Brake fluid question.. - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Reply
Thread Tools Display Modes
Old 11-01-2009, 11:43 AM   #1
Coonass
jacket off!
Coonass's Avatar
Images: 215
Feedback Score: 1 reviews
I HAVE used the search feature and have not been able to answer my question, so here goes...
I have already replaced my brake fluid with DOT 4 and I realized after the fact that I apparently had DOT 5 in the system before.
So my question is, "Did I fawk up?"
MOVING PEOPLE THRU MOTIVATION ONE TURD IN THE CROWDED POOL AT A TIME!
DRIVING FORCE OF THE "COONASS FAN CLUB"!
Coonass is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-01-2009, 12:08 PM   #2
Tie_One_On
Tie One On
Tie_One_On's Avatar
Images: 7
Feedback Score: 4 reviews
you need to use dot 5.
just suck the fluid out of the res and put in dot 5.
DO NOT get the dot 5 on painted parts since it will eat up the paint.
06 street rod (and proud of it)
05 RC51 Custom Motor (4 Sale)
Tie_One_On is offline   Reply With Quote
Old 11-01-2009, 12:45 PM   #3
ElrodontheV-Rod
durata membro
ElrodontheV-Rod's Avatar
Images: 9
Feedback Score: 5 reviews
Yea,you ****ed up.
If it were me,I'd get the mixture out of there right now before it has time to start messing up the seals.
Hopefully all you did was add the 4 into the masters instead of bleeding it through the system.If you did bleed it through and it hasn't been in there very long,I think you can flush the system w alcohol and then reinstall the 5.
I'm no expert on this,so you might want to wait till more suggestions are posted.
ElrodontheV-Rod is offline   Reply With Quote
Old 11-01-2009, 12:52 PM   #4
Tie_One_On
Tie One On
Tie_One_On's Avatar
Images: 7
I assumed that the res was just topped off. If it went through the system then you should drain it flush it and refill
Old 11-01-2009, 01:21 PM   #5
pecee
Registered Full
pecee's Avatar
the dot 4 will not hurt the seals.it will damage any paint it contacts. the dot 5 is less harmfull to paint and that is the reason its recomended in the early rods.the dot 4 performs better than the 5 in that it has a higher boil point and absorbs water better. dont mix the two together but otherwise if your resivoirs are polished or chromed then dot4 is the best.
pecee is offline   Reply With Quote
Old 11-01-2009, 02:01 PM   #6
Coonass
jacket off!
Coonass's Avatar
Images: 215
I'm not really after debating which oil is best; I accidentally replaced the DOT-5 with DOT-4.
I can understand that mixing the 2 could be an issue but, considering any residual DOT-5 left behind SHOULD float above the DOT-4 (b/c the 5 is less dense than the 4), then in THEORY, I should be able to give it a few pulls and skim off the DOT-5, right?
Old 11-01-2009, 02:56 PM   #7
vroder
Blowin' Smoke
vroder's Avatar
Images: 6
Feedback Score: 6 reviews
I suspect you will have a tough time getting ALL of either out of the system once it's mixed without flushing the one you want through the system. Sounds like you need a pressure bleeder to me.
Independent "A" owner
vroder is offline   Reply With Quote
Old 11-01-2009, 03:04 PM   #8
bproulxvrod
Registered Full
bproulxvrod's Avatar
Images: 12
Feedback Score: 36 reviews
I would drain it all out, flush it with denatured alcohol, and then add DOT 5, bleed the system, and add more DOT 5.
2002 V-rod: Yellow w/yellow ghost flames (frame painted to match)
2003 100th Anniversary VRSCA bagger edition
bproulxvrod is offline   Reply With Quote
Old 11-01-2009, 03:16 PM   #9
jedi
MODOHOLIC ANONYMOUS
jedi's Avatar
Images: 6
Garage
Feedback Score: 47 reviews
Quote:
i got a extra owners manual if ya need one..
05 VRSCA
Trask Turbo
X Treme Machine Ripper Wheels
Cutting Edge Illusions Paint
Franklin Designs Wicked Airbox/Hot Rod Rear Fender
Arnott Air Ride
LouBALLZ Headlight and LED's
American Drag Seat Custom Seat
Too Much Chrome to List...
03 RoadGlide
Covington Custom SlingBlade Wheels (26)
Sinister Bags
BR Custom Bars
Danny Gray "ButtCrack" Seat
Bassani 4 inch Covington Hot Rod Duals
Blacked Out, Raked and AccessoriZZed By Covington Customs
jedi is offline   Reply With Quote
Old 11-01-2009, 03:42 PM   #10
VrodG
Greg/Moderator
VrodG's Avatar
Images: 26
Feedback Score: 8 reviews
screw that dot 4!!
VrodG is offline   Reply With Quote
Old 11-01-2009, 03:59 PM   #11
Nas3car
Shelby Stanga Rocks
Nas3car's Avatar
Knowing about the interactions of the fluids, this is the only correct way to resolve the issue. The two fluids are serously like oil and water, two way different types. They each have their own good points but cannot be mixed. Worse case is the brake lever will always feel spongy or may even never give full brake line pressure.
Tech side the seals are the same, its the interaction of the two fluids that make the seals act soft. Over a long peroid of time it will not be reversable. Its not like bleach and amonia, instant, its a slow deal. Still needs to be addressed ASAP.
When its all cleaned out and fresh fluid is reinstalled you shouldnt notice a difference.
Chuck
1981 SuperGlide
2007 VRSCDX the rarest of the DX one year only 1130cc.
Any Edit is to fix spelling
Hunt and Peck its a way of life
Still no Facebook just older
BUMPER beats HELMET every time.
They removed my soul to fit in all this sarcasm
Nas3car is offline   Reply With Quote
Old 11-01-2009, 05:55 PM   #12
Coonass
jacket off!
Coonass's Avatar
Images: 215
Thanks all!
Old 03-08-2010, 01:51 PM   #13
abitwar10
Registered Full
Feedback Score: 2 reviews
How do you know what type of brake fluid is in your resevoirs? I purchased the bike from a previous owner, so have no idea what was in there. The only thing I can say, is I topped it off with DOT 5 because that's what my resevoir caps said to use. As soon as I poured it in, I noticed the DOT 5 is like a purple color. The existing fluid in there was kind of a yellowish brown clear color, sort of like new motor oil.
Any ideas on what I have or what I should do? I haven't ridden the bike since doing this, so it probably hasn't been through the lines yet.
Ken
2003 VRSCA black
abitwar10 is offline   Reply With Quote
Old 03-08-2010, 02:01 PM   #14
o2man98
The 1402 Originator
o2man98's Avatar
Images: 67
Feedback Score: 106 reviews
The DOT 5 is purplish when new. It will turn all kinds of nasty colors as it ages. From purple to , yellow, brown, and green.
Independent AMSOIL Premier Direct Jobber
-E-mail me at
Call me at 920-860-0116 for ordering. Best times will be after 5pm weekdays or anytime weekends.
Contact me directly for forum member pricing as Authorized Dealers are not allowed to advertise discounted rates publicly.
Get DEALER COST immediately on your first order by following these instructions.
o2man98 is offline   Reply With Quote
Old 03-08-2010, 02:48 PM   #15
abitwar10
Registered Full
Quote:
So is it safe to assume I already had DOT5 in my resevoir? Is there any way of easily figuring out what it is? I just don't want to worry about my brakes failing because I accidentally mixed.
Maybe to be sure, I should just flush and start over at the clutch and both brakes?
Ken
2003 VRSCA black
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
