Clutch Fluid Flush/Leak - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Reply
Thread Tools Display Modes
Old 09-12-2009, 08:49 PM   #1
sks109
Registered Full
Feedback Score: 0 reviews
Hi folks
You order up the parts thinking this will be a couple of minutes job and what do you find, one job leads to another.
Just took delivery of my HD chrome reservoir covers for my 2009 AW. Its only done 1000 miles but when I took the old cap off the clutch master cylinder it looks like water has got in as the fluid is all grey ? (reckon over enthusiastic use of pressure washer by the dealer ??)
Reckon I`m gonna have to flush this through with new fluid. Any tips on this. Being new to Harleys and coming from Ducati where bleeding and flushing the clutch was a black art involving removing the slave cylinder and part filling it etc and then back forcing the fluid I`m trying to discover the tricks before I start.
Hopefully gonna use my vacum bleeder as I notice that the slave cylinder has a normal bleed nipple.
I`ve fitted the caps pending the flush only to find the damn clutch side now leaks a little on the front side. Found a thread on here about gasket problems with these replacements so gonna investigate that.
2009 VRSCAW
1985 Yamaha RZ350LC YPVS
1982 Yamaha RD350LC
2002 Ducati 750SS
sks109 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 09-13-2009, 05:06 AM   #2
ElrodontheV-Rod
durata membro
ElrodontheV-Rod's Avatar
Images: 9
Feedback Score: 5 reviews
The gray or black is not water,it's assembly lube.Don't worry about it.
I've found with the DOT4,it's not necessary to flush any of the systems as frequent as systems with the DOT5,but that's up to you.
The 09 master lids seal much better than the previous design.Make sure you have the lid on square and evenly tighten the screws.Keep the height of fluid a scoatch lower than suggested and make sure to twist the bars to get the master as level as possible for checking the fluid height.
ElrodontheV-Rod is offline   Reply With Quote
Old 09-13-2009, 08:38 AM   #3
sks109
Registered Full
Thanks for that, nice to know, was a bit concerned as to how water could have got in. However, looked so easy with my vacum pump I flushed it anyway, This has got to be the easiest sytem to flush through, even the bleed nipple works correctly. I`ll keep an eye on the caps, made sure they were spotless around the seals and refitted.
2009 VRSCAW
1982 Yamaha RD350LC
2002 Ducati 750SS
Old 09-13-2009, 06:40 PM   #4
Yarvis
Official bike nut
Yarvis's Avatar
Images: 8
Feedback Score: 4 reviews
Can ANYONE else add some "how to" advice here???? I have an 06 D with Brembos and I want to flush both the clutch fluid and the brake fluid. What can I buy to do this myself that will work and NOT break the bank now that Max quit making his bleeder system?
Yarvis S. Torres
2014 Moto Guzzi California 1400 Touring
2006 VRSCD Night Rod (Sadly traded in)
2001 BMW R1200c Phoenix
"Life is what happens to you while you're busy making other plans." ---John Lennon.
Yarvis is offline   Reply With Quote
Old 09-14-2009, 07:57 AM   #5
sks109
Registered Full
This is the bit of kit I use
http://cgi.ebay.co.uk/BRAKE-CALIPER-...d=p3286.c0.m14
I know its ebay UK but I`m sure you can get it elsewhere. Just connected it to the bleed nipple and let it suck the fluid through from the reservoir. Kept topping up the reservoir and now and then stopped the process to pump the clutch. Eventually it sucks through the new fluid with no air in the system.
Not used it on the Harley brakes yet but have used it on all my other bikes and change the fluid every two years. No problems to date or the my Ducati clutch but thats laways a problem with whatever I use.
Am I right in believing the early models did not have a bleed nipple but a bleed screw, which of course would make it more difficult ?
2009 VRSCAW
1982 Yamaha RD350LC
2002 Ducati 750SS
Old 09-15-2009, 05:14 AM   #6
cboahd
Voluptuous 'V'
cboahd's Avatar
Feedback Score: 6 reviews
sks109,
I just did my rear brakes (very easy) and soon to do my clutch flush/fill with a Mityvac (Model # 20930) about $60 from Sears but could of done it with a cheaper model. It has a bunch of attachments that hopefully will fit the bleeder screw? or maybe buy a nipple? Needed to mail-order it because Sears didn't stock them at our local store. http://www.sears.com/shc/s/p_10153_1...criptionAnchor
cboahd is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
