Help, Overheating - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Reply
Thread Tools Display Modes
Old 11-15-2009, 08:22 PM   #1
mikeinatlanta
The Massive Pr1ck
mikeinatlanta's Avatar
Feedback Score: 0 reviews
Help, Overheating
I have a 06 VRSCR with 2,000 miles. Yesterday I started getting an overheat indication. I searched the forum and checked the following:
New style coolant tank is full
Pulled plug in airbox and only managed to add 2 ounces.
Checked under alternator cover (left side 2 screws) and everything seems ok.
The fans are running a lot and it happens at both low and high speed. The engine is obvoiusly very hot but the radiator hoses are not too hot to hold. Outside temp about 60.
What do the experts think, stuck Tstat?
Thanks,
Mike
mikeinatlanta is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-15-2009, 08:30 PM   #2
El-Bobbo-Cheapo
Registered Full
Feedback Score: 9 reviews
Check the triple sprocket bolt first, if it comes loose the water pump won't spin correctly. If that's still tight, pull the t-stat. Did you check the radiator to make sure it's not built up with leaves or whatever?
El-Bobbo-Cheapo is offline   Reply With Quote
Old 11-15-2009, 08:33 PM   #3
Boost
Back in Black
Boost's Avatar
Images: 35
Feedback Score: 12 reviews
Are you sure both fans are turning. Like he said not full of leaves.
I agree sounds like thermostat to me.
My bikes mods (lucky enough to have 2 v-rods)
My bikes pictures
Founder of NightMare's NightRiders!
Boost is offline   Reply With Quote
Old 11-15-2009, 08:41 PM   #4
mikeinatlanta
The Massive Pr1ck
Quote:
As I understand, you are talking about the bolt under a cover on the left side of the engine held on by two bolts. Is this correct? What is the torque supposed to be on that bolt? It looks pretty big.
Old 11-15-2009, 08:45 PM   #5
rsc
Killer Service Inc.
rsc's Avatar
Images: 1
Garage
Feedback Score: 8 reviews
I would check the triple sprocket also... they can and do back out, some have been known to be loose from the factory.
Check raditor also...clean...check to make sure both fans are coming on.
Check the manual for bleeding the system and do that.
Check cap so it is tight and not losing pressure.
Check bleeder screw to be tight.
Thermostat would be the last thing to dive into...you will have to remove alot to get to it.
The stat itself is not sold as a stand alone part, you have to buy the whole housing and all for 100.00
Good Luck
rsc
2003 turbo
2012 Ultra Classic
V-rod mechanics 101:
Old 11-15-2009, 08:45 PM   #6
HoneyB
Pat (Patrick!)
HoneyB's Avatar
Images: 14
Feedback Score: 31 reviews
Check here:
http://www.1130cc.com/forums/showthread.php?t=108910
Old 11-15-2009, 08:47 PM   #7
rsc
Killer Service Inc.
rsc's Avatar
Images: 1
Garage
You can check the stat to....feel the hoses to see if the fluid is flowing...
2003 turbo
2012 Ultra Classic
Old 11-15-2009, 08:54 PM   #8
mikeinatlanta
The Massive Pr1ck
Quote:
Originally Posted by HoneyB View Post
Looks like i was looking in the wrong area. If this is the problem, what are the chances I have internal damage? Put about 50 miles on it since problem started.
Old 11-15-2009, 09:09 PM   #9
El-Bobbo-Cheapo
Registered Full
As long as you're not getting air bubbles in the coolant, I doubt you hurt anything.
Old 11-15-2009, 09:15 PM   #10
mikeinatlanta
The Massive Pr1ck
THANKS!! I checked and the bolt had fallen out. My only concern at this point is did the loss of oil pressure cause any engine damage? I have about one week left on my 30 day warranty. I never got an oil pressure light.
Old 11-15-2009, 09:34 PM   #11
El-Bobbo-Cheapo
Registered Full
The shaft drives the water pump, not the oil pump. With the bolt loose, you lose some oil pressure to the top end, but it should have gotten noisy if you went without oil for very long.
Old 12-29-2009, 11:50 AM   #12
bassman76542
Registered Full
Good Luck
rsc
Where can I find more info about the triple sprocket bolt's backing out? This happened to my 07 VRSCDX, Its currently been at Mobile HD for two weeks, and Im looking for documentation on this problem and it's frequency. If this is a known & recurring problem I shouldn't have to pay to have it fixed, Thanks
bassman76542 is offline   Reply With Quote
Old 12-29-2009, 07:45 PM   #13
rsc
Killer Service Inc.
rsc's Avatar
Images: 1
Garage
See post number 6
click on the link.
Search function at the top of the page will help.
2003 turbo
2012 Ultra Classic
Old 12-29-2009, 07:55 PM   #14
rsc
Killer Service Inc.
rsc's Avatar
Images: 1
Garage
http://www.1130cc.com/forums/showthr...ht=overheating
http://www.1130cc.com/forums/showthread.php?t=59595
2003 turbo
2012 Ultra Classic
Old 12-31-2009, 10:21 AM   #15
mikeinatlanta
The Massive Pr1ck
Quote:
My 06 vrscr was two weeks out of warranty. HD area reps backed their product and took care of it no charge. The northeast and southeast reps seemed to be well aware of the problem. While in the shop, they also replaced a water pump, tstat, and housing due to a very minor seep. I took oil samples and indication was no top end damage.
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
