick up the bike and fix it.
The twist technique for testing belt tension is better than nothing but there’s two things wrong with it
  1. you shouldn’t twist a polychain drive belt (or bend it backwards) according to the manufacturers cautions
  2. you can’t be sure what the tension is using this technique
stever975 is online now   Reply With Quote
Old 06-11-2010, 11:45 AM   #6
Gdub
Registered Full
Gdub's Avatar
Images: 80
This is a good read if you don't want to buy a tool.
http://www.1130cc.com/forums/showthr...ght=belt+specs
Old 06-11-2010, 01:04 PM   #7
NRA-LIFER
Registered Full
I found this. It looks like a 10# tool with the numbers so you don't need the belt guard.
1.)http://www.denniskirk.com/jsp/produc...utm_medium=cse
2.)http://www.toolsource.com/belt-tensi...e-p-99899.html
I do not have this tool. I don't know anything about the quality or manufacturer. I am not 100% sure that this is the right tool for a v rod, so someone with more knowledge please check it out. Thanks
NRA-LIFER is offline   Reply With Quote
Old 06-11-2010, 01:06 PM   #8
VrodPete
Elephant Motors Rock
VrodPete's Avatar
Images: 23
Feedback Score: 3 reviews
Either of those tools would work.
'08 VRSCAW
1402 Oilman Elephant Motor - Fitzgerald Motorsports Style
(Fourteen-Oh-Twous Copicaticus)
HD SE II Cams, 3/8" Falicon Crank, Carillo Rods, CP Pistons, DA Fitz Engine Brace, Destroyer Injectors, Doherty oil pan, DA Fitz Head Port/Polish/+1mm Valves+springs, DA Fitz 58mm TBs, ARP studs, V&H 2nd Gear+Shift Shaft, Motohouligan Airbox, Wegner 2->1 Exhaust with Supertrapp V5
152.77 HP, 101.06 TQ
Other Toys: '01 BMW K1200LT, '76 Honda CB550F, '81 Mooney M20J
VrodPete is offline   Reply With Quote
Old 06-11-2010, 07:59 PM   #9
NRA-LIFER
Registered Full
Quote:
Thanks VrodPete
Old 06-11-2010, 08:51 PM   #10
RustyG
Lifetime Premium
RustyG's Avatar
Images: 99
Feedback Score: 11 reviews
According to my service manual (2007) belt deflection should be 8MM (10 for the VRSCR).
Belt deflection window on the belt guard is graduated in 2MM increments. Deflection is measured with 10lbs(4.5kg) force on belt.
Regards,
John
Quote:
2007 VRSCX 0461 / 1400
2002 Road King Classic
Old 06-11-2010, 09:37 PM   #11
rsc
Killer Service Inc.
rsc's Avatar
Images: 1
Garage
Feedback Score: 8 reviews
Video in 101 link...see sig.
2003 turbo
2012 Ultra Classic
V-rod mechanics 101:
Old 06-12-2010, 02:12 PM   #12
nfn
Registered Full
nfn's Avatar
Images: 8
great thanks
dealer had it today and they were working on it for a while he came out and said he adjusted it 3 times and the still moved as if it needed more on the torque wrench but he did not want to do that ? , he said he cleaned all the grease off the cam ? and had done it and was confindent that it "should be ok" but had marked the left side cam adjuster with the swingarm "nipple" and asked me to ride it and see if the mark moved , if so i needed a new axle shaft , nut and cam.
well i rode it hard for around 80miles and the mark has not moved , so would think its good to go ! but i cant understand why they had a such a job to get it to stay put ? this is the third time they have tried now !
my fear is there is something wrong , although i dont know what and that the next time the wheel has to be removed them or someone else is going to have the same issues ? as my warranty runs out in a few months
all they did was replace the rear tyre !
any advice as to what to do ?
Digitek USB charger
Digitek Power gauge
HID's
fork sleeve's
VH Comp 2-1
Rev-shift light
Rad grills
Text Alert
VRSCX fatbars
SE fork oil
Diamond grips
mod belt guards
Old 06-12-2010, 03:10 PM   #13
ElrodontheV-Rod
durata membro
ElrodontheV-Rod's Avatar
Images: 9
Feedback Score: 5 reviews
Stay away from that Harley dealer.It's quit evident from them ignorantly telling you you need a new axle that they don't want to work on your Harley.
Ride it for a few days,destroy the belt,then they can sell you a belt on top of a new axle.
God man,how in the **** can an axle wear out?
Do the work to your motorcycle yourself.
ElrodontheV-Rod is offline   Reply With Quote
Old 06-12-2010, 04:52 PM   #14
nfn
Registered Full
nfn's Avatar
Images: 8
its under warranty so costing them !
what i cant understand is why would they have trouble setting it up?
why would the axle not tighten enough to stay put ?
Digitek USB charger
Digitek Power gauge
HID's
fork sleeve's
VH Comp 2-1
Rev-shift light
Rad grills
Text Alert
VRSCX fatbars
SE fork oil
Diamond grips
mod belt guards
Old 06-12-2010, 05:24 PM   #15
ElrodontheV-Rod
durata membro
Images: 9
It doesn't cost a dealer to do warranty repairs.They get paid for it,that's besides the point.Please tell me what replacing an axle will accomplish?
The axle wouldn't tighten because the person that attempted to work on your motorcycle didn't know what he was doing.
Now we'll hear that he was the trained V-Rod mechanic.
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
