Help! Cam Timing is Off! - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Reply
Thread Tools Display Modes
Old 01-18-2010, 05:33 PM   #1
Dr Dave
Buy American!
Dr Dave's Avatar
Images: 93
Feedback Score: 3 reviews
Exclamation Help! Cam Timing is Off!
I don't know how I did it, but my cam timing is off. I just did a valve lash adjustment and everything was going perfectly until I checked the cam timing. I don't even know why I checked it because I am truly confident that I did everything exactly by the book. I never rotated the engine with either tensioner out.
It isn't even like only one cam is off, both cams are off (retarded) in the rear cylinder.
Anyone who has done this check, please verify my findings. These following two pics were taken with the Crankshaft Alignment Pin (size P drill) in place.
Front Cylinder Timing Marks:
Rear Cylinder Timing Marks:
As you can see in the lower picture, the rear cylinder cams both need to rotate CCW for the marks to align. How did this happen? Is there any way that there is so much slack in the cam chain that it skipped a tooth with the tensioner removed?
Dr Dave is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-18-2010, 06:00 PM   #2
TaxmanHog
Noel
TaxmanHog's Avatar
Images: 277
Garage
Feedback Score: 2 reviews
Here was my cam timing, before I started the 2007/2008 BB rehab project, you may want to check the tripple sprocket to base line where that is too:
http://www.1130cc.com/gallery/files/...6_original.jpg
Front Sprocket timing:
http://www.1130cc.com/gallery/files/...t_original.jpg
Rear Sprocket timing:
http://www.1130cc.com/gallery/files/...r_original.jpg
2006 VRXSE Destroyer
VRD-941 & ET-943
60: 1.393
ET: 9.661
Mph: 139.34
Check Your Grounds
TaxmanHog is offline   Reply With Quote
Old 01-18-2010, 06:05 PM   #3
TaxmanHog
Noel
TaxmanHog's Avatar
Images: 277
Garage
Did you need to pull the rear cams to change shims??
It's tricky pulling & returning the cams & keeping the orientation correct.
I think the only way this could have happened is that the engine was rolled backward at the crank or while in gear by the rear wheel.
VRD-941 & ET-943
60: 1.393
ET: 9.661
Mph: 139.34
Check Your Grounds
Old 01-18-2010, 06:34 PM   #4
Big Will
Hi... I'm Big Will
Big Will's Avatar
Images: 11
Feedback Score: 7 reviews
Have you rolled the engine any? You may need to keep rolling it to get all the dots and links to line up. It's something like 60 turns. It can be deceptive.
2005 VRSCSE
2006 Cub Cadet LT1042
Go Pokes!
WHO-DEY all the way!
5:30 a.m. Club ..... Mostly because we can .....
Big Will is offline   Reply With Quote
Old 01-18-2010, 06:34 PM   #5
Dr Dave
Buy American!
Dr Dave's Avatar
Images: 93
Thanks Taxman
Quote:
Yes, I lifted the cams. One at at time, one tappet removed at at time. The chain remained in contact with the cam sprocket at all times- each time that I moved a cam. The magic marker alignment marks that I put on each cam sprocket and the adjacent chain were still aligned when I replaced the cams and tightened the bearing caps. It either slipped on the drive sprocket or was installed like this from the factory (I didn't verify cam timing before the lash adjustment).
The rear wheel was chocked up on blocks and the belt loosened before I could even get the cam covers off of the engine. The bike was in neutral.
I just removed the bearing caps from the rear intake cam and slipped the chain one tooth on both rear cams. After replacing the caps and tensioner, all cams lined up correctly. I rotated the engine twice and pinned it and everything now looks good. I'm going to assume that the chain somehow slipped a tooth on the drive gear while I was moving one of the cams earlier.
Certainly the factory could not have put it together this way. That's silly. A 15 degree valve timing error on one cylinder (360/24) wouldn't fly. Would it? I will probably be able to tell if there is a difference in power when I get it all back together. Maybe this thing's faster than I knew?
Old 01-18-2010, 06:37 PM   #6
Dale "R"
Dale "R"'s Avatar
Images: 20
Its for sure off. Don't feel bad, its easy to do. The important thing is you caught it.
Dale "R"
Dale "R" is offline   Reply With Quote
Old 01-18-2010, 06:40 PM   #7
Dr Dave
Buy American!
Dr Dave's Avatar
Images: 93
Quote:
I know what you're saying, but the book says that the links don't need to be lined up like the picture. Here's a quote from the manual; "Note: Even though the timing is correct, the copper links may not appear in the positions illustrated. The copper links are used only in the installation of cam chains."
God forbid if I had to get the links lined up too. I would probably miss that particular rotation and have to do it all over again (can't roll clockwise).
Old 01-18-2010, 06:48 PM   #8
TaxmanHog
Noel
TaxmanHog's Avatar
Images: 277
Garage
Correct, what Will refers to is the copper links, they lose orientation after the first spin after initial engine build, and it's something like 60 crank turns (or so) before they are in.
What we want to focus on are the timing marks on the sprockets forward exhaust has a -., forward intake -.., rear intake -... and rear exhaust -...., and all these are horizontally on the same plane.
VRD-941 & ET-943
60: 1.393
ET: 9.661
Mph: 139.34
Check Your Grounds
Old 01-18-2010, 06:57 PM   #9
TaxmanHog
Noel
TaxmanHog's Avatar
Images: 277
Garage
It either slipped on the drive sprocket or ......
I think this is the root cause, while you were juggling the cams the chain could have gotten off the triple sprocket..
VRD-941 & ET-943
60: 1.393
ET: 9.661
Mph: 139.34
Check Your Grounds
Old 01-18-2010, 06:58 PM   #10
Big Will
Hi... I'm Big Will
Big Will's Avatar
Images: 11
Ok... not trying to add to the confusion, just a problem I've had myself and have seen others have as well.
Like Dale said, this is easy to have happen and it's a good thing you caught it!
2005 VRSCSE
Go Pokes!
Old 01-21-2010, 09:48 PM   #11
nic_a_bod
"A" is the only way
nic_a_bod's Avatar
Images: 134
Feedback Score: 20 reviews
It might of slipped when you released the tensioner. If the cam is loaded it will tend to jump the chain when the tension is released. You might want to see if someone has a home made tensioner tool to use so you can spin it backwards and forwards without it jumping time. I can send you mine if needed.
nic_a_bod is offline   Reply With Quote
Old 01-22-2010, 12:08 AM   #12
MY_VRSCDX
matt blk & fire hot
MY_VRSCDX's Avatar
Images: 38
Feedback Score: 0 reviews
Thumbs down
BAD IDEA! you could bend a valve if the chain jumped to far.
The older I get, the better I was
Run'in on Empty, but the F'in gauge doesn’t work, so I probably have 1/2 a tank!
MY_VRSCDX is offline   Reply With Quote
Old 01-22-2010, 12:19 AM   #13
MY_VRSCDX
matt blk & fire hot
MY_VRSCDX's Avatar
Images: 38
Wink
this happened to me too. no big deal to put it back.
Max once said: it is best to pull the side cover and tyerap the chain to the triple sprocket. as you lift the cams to get to the shims, the chain goes way slack, and drops off the triple sprocket, so when you put the cam back it is off time. you need to pull the cover, pin the crank, align the triple sprocket dots and all the cam dots. watch out you don't bind a valve and bend it when you turn the crank shaft.
then afterwords check the triple sprocket and loctite the bolt.
Old 01-22-2010, 06:44 AM   #14
Big Will
Hi... I'm Big Will
Big Will's Avatar
Images: 11
Quote:
Thanks for the tip
2005 VRSCSE
Go Pokes!
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
