Muffler Cement to Stop Exhaust Leak - Apparently It Doesn't Work! - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Go Back   1130cc.com: The #1 Harley Davidson V-Rod Forum > Specific Model > VRSCDX
Reply
Thread Tools Display Modes
Old 07-19-2009, 05:26 PM   #1
chenner
Registered Full
chenner's Avatar
Images: 20
Feedback Score: 2 reviews
So this summer I've pretty much had my CFR exhaust off the bike every week trying to stop the damn thing from popping. It basically consists of me sanding down the end of the pipes, cleaning it up with rubbing alcohol, then applying some red RTV. It seems to work for a bit before the popping comes back.
I found that the header pipe was leaking a bit so I replaced the gasket there as well. Well, I visited a muffler shop to find out if they can enlarge the diameter of the header pipe so I can get a tighter fit (I know that a member here did that) but they didn't want to take the chance of making it too large as then I'd be F-ed). They recommended a product called "muffler cement" which I bought a tube of. This stuff hardens once dry.
Well, I applied it to the bike and pipe and it seems to do the trick but for some reason after a short ride it starts to push the pipe back off the header pipe. I tried it twice and the second time I made sure I clamped down hard on it but again, after a 25 minute leisurely ride you can see the pipe starting to back off in this pic. When I started riding the CFR and the header pipe sat flush with no gap.
The cement has cracked where the pipe has backed off. I just can't figure out what is pushing the pipe back off the header? If it was mounted to the bike near the back I'm sure that it would work it's way off the pipe completely after a bit of riding.
Any advice?
'07 NRS Vivid/Denim
chenner is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-19-2009, 08:39 PM   #2
Spanky7
Registered Full
Spanky7's Avatar
Feedback Score: 9 reviews
I am glad I swapped out to a RH. I notice too that mine even with the new clamp when I had it on was working its way off too. Could it be the mounting setup in the rear? I know it's not a real "solid" braced mount. Just an idea. I mean the mount for the RH is much more solid. For example, I could wiggle the CFR, the RH is rock solid. Maybe a better mounting bracket? Might help?
From what I understand as well, the figure 8 clamp as they say is "one and done." which if that is true, provides to be expensive when intalling and removing the slip on numerous times.
2008 Vivid Black/Orange Stripe VRSCDX 9/20/08
Rinehart 2-1
PC3
SCREAMIN EAGLE Air Filter
Ghost Riders Customs radiator screens/skull medallions
Pondos Covers ("Bucky" inspired)
LED light kit
Bar end mirrors
"Better to be dead and cool then alive and uncool"
Proverbs 27:17
Spanky7 is offline   Reply With Quote
Old 07-19-2009, 11:37 PM   #3
AOW
AOW's Avatar
Images: 85
Feedback Score: 8 reviews
pick up a set of stock header pipes on here for cheap, and let the muffler shop have a go at enlarging the existing ones. If they fark it up you still have a spare set.
SERVICE MANUAL!
embrace the "google search" function.... site:1130cc.com:
Quote:
Originally Posted by rjrivero
Nobody cares about your shit like you
Fuel gauge? We don't need no stinking Fuel gauge!!!
AOW is offline   Reply With Quote
Old 07-20-2009, 12:24 AM   #4
Dozer
Zombie
Feedback Score: 0 reviews
When I tuned my CFR, it would pop until I richened up the mix. I made it so when the RPMs were high and the gas was backed off, it still added a little fuel. Popping went away. Try that... it might not be a leak.
2008 VRSCDX
Arnott's, CFR pipe, PCIII, Semi-topless, 260 Metz
118 RWHP
Dozer is offline   Reply With Quote
Old 07-20-2009, 08:48 AM   #5
sinic
INCONCEIVABLE!
sinic's Avatar
Images: 33
Feedback Score: 7 reviews
I can't believe you're still fooling around with this problem ... it's been all summer!
I love the look and sound of the CFR, but is it really so great that you're willing to put up with the problem over and over again?
Just get a different pipe ... there are so many options out there
The Evolution of My DX ... I Keep Telling Myself I'm Done, But Who Am I Kididng?
Summer 2008................Summer 2009......................Summer 2010
sinic is offline   Reply With Quote
Old 07-20-2009, 12:55 PM   #6
chenner
Registered Full
chenner's Avatar
Images: 20
Thanks for the advice guys.
I hear you Sinic. I've decided that I'll have one more go at the RTV and just live with it.
I'm now worried about the pipe starting to back off the header though but I'll try to ride into work on Wed to test it out. Besides, with the weather we've been hading it's not like I have been missing many riding days! :-o
'07 NRS Vivid/Denim
Old 07-20-2009, 02:44 PM   #7
usanigel
Lifetime Premium
usanigel's Avatar
That paste is for very small spaces! It has no strength! Wheres the clamp to fit around this joint in the pipes? Even a hose clamp will work. You need to be able to "crush" the outer pipe around the inner pipe. Sometimes you need to make the "gaps" in the end of the outer pipe wider to allow this. Expanding the inner pipe will also make this work, just not as easy to do.
2006 Night Rod, almost all the chrome you can get+custom paint.
1976 Triumph T160 stock for the most part.
Buell 2009 1125cr "very red and rapid!"
usanigel is offline   Reply With Quote
Old 07-20-2009, 04:14 PM   #8
bproulxvrod
Registered Full
bproulxvrod's Avatar
Images: 12
Feedback Score: 36 reviews
You could always buy one of these: http://www.autozone.com/autozone/cat...+Pipe+Expander and try to expand the pipes yourself. Very easy to use and you can go in small increments.
2002 V-rod: Yellow w/yellow ghost flames (frame painted to match)
2003 100th Anniversary VRSCA bagger edition
bproulxvrod is offline   Reply With Quote
Old 07-21-2009, 09:15 AM   #9
ROCKERDAN
SOLD!!!
ROCKERDAN's Avatar
Images: 258
Feedback Score: 30 reviews
silicone sealants are never gonna cure the root if the issue....the inlets where it clamps on is slightly too large...you need to have the stock headers opened up IMO.
also,the second issue is the rear mount....if the rear is mounted in a good manner,the front cannot come loose so easily....
the RH uses the AW mount system,you may want to look into the AW bracket which is heavy duty.
worst some to worst....why dont you just have the thing tacked(welded) in a few spots in addition to the clamp...that should hold the mutha on there!
Dan
'08DX Custom SOLD!!!
Arnott air ride
PcV w/Auto tune
Golf club mirrors
Custom built fender
HogPro 300 swingarm kit
Custom tilted Carlini FUBAR
Custom hand built solo seat
HogPro 'Indy' contrast wheels
4.5" billet 'Venom style' headlight
Rinehart 2:1 with Custom Made Baffle
Kellermann micro 1000DF run-brake-turn signals
Adaptiv TPX Radar Detector w/Visual alert & RAM mount
ROCKERDAN is offline   Reply With Quote
Old 07-21-2009, 12:33 PM   #10
Cheatin
Cheatin's Avatar
Images: 93
Feedback Score: 1 reviews
Smash it with a BFH!
FREE HOTDOG = MOCO REACHAROUND
Cheatin is offline   Reply With Quote
Old 07-21-2009, 01:09 PM   #11
V-Rod I FL
Registered Full
V-Rod I FL's Avatar
Feedback Score: 5 reviews
You may have already done this but......
When you take the CFR off next, place the expanded portion beside the header pipes and align the end of the expanded portion with the tip of the header pipe and mark the spot with a sharpie. Now as you are "tapping the CFR pipe on to the header pipe you can be sure that it is actually going as far on the header pipe as it should. Then tighten down the exhaust bracket.
I also used a stainless steel bolt that was a little larger in diameter than the one that came with the rubber insulator and added a stainless washer and nylon locking nut on the top and bottom. That way if it was trying to slide off the larger bolt would prevent it from occuring.
I also found that the little sharpie mark let me see at a quick glance while riding if anything had moved.
I would also recommend that if it keeps occuring that you contact Cary Faas and ask for his advice. He is a great guy and will be more than willing to share his experiences.
I hope you resolve the issue real soon.
V-Rod I FL is offline   Reply With Quote
Old 07-21-2009, 02:59 PM   #12
chenner
Registered Full
chenner's Avatar
Images: 20
Thanks for the suggestions guys.
Dan, I thought about welding but that means if the pipe ever needed to be removed they'd have to remove it from the header/motor connection and having a leak there would put me worse off!
V-Rod I FL - it never dawned on me to try the manufacturer. I will probably give Cary a call later this week.
'07 NRS Vivid/Denim
Old 07-21-2009, 04:15 PM   #13
ROCKERDAN
SOLD!!!
ROCKERDAN's Avatar
Images: 258
just a couple small tacks i mean...and you could do just one header(similar to what they did on 09s)...'
if it needs to come off you just cut the tacks with dremel...simple.
Dan
Arnott air ride
PcV w/Auto tune
Golf club mirrors
Custom built fender
Old 07-24-2009, 02:54 PM   #14
V-Rod I FL
Registered Full
V-Rod I FL's Avatar
You can ask Max or anyone else he is real customer oriented and I am sure will help you find a solution.
Please be sure your pipe is up on the header pipes as far as it will go. I was fortunate enough to find this issue out before it was too late.... Of course I was having some fun with my previous V-Rod (see pictures in my gallery). 140rwhp always intices you to see what it is capable of.......
I hope you find a solution real soon.
Regards
Old 07-24-2009, 04:26 PM   #15
beafraid8
Creepin' up...
beafraid8's Avatar
Images: 33
Feedback Score: 13 reviews
Any chance of drilling a hole on each side and putting in a couple small screws?
2009 DX - Basic mods
beafraid8 is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
