I want to put in a password for the TSSM on the 02 just in case the fobs die like they did on my R. The PO had a password. How can I retrieve it? Change it? Lookng through the electrical, it just show's how to add if there was no code previously entered
I programmed mine from the instructions in the owners manual.
There is also a video tape that came with my bikes.
I'm not sure if going through the procedure and setting a new set of numbers will over ride the code already in it.
The only TSSM password I know about is the digital password that the TSSM and ECM use to communicate on the SERIAL DATA LINK. This password can't be entered or changed.
There's a "Personal Code" that's entered using the turn signal switches. Once entered this can be used to disarm a armed TSSM if the FOB is lost or damaged. The procedure for entering or changing this personal code is explained on page 3-6 using Table 3-4 on page 3-8 of the '02 EDM. I attached these pages.
PS I just realized that i forgot to post the last steps of Table 3-4 on page 3-9
stever975 if the password is lost, forgotten or never known is there a way to retrieve it or set a new one. I ask because my 04b has a password set but I don't know what it is and I'm the third owner.
I'm assuming you mean the TSSM "Personal Code". If so, yes this can be retrieved:
Once you're in the TSSM PC programming mode (step 4 in Table 3-4) and you then press the left turn switch (step 5 in Table 3-4) the first digit of the TSSM PC will be indicated by the turn signals: 0 to 9 flashes. Zero flashes means that the TSSM PC has not been set and steps 6 through 22 explain how to enter or change it.
Your right about reading and following the instructions,Rusty.It's much easier with another competent person.I read,while my brother did the procedure.
stever is there a way to unlock it if it locks up?
Related Threads
Harley Davidson V-Rod Forum
2.7M posts
68.6K members
Since 2003
