Stock R lean angle - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Go Back   1130cc.com: The #1 Harley Davidson V-Rod Forum > Specific Model > VRSCR
Reply
Thread Tools Display Modes
Old 06-30-2016, 05:23 AM   #1
Mossimo70
Registered Full
Garage
Feedback Score: 0 reviews
Stock R lean angle
Hey fellow R riders,
I've been rocking the R for several months now and have started pushing through the corners a little harder lately. For a 600lb bike it has held rock solid in the corners through whatever I've thrown at it.
I still have chicken strips on the edge of my tires, but much less (1/2") on the rear than the front tires (~1"). Haven't felt any peg grinding.
Mine is stock down low, except for slip-on supertrapps. Most cruisers I've ridden will scrub the pegs long before you run out of tire. It doesn't feel like the VRSCR pegs will ever scrub the pegs until it lays down outright. I really don't want to find out the hard way!
Anyone with experience that knows the limits of the R lean angle and what to expect in extreme cornering?
Mossimo70 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 06-30-2016, 06:26 AM   #2
mikeinatlanta
The Massive Pr1ck
mikeinatlanta's Avatar
Expect it to remain rock solid. With a stock suspension, you will use right up to the edge of the rear tire and keep a little chicken stripe on the front.
New avon cobra
After day one in the mountains
Day two
Day three
Day eight
mikeinatlanta is offline   Reply With Quote
Old 06-30-2016, 07:26 AM   #3
-alan-
Registered Full
-alan-'s Avatar
^ You prefer left-handers by the looks of things Mike
Funny thing, the vast majority of the road-bikes here usually show the signs of hard cornering through right-handers rather than the left - scraped footrests/tortured tyre edges etc. We must all tend to feel a bit more comfortable winding it on when the apex is in the middle of the 2 lanes, rather than tight into the ditch (or kerb as you guys have it).
VRSCD - Blue no more.
-alan- is offline   Reply With Quote
Old 06-30-2016, 03:25 PM   #4
mikeinatlanta
The Massive Pr1ck
For me it's all about overdriving what I can see. In the mountains, you can see further around left handers and therefor carry a lot more speed safely. You can't tell looking at the photos, but I put more wear on the left from speed but the right gets more tread lipping from accelerating out of the corner harder when I can see down the road.
Old 06-30-2016, 03:59 PM   #5
Mossimo70
Registered Full
Garage
Quote:
Ah! Thanks for the info. I pushed a little harder into the twisties on the way home today and felt the tip of my boots in the road. The bike felt fine. I'll run this way for a while on ideal days and see how my tires wear.
For a 600lb bike, the R sure responds!
Old 06-30-2016, 08:58 PM   #6
mikeinatlanta
The Massive Pr1ck
The more you ride it, the better you will understand why even ex racers love it in the corners. Its rock steady and the limitations are just about perfect for sane road speeds. Even on a sport bike I don't go any faster on the street and it's so steady you could about take a nap at full lean.
Old 06-30-2016, 09:02 PM   #7
Tassie Tony
Devils Advocate
Tassie Tony's Avatar
How long does a front last you? Some riding styles favour one end or the other.
Glamacolor Productions
Sofa King
Dr Phil double episode attendee
Shock bolt/oil cooler hose rubbing on brake line whistleblower
Quote:
The X Diavel is so cool, so fast, and so cheap, it just buried The V in sales.
Nukular codes..............what does this button do recipient
Tassie Tony is offline   Reply With Quote
Old 06-30-2016, 09:19 PM   #8
mikeinatlanta
The Massive Pr1ck
Front usually has a bit left, but not enough to do two rears. I like the Cobras, but once you start leaning they start wearing away quickly. Not surprising when considering just how much weight they are moving around the corner.
Old 07-02-2016, 09:34 AM   #9
streetrodracer
Registered Full
hey mikeinatlanta, I've got the Exedra 180/55ZR tire and it also wears on the left side, I only get up to your mountains once a year so its not all that. I believe it is a combo of what you said plus the built in crown in the road is 3/4s of it and riders leaning left slightly to offset exhaust weight 1/4 of it. Also feathering on the right side looks like more braking than acceleration on that side. My Triumph with smoother 3 cylinder power pulses, a muffler on each side and Cobra tire has much less left side wear, rt. feathering.
I believe the Cobra is one rubber compound with AVD variable belts to help cornering traction. The Exedra is two rubber compounds with the same belts I think. What tires have you run to compare and do you run a 200 on the stock wheel ? Yes, the " R " stands for "Rocks " Thanks !
streetrodracer is offline   Reply With Quote
Old 07-02-2016, 12:22 PM   #10
mikeinatlanta
The Massive Pr1ck
No doubt road crown accounts for most wearing on the left for the straight up guys, but I carry a whole lot more speed left as well. One too many collar bones and I pretty much gave up on trail braking (racing days), plus I don't use rear brake when playing in the corners, so it's no doubt acceleration lipping you are seeing. I tend to keep speeds low on the straights and just carry it all in the corners, so I don't ever lip the front from braking either.
Tires are stock sizes. I wouldn't run a 200 unless I also mounted a correct wheel width to run one.
I actually drag more on the right, but I think it has more to do with inconsistent lines and driving out. With greater visibility, left tends to be more smooth with more time right at the edge of dragging. Right is go slow and as soon as I can see, get on the gas and lay it down.
Old 04-19-2017, 09:11 PM   #11
Katchme
Registered Full
Katchme's Avatar
where in ny are you from/?
Katchme is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
