Lower frame - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Go Back   1130cc.com: The #1 Harley Davidson V-Rod Forum > Specific Model > VRSCB
Reply
Thread Tools Display Modes
Old 06-20-2009, 11:24 AM   #1
kbvrod
Bugs in the teeth!
kbvrod's Avatar
Feedback Score: 0 reviews
Exclamation Lower frame
Hi all,
Dumped the 2004 VRSCB,the 'sleeve' that holds the foot peg (left side/shift) cracked.Question: is easily welded or can you replace that part of the frame?
Thanks for any help,Kev.
kbvrod is offline   Reply With Quote
Sponsored Links
Advertisement
Old 06-20-2009, 11:31 AM   #2
taximech
Lifetime Premium
taximech's Avatar
Images: 42
Feedback Score: 5 reviews
That lower frame rail is available from dealer, not much money (100 to 150). But I can't see why that could not be removed and welded for less, IMHO
2008 VRSCDX
Vivid black with orange pearl
Tiger Racing Belt Guards, Dan's Grille Guards
Arnott Air Ride, Progressive Front Springs
Black Diamond Grips, Black Axle Covers
Many Parts Powdercoated
taximech is offline   Reply With Quote
Old 06-20-2009, 02:56 PM   #3
wewarn
passionate fanatic
wewarn's Avatar
Images: 1
Feedback Score: 1 reviews
replace it ..there was a part number change for the one on the right side and the early number was cheaper. I was able to locate one of the early ones and have it in my personal stock now in anticipation of the "crash". the metal is soft enough to deform in the event of a crash so welding then repainting would work but does nuthing for the looks of it
2004 Black B the Original Dark Side
Artificial Intelligence is no match for Absolute Stupidity
I've found that a good ride is the best place to find the answers, or ignore the questions
wewarn is offline   Reply With Quote
Old 06-21-2009, 03:57 PM   #4
stagwaffe
Registered Full
stagwaffe's Avatar
Images: 9
i welded my rh peg back on in august,about 5k miles ago. i used a good snap-on welder and am confident in it strength. Yours might be mis-shaped though, and not 'roll' back into place correctly.i had to do a bit of bending.As said new rails arent dear though if you shop around.i think 'zanotti' were cheap....is that a place ?
stagwaffe is offline   Reply With Quote
Old 06-21-2009, 07:14 PM   #5
07vrscdx
VividDX
07vrscdx's Avatar
Images: 41
I would replace it. The problem is they are currently on back order with no ship time. I know because I dumped my bike a few weeks ago and have to replace mine. Might get lucky with the part since we have different frames. Good luck and glad to see you are OK.
Keven
Virginia
07 DX
Legend's Air Ride-Progressive front lowering kit-26t pulley-V & H Indy Pipe- Screaming Eagle Filter- Screaming Eagle Super Tuner - Stage II Cams - Metz 260- Custom Dynamics orange LED's, Side mount plate, LED turn / brake strip-rear fender delete- too many others to list.
07vrscdx is offline   Reply With Quote
Old 06-22-2009, 10:06 AM   #6
dleighty
Artillery VET
dleighty's Avatar
Images: 14
Feedback Score: 32 reviews
I HAVE A 2006 D model right side frame
USW LOCAL 8-1003
FINANCIAL OFFICER
OWNER OF COPRA ON SITE
SPRAY IN LINERS
dleighty is offline   Reply With Quote
Old 06-22-2009, 10:54 AM   #7
BLKBAL
Registered Full
BLKBAL's Avatar
Images: 187
I Found Myself In Situation About A Month Ago!
Tried The Dealed But That Section Of The Frame Was An Back Order,non In Stock At Any Usa Dealer ,neither Did H-d Give A Public Sale Release Date.
I Had Mine Repaired By A Welder.he Placed It In A Jigg To Insure It Was Straight !! The Result Were Perfect.so I Dont See Anyreason Not To Have That Part Repaired.i Also Have One On Order.goodluck!
BIKE:2009 DX
NAME:L TRIPLE D(LOW DOWN DIRTY DIRTY)
PCV
K&N FILTER
BOTTOMLESS AIRBOX
MODED RADIATOR SHROUD
V&H INDY
FITZGERALD 26T PULLEY
PROGRESSIVE SUSPENSION FRNT & REAR
TEMP O/R SWITCH
S/E STAGE II CAMS
S/E PRO SHIFT LIGHT
DESTROYER 58MM T/B
FRNT/REAR "F" RIMS
LED HEADLIGHT UPGRADE
CUSTOM PAINT/PWDRC
CUSTOM BRK/TURN SIGNALS
MAX HP:134.99
MAX TQ: 81.27
BEST TO DATE:
1/8=7.089,98.82
1/4=11.126,120.70
BLKBAL is offline   Reply With Quote
Old 06-22-2009, 02:18 PM   #8
kbvrod
Bugs in the teeth!
kbvrod's Avatar
Danke!
Hi all,
Thanks for the help!Got one on order.
KB
Old 06-22-2009, 03:35 PM   #9
Tie_One_On
Tie One On
Tie_One_On's Avatar
Images: 7
Feedback Score: 4 reviews
Quote:
Prices have gone up on the lower frames to about 245.00 recently.
06 street rod (and proud of it)
05 RC51 Custom Motor (4 Sale)
Tie_One_On is offline   Reply With Quote
Old 06-22-2009, 05:16 PM   #10
Boost
Back in Black
Boost's Avatar
Images: 35
Feedback Score: 12 reviews
I heard a while back they were on back order. Did they mention this or not? I only ask because i am about to order two.
My bikes mods (lucky enough to have 2 v-rods)
My bikes pictures
Founder of NightMare's NightRiders!
Boost is offline   Reply With Quote
Old 06-25-2009, 08:05 PM   #11
07vrscdx
VividDX
07vrscdx's Avatar
Images: 41
Mine came in today. So hopefully you wont have to wait much longer.
Keven
Virginia
07 DX
Old 06-25-2009, 08:59 PM   #12
Boost
Back in Black
Boost's Avatar
Images: 35
Thanks called today they said they came off back order today.
My bikes pictures
Old 06-30-2009, 11:57 PM   #13
VRSCSE-Willy
Registered Full
VRSCSE-Willy's Avatar
Images: 4
is there a specific website that you guys are checking prices and does it come painted?
VRSCSE-Willy is offline   Reply With Quote
Old 07-01-2009, 07:48 AM   #14
Boost
Back in Black
Boost's Avatar
Images: 35
Yes comes painted try Zannotti's they are te cheapest i found i just bought a set for 04 B
They said will not be available till 7-10 of course 3 days ago i was told 2 days from Harley
My bikes pictures
Old 09-12-2009, 04:26 AM   #15
VRSCSE-Willy
Registered Full
Images: 4
does anybody have or know where i can find video on how to replace the lower left frame rail
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
