Is the Intake Temp Sensor okay to be not installed? - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Reply
Thread Tools Display Modes
Old 03-18-2017, 11:42 PM   #1
storx
Registered Full
Feedback Score: 0 reviews
So today i spent the day replacing all the brake fluid in the bike, then changed the oil with Mobile 1 20w50, then when i went to check the air box, i found that it had already been "de-lidded" already with the cover completely missing along with the intake air sensor just dangling in the breeze... is this ok?
storx is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-19-2017, 01:57 AM   #2
Knut J
VRSC est -03
Knut J's Avatar
Short answer: yes. Place it above the battery for fresh air..
WILL RACE FOR FOOD!
Knut J is offline   Reply With Quote
Old 03-19-2017, 02:53 AM   #3
TwinOaks
Registered Full
TwinOaks's Avatar
Feedback Score: 5 reviews
NO. Moved, yes, but not a good idea to remove it completely.
See manuals, buy manuals, read manuals.
TwinOaks is offline   Reply With Quote
Old 03-19-2017, 07:10 AM   #4
Elgavilan
The Hawk
Elgavilan's Avatar
Images: 21
Feedback Score: 14 reviews
The sensor needs to be plugged into the wiring connector. Where you place it after that is up to you, some guys think it works best plugged into a hole they drill on the air cleaner cover. Some guys like it plugged into a hole drilled into the lower airbox cover and some just zip tie it so it hangs in the airbox cover near the air cleaner. The bike will run with the sensor removed but it will run way rich.
Mike
It's not how fast you go, it's how fast you get there!
Elgavilan is offline   Reply With Quote
Old 03-19-2017, 08:03 AM   #5
mikeinatlanta
The Massive Pr1ck
mikeinatlanta's Avatar
So far you are getting some good info here and some not so good. Your ECU will alter AF ratios based on temps of intake air. Obviously if you want your motor to adjust tune for air temp you need the sensor installed. If you want it to do the job well you need the sensor as close as practical to the actual air going into your throttle bodies. Locating it to read "fresh" air is not conducive to having an accurate reading and not a good idea because that is not necessarily what your engine is breathing at any particular moment. Minus having an airbox to read from the next best is mounted to the air filter lid, which is what about 95% of folks here do and 100% of those doing the job correctly.
mikeinatlanta is offline   Reply With Quote
Old 03-19-2017, 03:33 PM   #6
Knut J
VRSC est -03
Knut J's Avatar
I stand correct.
WILL RACE FOR FOOD!
Old 03-20-2017, 08:11 AM   #7
Elgavilan
The Hawk
Elgavilan's Avatar
Images: 21
Agree, you are getting some misleading info, the ECM adjusts temperature related parameters on a 16 degree temp swing. In other words, the temp has to change 16 degrees before the ECM makes an adjustment. Locating the IAT within the lower air box and within 2 to 4" of the air cleaner is measuring the same air as that pulled through the air cleaner. That is how the factory does it when they locate it in the front panel of the airbox.
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
