Squeaky door sound coming from rear wheel/belt - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Reply
Thread Tools Display Modes
Old 03-10-2017, 03:30 PM   #1
mattssi
Registered Full
Feedback Score: 3 reviews
Just picked up bike from dealer for brake bleed. Finally go the bike on the road after a year and a few months' rebuild.
As soon as I took off from the dealer loud creaky sound from back wheel/belt/ish area the entire time. After I got it home, I could replicate it by just rocking the bike back n forth in neutral.
This morning, its quite again when rocking, the noise came back after a VERY short ride...like a block or so.
Belt looks okay. I used tension gauge when installing it.
-I have the poly cush bushing in the back - maybe that could have been it?
-Rear wheel/bearings/spacers are all new. Comp bowl and sprocket have all been coated.
This sound familiar at all?
Video link: https://drive.google.com/open?id=1W8...kOywDlO51w1CwQ
2011 DX w/ Goodies
mattssi is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-10-2017, 06:52 PM   #2
RustyG
Lifetime Premium
RustyG's Avatar
Images: 99
Feedback Score: 11 reviews
Sounds like the drive belt is hitting one of the covers.
Get bike off ground and spin wheel by hand. That should get you close to the truth.
Regards,
John
Quote:
2007 VRSCX 0461 / 1400
2002 Road King Classic
Old 03-10-2017, 08:41 PM   #3
Wind Walker
Registered Full
Wind Walker's Avatar
Feedback Score: 0 reviews
Had the same sound coming from mine one time and it was the belt. They didn't get the rear wheel straight when they put it back together.
Wind Walker is offline   Reply With Quote
Old 03-10-2017, 10:03 PM   #4
biker bob
Registered Full
biker bob's Avatar
Feedback Score: 2 reviews
I would check the brake pad's if they bleed the brake's
biker bob is offline   Reply With Quote
Old 03-12-2017, 06:59 PM   #5
mattssi
Registered Full
Quote:
How was it resolved? How can the rear wheel be misaligned? They axle has fixed cam and both sides of the wheel are moved forward/backward based on the cam.
I checked my belt tension again today, it looked good at 8mm @ 10lb
2011 DX w/ Goodies
Old 03-12-2017, 07:10 PM   #6
RustyG
Lifetime Premium
RustyG's Avatar
Images: 99
get the rear wheel off the ground and spin it. You will find where it is rubbing that way. Fastest way to find out the problem is.
Regards,
John
Old 03-12-2017, 07:12 PM   #7
mattssi
Registered Full
Quote:
That's the plan. Waiting for an extra set of hands just in case. Since the sound goes away after some time, I'm hoping someone can watch/listen as I roll when it occurring.
2011 DX w/ Goodies
Old 03-12-2017, 09:00 PM   #8
Nas3car
Shelby Stanga Rocks
Nas3car's Avatar
Feedback Score: 1 reviews
when mine had that sound it was bad wheel bearings.
Chuck
1981 SuperGlide
2007 VRSCDX the rarest of the DX one year only 1130cc.
Any Edit is to fix spelling
Hunt and Peck its a way of life
Still no Facebook just older
BUMPER beats HELMET every time.
They removed my soul to fit in all this sarcasm
Nas3car is offline   Reply With Quote
Old 03-13-2017, 12:46 AM   #9
flybigjet
Departed the Fix.
flybigjet's Avatar
Feedback Score: 22 reviews
I've had something like this. Even though the belt was in spec and measured correctly, I had a small squeak.
The fix was stupidly simple. I just released the tension on the belt a *tiny* bit, and the problem went away.
R.
USAF: 1989-1997. Desert Shield (Saudi Arabia), Desert Storm (Kuwait, Iraq), Provide Comfort (Kurdistan), Restore Hope (Somalia), Uphold Democracy (Hati), Joint Endeavor (Bosnia), Support Hope (Rwanda). USAFR: 1997-2014. Iraqi Freedom (Iraq), Enduring Freedom (Afghanistan). Retired, Oct. 2014.
flybigjet is offline   Reply With Quote
Old 03-19-2017, 03:19 PM   #10
mattssi
Registered Full
Okay guys, finally got it up on the jack and was able to free spin the wheel and check it out.
-Loosened belt, still a noise. Belt was in spec.
-If I loosened the axle nut and spun it - no noise. Tightened it, noise.
-Removed shocks and brake mount, removed rear sprocket and check what I found!
My guess is the stupid spacer, which doesn't spin, was rubbing on the new urethane cush bushing (red) when it spins causing it to squeal, and as you can see, slowly rub off the cush material.
WTF?
Would the solution be to put some anti-seize on both sides of that spacer and reassemble? This has to be the issue...
Name:	IMG_20170319_1258145 (Medium).jpg
ID:	500017   Click image for larger version
Name:	IMG_20170319_1258088 (Medium).jpg
2011 DX w/ Goodies
Old 03-19-2017, 03:33 PM   #11
bbally
Asylum Inmate
bbally's Avatar
Feedback Score: 4 reviews
How does that bearing feel in the sprocket?
That cushion should spin around the outside of the spacer. I had to trim the ID on one.
USMC '79-'85 Sgt.
1st Mar Div, 1st FSSG Det A in the Stumps
Malo periculosam, libertatem quam quietam servitutem
Freedom is different for those whom have fought to preserve it!
bbally is offline   Reply With Quote
Old 03-19-2017, 05:47 PM   #12
mattssi
Registered Full
The spacer is supposed to spin? I'll have to make sense of that. I thought it's stationary while the cush and sprocket rotate around it.
The bearing seemed okay. It was flush, spun correctly, etc.
I cleaned it up, put some a/s on the outside of that spacer, reassembled and took it for a drive.
No noise in the 2 blocks I road which is way better than last time.
Now, I can't quite figured out why its fixed. There were clearly red shavings everywhere, so something wasn't 100%.
2011 DX w/ Goodies
Old 03-19-2017, 06:21 PM   #13
bbally
Asylum Inmate
bbally's Avatar
Typed that wrong.
The Cush should spin around the spacer without touching the spacer.
USMC '79-'85 Sgt.
Old 03-19-2017, 06:26 PM   #14
RustyG
Lifetime Premium
RustyG's Avatar
Images: 99
Where did you get that " new urethane cush bushing (red) " from. Is it OEM or after market?
Regards,
John
Old 03-19-2017, 06:45 PM   #15
mattssi
Registered Full
It's aftermarket. Energy Suspension
2011 DX w/ Goodies
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
