Side mount license plate option. - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Reply
Thread Tools Display Modes
Old 02-03-2010, 11:10 PM   #1
4stroker
I'd rather be riding
4stroker's Avatar
Images: 1
Feedback Score: 0 reviews
What do you think of this plate holder? It seems like the same production as some models that are 2-3 times more expensive. http://www.demonscycle.com/Lights-an...70320-2-1.html
**SOLD**2006 Yellow SE, Arnott's air ride, Heavycycles LED stage 2, PCIII, VMOD pipes.
4stroker is offline   Reply With Quote
Sponsored Links
Advertisement
Old 02-04-2010, 09:10 AM   #2
killerVRod
Registered Full
killerVRod's Avatar
Images: 15
Feedback Score: 16 reviews
I think I have seen it on ebay even cheaper. Like $80...
Present : 2013 NRS with AlteredStateDesign controls,sidemount, lights,headlight holder, sprocket cover, handlebars.
Past : Custom Lapis Blue V-Rod (Rick's 240 Lector wheel setup,chrome swingarm,Rizoma bars,signal relocators,LED rear lights,V-mod pipes,Custom cut sidemount plate,11.5" SmoothRide shocks,spike grips,Custom cut mirrors, 3" tribal forward controls)
killerVRod is offline   Reply With Quote
Old 02-04-2010, 09:50 AM   #3
4stroker
4stroker's Avatar
Images: 1
Quote:
Nice billet aluminum? I've only seen the cheapos but I've seen some posted on here for almost $500 that look like the same thing. I don't want to drop that much on a side plate but don't want a piece of crap either.
Old 02-04-2010, 10:16 AM   #4
killerVRod
Registered Full
killerVRod's Avatar
Images: 15
Quote:
Sorry I didn't realize it was billet! That is a good price!
-Keith
Old 02-04-2010, 10:17 AM   #5
Jethro_3
In the Shark Tank!!!
Jethro_3's Avatar
Images: 69
Feedback Score: 29 reviews
Check out GRCustoms, I think for theprice and quality the sidemount vertical turned out nice on my bike.
Jethro_3 is offline   Reply With Quote
Old 02-04-2010, 10:34 AM   #6
jsims002
Registered Full
jsims002's Avatar
Images: 128
Feedback Score: 5 reviews
I have the Anodized black one, it's quality. Not sure why the black one cost more. I should have got the chrome one and painted it. I dig it though. You'll need to get a longer axle or grind about 1/4" off the mounting bracket where the axle bolt goes through so you can get the axle nut on to be able to put the safety clip back on.
IT'S BLACK
Best quote EVER!!!
Quote:
Probably one of those deals that you ask 10 guys and get 10 different answers. I'm keeping what I have. I like the look, I like the sound. I don't think you would ever notice the difference on the street. Maybe on the dyno, but I don't ride there.
jsims002 is offline   Reply With Quote
Old 02-04-2010, 11:11 PM   #7
4stroker
4stroker's Avatar
Images: 1
Quote:
How about mounting on the lower shock bolt?
Old 02-05-2010, 06:47 AM   #8
killerVRod
Registered Full
killerVRod's Avatar
Images: 15
I think that if you want it to look perfect it has to go on the axle since it is a radius mount and the center of the radius is at the mount hole. Otherwise the radius of the plate won't match the radius of the pulley. It would be a half an inch higher...
-Keith
Old 02-05-2010, 10:40 AM   #9
4stroker
4stroker's Avatar
Images: 1
-Keith
That makes sense. Thanks.
Old 02-06-2010, 07:30 PM   #10
jsims002
Registered Full
jsims002's Avatar
Images: 128
Yep, no go on the shock mount, tried it. I didn't fit and it looked stupid there.
Grinding it down was pretty simple though. A grinding wheel or table saw with a grinding blade does the trick. I put the bracket against the swingarm and traced the swingarm with a sharpie.
I also cut out the axle cover so it forms around the plate mount bracket.
IT'S BLACK
Best quote EVER!!!
Old 02-06-2010, 08:50 PM   #11
POWERSTROKEN
Trouble Maker
POWERSTROKEN's Avatar
Images: 14
Feedback Score: 1 reviews
This is what I did to mine as I didn't want to drop $300 on the only one I found for mine. http://www.1130cc.com/forums/showthread.php?t=132947 I am not sure if this is something youd like? Or if you frames even the same as mine? I had to drill NO HOLES. Thanks Jim
ASK ME ABOUT TYSON'S POWDER COATING SERVICES AVAILABLE ON THIS FORUM and how he screwed up my swingarm and wont stand behind his work.
2009 VRSCFX NRM
Vivid Black, SEPST, V & H Indy Comp Pipe, K&N, Topless/Open Vents, Progressive front's, Ceramic bearings, Avon's 250, HID's, Hi/Low Mod, Killerglass/Braided hose
POWERSTROKEN is offline   Reply With Quote
Old 02-06-2010, 10:16 PM   #12
akousticplyr
'03 VRSCA
akousticplyr's Avatar
Hey bud-
I just finished putting this one on the bike about 15 min ago.
http://cgi.ebay.com/ebaymotors/SIDE-...16236007r23451
What's good: seems pretty good quality in chrome and has a Radiantzs logo stamped into the metal on the backside, so that says something good for it. Easy to install on the lower shock mount bolt (provided you can get the damn bolt off, I'll tell you that story later).
What's bad: it came in a US postal box without any mounting hardware. I emailed sales@lmcycles.com and so far N O T H I N G.
I went to ACE hardware to get some stainless screws and bolts...so far so good and pretty easy. You can see it when we get together for a ride.
akousticplyr is offline   Reply With Quote
Old 02-07-2010, 10:36 AM   #13
4stroker
4stroker's Avatar
Images: 1
How did you run your wires? I think I see part of your wire below but did you run it along backside of swingarm or what?
Old 02-07-2010, 11:19 AM   #14
Demthios
To boost or not??
Demthios's Avatar
Images: 19
Feedback Score: 4 reviews
So question for all of you guys that have your plate mounted on your shock, the only ones that I'm seeing on ebay are like 3/4" and 1" diamater holes made for swingarms what would the correct size be for the shock bolt??
Demthios is offline   Reply With Quote
Old 02-07-2010, 11:37 AM   #15
DEW
I DON,T KNOW WHY
DEW's Avatar
Images: 48
made my own think it looks good for a home made jobI( in my pics)
2007 VRSCDX VIVID BLACK
HDBLACK DIAMOND GRIPS,SHIFTER,PEGS
BIGSHOT FUELER
THUNDERHEADER
K&N AIR FILTER
ARNOTT AIR SHOCKS
DEW is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
